PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 26th June 2017, 03:28 AM   #8281
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
Originally Posted by Holzohren View Post
I have connected my Raspberry 3 with HiFiBerry DAC + pro via RCA to my amplifier. To adjust the volume to other amps connected to the amplifier, I have set the Volume (ALSA) to 85% in MoOde Audio Player 3.7 under Audio Configuration.
Has this setting affects the bit rate of a HiRes file (for example 24bit / 96kHz only ~ 20 bit remaining) or only changes it the audible volume?
Thanks alot
I don't quite understand your configuration and why you would set ALSA volume to 85%. ???
Are u using an external volume control (on your amp or preamp)?
-Tim
Enjoy the Music!
http://moodeaudio.org, http://twitter.com/MoodeAudio
Old 26th June 2017, 06:27 AM   #8282
Bedlore is offline Bedlore  Australia
[feature request] Could NAS mounts remain visible even when empty please. I move music around and its annoying having to go into sources to have to force an update.
Old 26th June 2017, 07:13 AM   #8283
watchal is offline watchal  Thailand
Originally Posted by Man in a van View Post
@ watchal
Stop MoOde Player and remove the sd card from the raspberry pi.
Put it in a card reader and plug that into the Windows computer.
Go to My Computer (or equivalent), locate the card and click on open, this puts you into the /boot section.
Open the file called config.txt with Windows Wordpad.
Scroll to the bottom of the text and add
dtoverlay=simple-bclk-64fs
Save and exit.
Remove the card from the computer correctly, put it back in the pi, boot the pi and select the kernel you wish to use from the relevant settings page .
You can also use a program called Putty to access the card via SSH whilst it is still in the pi, But the above way is easy and simple, if you wish to learn a little more, come back.
atb
Ronnie
Really thanks
I did above 2 days ago but when boot pi again I cannot connect to moode .
So I think I make mistake .
just now image write again and edit the config.txt ( I see only config file icon) boot and connected
so play music tonight
really thanks again.
Old 26th June 2017, 08:12 AM   #8284
CarlTorn is offline CarlTorn  Sweden
Just bought Moode 3.7 gonna give it a go now. I have Raspberry Pi3, with Pi 7" touchscreen and HiFiBerry DAC+ Pro. Love my config.
Old 26th June 2017, 08:26 AM   #8285
ianrt is offline ianrt  Australia
Holzohren,
All digital volume controls affect the bits - whether it is an issue is debatable.
You would have to set the level to 50% to lose 1 bit, 85% is not a serious deficit.
Ian
Thanks alot
Old 26th June 2017, 02:34 PM   #8286
Holzohren is offline Holzohren
-Tim
Hi Tim,
I want to adjust the volume for a direct listening comparison between LP and HiFiBerry. I'm not sure if the change of the volume (ALSA) synonymous the quality of the HiRes file changes.
Old 27th June 2017, 03:28 PM   #8287
TimCurtis's Avatar
Some improvements to Source Config coming in moOde 3.8 ncluding quick Re-mount and Reset library cache.
The Re-mount function is useful in cases where NAS sources are offline when Pi is rebooted. Resetting the Library cache resolves the issue where the Library was opened before MPD update completed thus leaving the Library incomplete.
-Tim
Enjoy the Music!
Old 27th June 2017, 07:49 PM   #8288
Worldofsteve is offline Worldofsteve
Default Missing metadata / tracks
Moode sounds amazing and remains the best piece of freeware I've paid for, but the library view appears to be dropping artists / albums that MPAD "sees" so I guess the tagging is Ok, I have >15000 tracks can that be an issue?
I'm quite happy using MPAD except I think the next IOS update will kill it off.
Old 27th June 2017, 07:58 PM   #8289
Bruce2W is offline Bruce2W  United States
I am considering upgrading from RuneAudio to Moode on my Pi 2B. Could anyone help me with a few questions?
1. Is it compatible with the Behringer LCA202?
2. Could I mix the line level input of the LCA202 into the output from Moode?
I use the Pi as a phone controlled audio player in my boat. I would like to mix in audio from the VHF radio via the line in of the LCA202. I am hoping this is just a matter of making changes to mixer settings.
Old 27th June 2017, 08:31 PM   #8290
Sorry guys, my LCA202 is actually a Behringer UCA202.
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 30th April 2017 12:10 AM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 08:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 07:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 06:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 04:38 AM
Copyright ©1999-2019 diyAudio
