PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 4th August 2017, 04:43 PM   #8671
dewdrop is offline dewdrop  Singapore
Originally Posted by hellrider77 View Post
You are correct regarding bass but in can live with that.
Yes, every difference is subtle but those subtleties make for great sound (cues for positioning and soundstage, tonal balance, etc). Of course I might seem to nit-picking but as a music lover hardliner and fundamentalist audiophile, those subtle details seem like night and day to me.
Anyway, got used to using moode 3.7 so will stick to that for a while before going the Aurender route.
What are you using RR or TS with LL-Kernel? Let me try listen on mine.
Ed
Old 4th August 2017, 04:46 PM   #8672
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
Originally Posted by marktd View Post
Please excuse the basic nature of my questions. I recently consolidated all the household music on one 5 Terabyte drive (with another as backup). We have Macs, but I formatted the music drive as exfat, thinking that was better for the Pi.
When I tried to add the music, Moode would seem to e doing so, and then choke. When 3.8 came out, I hoped it would solve my problem, but it does not. In addition, the file system always reads as unexpanded - I've tried all this several times. There is free space, so I've partitioned the backup, and have started the tedious process of copying files, with the aim of getting to 2 2.5GB partitions (in a couple days), hoping smaller partitions will solve the problem. Any help would be appreciated!
The "unexpanded..." message is a display bug and does not reflect actual file system expansion. I'll be posting a list of the 3.8 release bugs that have been discovered so far.
What does "choke" mean?
The best way to monitor MPD database update is to look at the log as its updating.
tail -f /var/log/mpd/mpd.log
or alternatively display the entire log:
cat /var/log/mpd/mpd.log
-Tim
Enjoy the Music!
http://moodeaudio.org, http://twitter.com/MoodeAudio
Old 4th August 2017, 04:47 PM   #8673
yannig is offline yannig  France
As far I know, moOde can read HFS+ format.
MoOde works perfectly with my 1TB.
I have not tested more.
Old 4th August 2017, 04:59 PM   #8674
lemting is offline lemting  France
Originally Posted by remy1961 View Post
Hi. I used to have this problem on my MAC and i found the solution on this forum. Go to finder, go, go to folder, enter "c/Users/yourusername/.ssh" and delete the file "known_hosts".
Remy
thank you Remy
now with SSH pi@moode.local, i can enter raspberry as password but it's still denied
maybe password is not raspberry
Old 4th August 2017, 05:16 PM   #8675
TimCurtis's Avatar
Hi @lemting,
pwd is moodeaudio
moOde Setup Guide
http://moodeaudio.org/docs/readme.txt
-Tim
Enjoy the Music!
Old 4th August 2017, 05:34 PM   #8676
hellrider77 is offline hellrider77  Romania
TS, i do not hear differences between MPD scheduler policy settings
Old 4th August 2017, 05:59 PM   #8677
Default sound differences 3.7 vs 3.8
eventually, I prefer 3.7 restitution...
On my system, 3.8 sound a little "thin", and with less "legato", and less "colors".
The sound is more relaxed with 3.7
For the rest, I do not find much differences. 3.7 and 3.8 run well.
For Tim :
I said before that there was some playlist problem sometimes.
It seems that I had this problem only when I tried to manage some UPnP streaming with Linn Kazoo or Kinsky (some residual information, I guess).
Now, I prefer to stream via Squeezelite renderer active, with Logitech Media Server. Much more stable, and I have access to a nice Qobuz plugin .
Old 4th August 2017, 06:09 PM   #8678
Your description is quite accurate. Thank you
Old 4th August 2017, 06:39 PM   #8679
TimCurtis's Avatar
Originally Posted by TimCurtis View Post
Hi @BryceJ, @jamont, @AdZero,
Zip up a dir containing a few song files, cover image, etc that will enable me to try and repro the issue. Email download link to tim at moodeaudio dot org.
-Tim
Originally Posted by kaktus99 View Post
Hello
Al my musicfiles are .flac with no embedded pictures on my NAS, but in every album directory there is a file named cover.jpg.
In 3.7 (and earlier) cover.jpg was diplayed perfectly for each song in this directory. In 3.8 no more.
Is there a solution?
I was able to use @kaktus99's files to discover a regression bug involving a missing symlink.
The symlink below was not present in /var/www
lrwxrwxrwx 1 root root 18 Aug 4 14:15 mpdmusic -> /var/lib/mpd/music
-Tim
Enjoy the Music!
Old 4th August 2017, 06:56 PM   #8680
philrandal is offline philrandal  United Kingdom
-Tim
pi@moode:~ $ sudo ln -s /var/lib/mpd/music /var/www/mpdmusic
ln: failed to create symbolic link ‘/var/www/mpdmusic’: Read-only file system
Pi Zero W + Pimoroni pHAT DAC / Pro-ject Elemental / Marantz CD6004 / Marantz PM6004 / Monitor Audio Bronze 2
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 06:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
Copyright ©1999-2019 diyAudio
