PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 19th August 2017, 06:28 PM   #9021
jonners is offline jonners  United Kingdom
jonners's Avatar
[QUOTE=Sparkwizard;5161927]how does one enable gab_mclk
/QUOTE]
In the Driver options, Audio Config - Devices.
Old 19th August 2017, 08:12 PM   #9022
SonofThor is offline SonofThor  United Kingdom
Well, I've just updated to 3.8.2 and using Kali/Piano 2.1 (dual-mono) and now I'm only getting audio out of one channel, so something has gone wrong there!
Edit: switched back to stereo operation and connected to main L/R and I now have 2 channels back. Shame to not be able to take advantage of dual-mono though.
Old 19th August 2017, 08:56 PM   #9023
TheOldPresbyope is offline TheOldPresbyope  United States
Originally Posted by tgraan View Post
Tim...
Yes, you identified another common factor: HifiBerry HATs. I will follow up with HiFiBerry support, but I will also describe my setup in more detail which will explain why I don't think it is the answer
1. Player#1 = RPi3 & Digi+ Pro. On-board wifi-BT is turned off, and external USB wifi adapter in use. No known interferences with this hardware configuration.
2. Player#2 = RPi2 & DAC+ Pro. No on-board wifi, and external USB wifi adapter in use. No known interferences with this hardware configuration.
3. Player#3 = RPi2 & DAC+. No on-board wifi, and external USB wifi adapter in use. No known interferences with this hardware configuration.
Thanks,
Tom
Hi, Tom.
I'm on a road trip and using my phone so will be brief (or else my finger will wear out).
Have you tried running one of these RPis with the DAC removed but no change in location, enclosure, WiFi setup, power arrangement, OS, etc? If it remains accessible for up a reasonable time (in your case, more than 20 days, apparently) then it's tempting to say the culprit is indeed EMI from the DAC to the WiFi adapter.
I only say " tempting" because it is also possible to point an accusatory finger at your power supply and power cabling. If the supply is marginal then the extra load of the DAC might be enough to pull the supply voltage over the edge, so to speak. Similarly, if the cabling conductors have high enough resistance (small diameter/long length) the extra load could again pull the supply voltage down enough. Also, the more marginal the supply voltage, the more the system will be susceptible to EMI coupled to the supply line from the DAC.
Kent
Old 19th August 2017, 09:20 PM   #9024
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
No issues w/Dual-Mono on my end. Looking at the RCA jacks its L/mute mute/R.
There is also a test cmd in the home dir named piano.sh. It dumps out the mode setting and volume levels.
Below is with MPD set to Hardware and moOde knob at 30. If MPD set to Software volume then volume levels below would all be 0dB (100%).
pi@rp3:~ $ ./piano.sh
Dual mode: Dual-Mono
Subw mode: None
Sub xover: 60
Sub level: 70%
Main levl: 70%
Mstr levl: 70%
-Tim
Enjoy the Music!
http://moodeaudio.org, http://twitter.com/MoodeAudio
Old 19th August 2017, 10:05 PM   #9025
r100 is offline r100
I think you have to set the subwoofer volume to 100% to get sound from the other channel (Audio Configuration > Chip/Device options) and put the RCA connector on the outer right connector.
Old 19th August 2017, 10:36 PM   #9026
Zootalaws is offline Zootalaws  New Zealand
Originally Posted by philrandal View Post
Even the lowly pi zero w with a PHAT DAC sounds great with similar settings (no upsampling ) . Tried an A to B comparison of some tracks on Marantz CD6004 CD player and FLACs ripped from the same physical CDs streamed from NAS using MoOde 3.8.2 and it was hard to tell the difference between them.
Phil
If only they could be purchased... outside of Europe and the US the shipping far exceeds the cost, which means buying 5 or so is the only economic method, but I've yet to find a vendor that will sell more than 1.
I've never understood this ridiculous policy.
Old 19th August 2017, 10:37 PM   #9027
TimCurtis's Avatar
Hi @r100,
No need to set Subwoofer volume when the mode = Dual-Mono or Dual-Stereo.
-Tim
Enjoy the Music!
Old 19th August 2017, 10:49 PM   #9028
ah, ok, thanks for that. I was under the impression that I had to do that in certain cases while in Dual-Mono but cant remember which
Old 19th August 2017, 10:55 PM   #9029
hifix is offline hifix  Australia
hifix's Avatar
Originally Posted by lukivision View Post
Hi Hifix,
to me, it seems, 3.8.2. does the best job concerning sq. This may be due to the newest kernel, but I dont know really. What is better? Stage, resolution, precision and agility. I´m using Rpi3 with Allo Boss and iFi iPower. Sox Upsample to 32bit 384 khz, advanced rt-kernel, cpu-governor on demand, FiFo.
Enjoy
Luki
Hello Luki,
Danke schön.
I appreciate the feedback. I will give the new release a go as soon as i get some time.
I'm using the RT kernel (on demand) with the RR setting. I'm using an audiophonics ES9023 DAC which thankfully provides enjoyment. I'm watchfull of the CPU temps as the whole thing is in an aluminium enclosure (which i've drilled out for ventilation). Without "on demand", the CPU temperature was a consistent few degrees higher.
Old 19th August 2017, 11:04 PM   #9030
DRONE7 is offline DRONE7  New Zealand
Originally Posted by TimCurtis View Post
Hi Bob,
Take a look at /var/www/command/restart.sh. This is what moOde uses for Shutdown and Reboot from the UI. In this script, MPD is sent a stop command which causes it to save its state file. The state file would contain the a reference to the last track that was played.
-Tim
Thanks Tim, I changed my lirc config to the command found in /var/www/command/restart.sh
Code:
begin
prog = irex
button = KEY_POWER
config = mpc stop; systemctl stop nginx; poweroff
end
It turns off cleanly but still something is stopping autostart on a cold start.
I am wondering if the gpio pin used for the lirc receiver is being polled by something else... I seem to recall you wrote previously about rotary encoders for volume and a moode config but can't seem to find this through the forum search...perhaps I have the wrong terms....
is there anything else in moode using gpio pin 25 ? I recall something about the rotary encode being 23 and 24 and possibly the switch being 25 ?
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 30th April 2017 12:10 AM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 08:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 07:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 06:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 04:38 AM
Copyright ©1999-2019 diyAudio
