PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 26th August 2017, 10:25 AM   #9181
heifisch is offline heifisch  Germany
Hi Tim,
for trying brutefir you first of all need a filter to implement.
There is an image for rspi from the german electronic manufacturer abacus-electronics.de (arioOS). He uses the image for streaming and convolving in his products but also provides a free download of this image. In this image brutefir is integrated and it seems that the filter needed has 65536 taps. The software used is acourateCV. You can make a room measurement with the rspi and a miniDSP UMIK-1 with the arioOS. This measurement is used in the acourate software to create roomcorrection filters. These filters you can select in the brutefir UI and listen to your music convolved on the fly with your roomcorrection.
I think this would be a great update for all that use moode with speakers. The acourate software costs 100.-€ and needs windows (AcourateCV - AudioVero)
Unfortunately it seems that this part of the audiovero website is not translated to english.
For further investigation I could provide you with a filter 44.1 kHz 65536 taps 64-bit double prescision *.dbl which could be -6dB linear to 1000Hz and after that steady falling down to -11 dB at 22050 hz.
You would hear immediately if the filter is active.
Heiner
Old 26th August 2017, 12:57 PM   #9182
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
Originally Posted by squadra View Post
Hi Tim,
Can you add this to your list of features to consider for vNext:
Add links to the artist/album in the currently playing section in the playback tab?
They should jump to the browse/search box for the artist and the library/album for the album.
If you click on the cover art in the Playback tab it launches a google search using the song title for Radio Stations and artist + album for Song Files.
-Tim
Enjoy the Music!
http://moodeaudio.org, http://twitter.com/MoodeAudio
Old 26th August 2017, 01:15 PM   #9183
TimCurtis's Avatar
Originally Posted by heifisch View Post
Hi Tim,
I think this would be a great update for all that use moode with speakers. The acourate software costs 100.- and needs windows (AcourateCV - AudioVero)
Heiner
Hi Heiner,
Seems like a lot of moving parts. I think if there were a full DRC package available that included the signal sweep function and could be configured by simply manipulating conf files I could probably work with it.
The other concern I have is whether the Pi has enough horsepower to run convolution DSP on top of other DSP for example SoX resampling.
-Tim
Enjoy the Music!
Old 26th August 2017, 01:48 PM   #9184
Man in a van is offline Man in a van  United Kingdom
Originally Posted by TimCurtis View Post
Hi Heiner,
-Tim
This chap has been very helpful to me in the past and apparently he does some "convolving".
At least, it might be an interesting read if one understands what it is about
ConvoFS.net — ConvoFS documentation
I have no idea if it could be used in conjunction with MoOde.
Ronnie
Old 26th August 2017, 02:13 PM   #9185
TheOldPresbyope is offline TheOldPresbyope  United States
Hi Kent,
Stretch testing is just beginning for me. I'm still squashing the last few bugs in the Jessie build of moodeOS and moOde. Stretch brings new versions of ALSA, Samba etc and will take some time figure out.
Its nice to see that after the BlueZ project for some strange reason deleted ALSA support in Jessie is now supporting it again in Stretch.
-Tim
My personal opinion is that Bluetooth output should take a backseat to everything else. Pairing and connecting to a Bluetooth device from the command line in Linux is very fiddly. It'll take some doing to make it as easy with moOde Player as it is, for example, with my Android phone.
According to the ReadMe at GitHub - Arkq/bluez-alsa: Bluetooth Audio ALSA Backend, "This project is a rebirth of a direct integration between Bluez and ALSA." No explanation is given for the project getting renamed BlueALSA (dropping the "z") along the way. A quick scan of the "Configuration & Usage" section and I had aplay playing through the JBL.
It isn't clear to me how mainstream this project is. There's only two contributors to the repo of whom "Arkq" seems to be the initiator and main coder.
There's two particular open issues on the github repo dating back to February which I'm reading through now. One has to do with the tribulations of someone trying to implement this in Volumio 2, and the other with high cpu-loading observed with mpd (0.19.x) playing through BlueALSA. The first BlueALSA source code "release" was v1.0.0. The current is v1.2.0, dated April. Don't know what's in the Raspbian bluealsa package. It says it's v0.4 Time to get my compilation mojo on.
Kent
Old 26th August 2017, 02:14 PM   #9186
takoyaki is offline takoyaki  Japan
Hi, Tim.
I have encountered a problem from Moode 3.8 to 3.8.3.
In Hifiberrydac+pro, playback speed is faster than usual after turning on pi3b power. This event will be fixed by pausing and replaying again.
Old 26th August 2017, 02:35 PM   #9187
Hi Tim,
acourateCV is the thing to measure and produce filters. But you need brutefir to convolve them with your music.
By the way, convoFS is very good but it is used like brutefir, especially if you have a synology NAS with intel processor.
So you will also need a software for measurung and generating filters.
And yes, maybe it will stress the rspi convolving and upsampling. I use DRC now for about ten years and I can assure you, that there is no need for furhter DSP or upsampling if you use proper filters.
Maybe there are other products than aourate. I do not know as acourate works very fine for me.
Heiner
Old 26th August 2017, 02:47 PM   #9188
TimCurtis's Avatar
Kent
Hi Kent,
I haven't really looked at Stretch yet but what is output from
dpkg -l | grep blue
-Tim
Enjoy the Music!
Old 26th August 2017, 02:50 PM   #9189
TimCurtis's Avatar
Originally Posted by takoyaki View Post
Hi, Tim.
Very odd. I've never experienced this.
What sample rate is the audio?
-Tim
Enjoy the Music!
Old 26th August 2017, 03:10 PM   #9190
-Tim
It is mp3 files(44.1KHz, 16bit).
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 30th April 2017 12:10 AM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 08:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 07:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 06:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 04:38 AM
Copyright ©1999-2019 diyAudio
