PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 8th September 2017, 09:29 AM   #9501
Zootalaws is offline Zootalaws  New Zealand
Originally Posted by TimCurtis View Post
Hi @didiet78,
Look for Beta2 this weekend :-) Please report issues to my email address so I can easily track them and respond.
-Tim
Yer killing my third-world bandwidth, Timothy!
And my wife wants to know what happened 'to my BBC radio'?
Tried to explain, got the blank look after about the third word...
Old 8th September 2017, 09:57 AM   #9502
Longgone is offline Longgone
For some time I tried to have the random play function among other problems with low or no wifi reception. After changing to a new SD card the wifi is much better.
Now I would love to tackle the Random Play:
ANYbody with a setup like me: PiZero with hifiBerry DacPlus zero 1.0.1? has this function without problems?
thx
LG
Old 8th September 2017, 11:34 AM   #9503
Serverbaboon is offline Serverbaboon  United Kingdom
Originally Posted by isaacc7 View Post
A quick question. If I am using my pi strictly as a DLNA renderer, does the program running on it affect the sound? My pi will be coming next week and I'm researching how I want to set it up. I plan on using JRiver Media Center to stream to the pi and then connect it to my Oppo HA-2SE. I've seen several opinions that Moode is the best sounding program for the pi but does that hold true just for DLNA rendering? Thanks.
As Zoot says further down UPMPDCLI is just a front end or comms broker for your control point to submit songs, playlists and radio streams to MPD so there should be negligible perfomance hit. UPMPDCLI does not process the audio merely populates the MPD queue with the urls of your songs such that MPD can play by them submitting by HTTP requests to your UPNP server.
For me the UPNP control point is a better interface on my phone than web front ends and my UPNP server is a much nicer and more flexible music database management service than MPD. The use of a media server over MPD access to a share does not bother me too much.
I disagree with Zoot a little in that I prefer to use Moode because its still useful to benefit from all of Tim's customisation/optimisation work rather than trying to roll my own install, I just turn off all the other services.
Old 8th September 2017, 11:48 AM   #9504
mhouston is offline mhouston  Australia
mhouston's Avatar
Originally Posted by Zootalaws View Post
You are recommending an Australian-specific semi-commercial forum with a few hundred active members over what is possibly the most widely-read home audio forum on the planet with over four hundred thousand international members and you think it will drive more business?
Current stats: Threads: 297,787, Posts: 5,115,508, Members: 404,462, Active Members: 23,201
There are more posts in this single thread than in the entire computer/software sub-board of SNA.
Perhaps you would be better off pointing your small-forum members over here?
An oak tree starts with an acorn.
Old 8th September 2017, 12:46 PM   #9505
Vhond is offline Vhond  Netherlands
Originally Posted by kaspersone View Post
Hi guys / Tim
First of all this is an amazing community.
I started my audiophile raspberry-pi adventure half a year ago, and have tried both Volumio and Moodeaudio. Both are excellent pros and cons
I started with my DAC connected via USB to my rpi3, and upgraded with the DigiOne from Allo as soon as it was released sound quality is superb, outperforms everything else Ive heard so far.
Kids mostly use it with airplay (I know quality is not the best, but its easier).
Could you be more specific about pros and cons Volumio versus Moode?
Maybe something for Moode version 4 to get even better??
And what about the lesser quality with Airplay? (restrictions with bitrate you mean?)
Old 8th September 2017, 12:52 PM   #9506
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
lol, you should see my monthly AWS CloudFront bill :-0
Enjoy the Music!
http://moodeaudio.org, http://twitter.com/MoodeAudio
Old 8th September 2017, 01:53 PM   #9507
isaacc7 is offline isaacc7  United States
upmpdcli is the dlna front end for MPD, which is the main audio engine in moode, and most other Linux audio solutions.
But, why not share your files over your network and cut out two complete interfaces and play the music directly?
In your implementation you will be going from source>JRiver>upmpdcli>MPD, where you could be going from source>MPD and taking advantage of all the wonderful tweaks Tim has designed.
If you just want dlna, there are simple Pi configurations that will perform that for you without all the overhead of libraries, airplay, etc.
Thank you, I was thinking that I could use a much simpler set up. I like using JRiver because Jremote on the iPhone and iPad are great. Maybe one day I'll have a setup that allows me to connect my computer directly to my DAC but until then I'll stream from JRiver to my system in the other room.
Thanks for the info!
www.isaharr.com
Old 8th September 2017, 08:01 PM   #9508
repairmatt is offline repairmatt
Originally Posted by repairmatt View Post
Hi, Tim,
I am experiencing a weird problem, I just updated to the latest version of Moode and since my DAC doesn't support DSD I'm using the DSD to PCM conversion. Whenever I play a DSD file it sounds like it's sped up, like a 33 record on the 45 setting. I've tried several DSD files, all DSD64 and they all do the same thing, it never did this with 3.6. I am using the advanced real-time kernel. Thanks for any help you can provide.
To troubleshoot, start by installing the Standard Linux kernel and then re-testing.
What DAC are u using?
-Tim
I just reinstalled the standard kernel making sure all the settings are at default and it still has the problem. I'm using a HiFiBerry DAC+ Pro.
Old 8th September 2017, 09:15 PM   #9509
JimCoMV is offline JimCoMV  United States
I have the same DAC. It doesn't seem to work with DOP. However, if you set "DSD over PCM(DOP)" to "no" it will work properly. At least mine does.
Old 8th September 2017, 10:22 PM   #9510
I've set mine to no as well and it's still doing it. If you enable DOP with the DAC+ Pro it will just be static when you play a DSD file.
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 06:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
Copyright ©1999-2019 diyAudio
