PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 25th August 2017, 09:11 PM   #9171
gychang is offline gychang  United States
Originally Posted by TheOldPresbyope View Post
What happens if you simply power-cycle the RPi?
If the username "pi" and password "raspberry" don't work on an r3.7 system then you must have changed your credentials or (somewhat far-fetched) your SD card issue is preventing the login.
r3.8 requires a fresh install. I just noted in a recent message that this report saying an r3.7 installation has the latest update could be improved on. It's true in the sense that it has the latest update for the r3.7 series.
What model RPi? If an RPi3b, you can do boot directly from USB. If an RPi2b, there is an indirect method which bootstraps from a file on the uSD card to get to the USB drive. The RPi3B method has been discussed previously in this thread. Both it and the RPi2B method are discussed on the RaspberryPi.org site.
Kent
power cycling result in the same problem. Can the password be reset by booting the SD in another PC using "passwd" command but root or pi password does not work...
if I want to try r3.8 version, will I have to pay $10 so I can unzip the file?
thanks
Good sound from Davis, CA
Old 26th August 2017, 12:06 AM   #9172
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
Hi, Si.
Is this with your files served over your Powerline network or from local media?
This is most curious. Strong enough spurious radiation in the same frequency domain can interfere with WiFi communication. Microwave ovens and cordless phones are notorious examples of a spurious emitter. I'm not sure, though, how to relate your reported symptoms solely to such interference from the HiFiBerry product ([ed]: if it's an emitter, perhaps it's also susceptable to radiation from other devices?). It'll be interesting to hear if getting a new HiFiBerry DAC+ Pro also results in the issue going away---assuming you want to do the test by reconfiguring all your WiFi devices back to 2.4GHz
Kent
Hi Kent,
Residential power wiring is inherently noisy, and its subject to injected noise from light dimmers, appliances, etc., and it forms a giant copper antenna. Its definitely not the greatest medium for transmitting audio data.
Unlike bulk data transfers (Web, Email, Downloads, etc) which use TCP protocol (guaranteed delivery or fail), audio data transfers use UDP (best effort, no retries) and use isochronous transmission which requires that the network provides a guaranteed data rate for the duration of the transfer.
Noisy network + UDP + isochronous tranmission = audio glitches!
-Tim
Enjoy the Music!
http://moodeaudio.org, http://twitter.com/MoodeAudio
Old 26th August 2017, 12:09 AM   #9173
TimCurtis's Avatar
Originally Posted by DaverJ View Post
If anyone is interested... Since I started my MPD Pi project, I've been plagued by pops/clicks for files above 48k. One of the reasons I switched to MoOde is this player's ability to re-sample higher res files down to 24/48, but it always bugged me that I couldn't play 24/96 files at full resolution without the occasional faint "tick" on my hardware setup.
In an effort to solve this, I decided to try to take the USB connection to the DAC (Musical Fidelity V90) out of the chain. I installed a JustBoom Digi-HAT for the Pi3 to connect via optical (or coax) to the DAC, so the files play through that I2S device.
As they say... MISSION ACCOMPLISHED. No more pops/clicks, and audio high-resolution files are now playing in glorious 24/96.
So, if a MoOde user is using a USB connection to a DAC and is experiencing faint random pops and clicks, particularly with higher-resolution files, I strongly recommend a digital connection other than USB to the DAC instead.
Hope this helps someone!
Hi Dave,
Glad to hear this :-)
Did u try the USB (UAC2) work around on System config?
-Tim
Enjoy the Music!
Old 26th August 2017, 12:37 AM   #9174
TimCurtis's Avatar
Originally Posted by JLOP View Post
Hi Tim
So is convolution with BruteFir now planned ?
BR
Jean-Louis
Hi Jean-Louis,
If I were to attempt to integrate it into moOde what would I need in order to test and verify that it works correctly?
-Tim
Enjoy the Music!
Old 26th August 2017, 02:36 AM   #9175
TheOldPresbyope is offline TheOldPresbyope  United States
Originally Posted by TimCurtis View Post
Hi Kent,
-Tim
Yes. That's why I asked whether files were being read via the Powerline Network or from local media when the issue went away.
On a totally unrelated subject, have you experimented yet with the BlueAlsa package in Raspbian Stretch? I got it up with just a couple lines of input. Right now I'm playing the soundtrack for the movie Pitch Perfect over a JBL Bluetooth speaker I happen to have. It's a lousy speaker but it suffices to prove BlueAlsa works.
Kent
Old 26th August 2017, 03:32 AM   #9176
No.
However, if you have a Linux computer available (or possibly OS X, but I don't have it so can't comment) you can mount the second partition of the SD card and do some black magic to regenerate the password in the file /etc/shadow. See, for example, How are passwords stored in Linux (Understanding hashing with shadow utils).
If you have only a Windows computer available, you can always live-boot Linux from a USB drive. Google is your friend.
You should be able to reuse the key you used to unzip r3.7.
thanks
You're welcome.
Kent
Old 26th August 2017, 03:48 AM   #9177
DaverJ is offline DaverJ  United States
Hi Dave,
-Tim
Hi Tim...
Yeah, I tried that work around, and a dozen other software and hardware attempts at fixing my faint "ticks" when playing high-resolution files over USB.
From my experience, digital out of the Pi is the best way to connect to a DAC. Thanks for your great software!
Old 26th August 2017, 03:54 AM   #9178
TimCurtis's Avatar
Hi Kent,
Stretch testing is just beginning for me. I'm still squashing the last few bugs in the Jessie build of moodeOS and moOde. Stretch brings new versions of ALSA, Samba etc and will take some time figure out.
Its nice to see that after the BlueZ project for some strange reason deleted ALSA support in Jessie is now supporting it again in Stretch.
-Tim
Enjoy the Music!
Old 26th August 2017, 05:45 AM   #9179
heifisch is offline heifisch  Germany
Hi Kent,
thanks for your help. I now looked at the manual and nothing about consumption is mentioned. I looked USB up in wiki and 2.0 needs 5 V 0.5 A. USB 3.1 needs 5V and 0.9 A. So it could possibly work with the y-Adapter. If I try this device, I will post the results here.
Heiner
Old 26th August 2017, 07:07 AM   #9180
squadra is offline squadra  Thailand
squadra's Avatar
Hi Tim,
Can you add this to your list of features to consider for vNext:
Add links to the artist/album in the currently playing section in the playback tab?
They should jump to the browse/search box for the artist and the library/album for the album.
I dither, therefore I might be.
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 06:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
Copyright ©1999-2019 diyAudio
