PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 17th April 2017, 11:26 AM   #7171
vakharia is offline vakharia
Originally Posted by albanibr View Post
Hey, my ALLO BOSS option is gone!
An externally hosted image should be here but it is no longer accessible. Please upload images instead of linking to them to prevent this.
I suppose you are using MoOde 3.5?
Try installing the Advanced Kernel.
Old 17th April 2017, 11:31 AM   #7172
lemting is offline lemting  France
hi
impossible to save:
-new radio station
-new playlist
it's like if we can't write on sd card
Old 17th April 2017, 11:34 AM   #7173
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
Originally Posted by higash View Post
Hi Tim.
I want to rebuild kernel with aufs4 patch.
Please tell me the difference from the original kernel 4.4.50.
I can send you the sources for 4.4.39 advanced kernel if you would like, but beyond that you would have to rebuild it on your own.
-Tim
Enjoy the Music!
http://moodeaudio.org, http://twitter.com/MoodeAudio
Old 17th April 2017, 11:36 AM   #7174
TimCurtis's Avatar
Originally Posted by aBrianH View Post
Tim. Promoting Moode on UK forum Pink Fish Media I am getting asked if Moode can process Tidal see Moode player 3.5 - pink fish media
Is it possible either now or as a development? Thanks
As @joiners mentioned, it possible to stream any music service through Moode by using either Airplay, UPnP or Squeezelite renderers.
-Tim
Enjoy the Music!
Old 17th April 2017, 11:41 AM   #7175
TimCurtis's Avatar
Its a bug. Try the workaround in the post below. Note the Boss driver is only in the Advanced kernels.
-Tim
Enjoy the Music!
Old 17th April 2017, 11:43 AM   #7176
TimCurtis's Avatar
Originally Posted by Pascal Kunzler View Post
Hi Tim,
Thanks a lot, all fine for me. Fantastic work !
(except save playlist , but you already noticed).
As I prefer to display coverart above control and then playlist in colomn display for small media, I added this lines in /var/www/css/moode.css in section @media (max-width: 768px):
#playback-panel .row-fluid{
display: flex;
flex-direction:column-reverse;
Perhaps a new configuration choice to implement?
Pascal
Hi Pascal,
Thats cool. I'll check it out later today.
-Tim
Enjoy the Music!
Old 17th April 2017, 11:59 AM   #7177
albanibr is offline albanibr
-Tim
Yes.. version 3.5
thank's for your support!
Old 17th April 2017, 12:17 PM   #7178
Ron54 is offline Ron54
Hi Pascal,
Thank you for your quick reply but I am using a Hifi Berry DAC and still had the noise when using a combined 12V/5V PS.
But the noise in the speakers is gone now with separate PS, perfect music quality now, so that problem is solved for me.
What I need now is a means to isolate the speakers for a couple of seconds when powering the system on.
Ronald
Old 17th April 2017, 12:20 PM   #7179
Sorry, I meant Vakharia off course, not Pascal....
Anyway, I think the thump comes from the power amplifier, not from the RPI with or without DAC.
Ron
Old 17th April 2017, 01:37 PM   #7180
Man in a van is offline Man in a van  United Kingdom
Ron
Power amplifier: switch on last, switch of first.
So to avoid any noise you will need a couple of lines of code, maybe?
atb
Ronnie, who thinks there should be a little more Rons (see what I did there?)
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 06:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
Copyright ©1999-2019 diyAudio
