PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 19th October 2019, 06:39 PM   #14951
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
Yes of course, math and physics guarantees there will be a limit to the true resolution of the device.
Old 19th October 2019, 06:41 PM   #14952
TimCurtis's Avatar
Originally Posted by matthiasw View Post
Thanks Tim,
I forgot to mention that I would like to go for an USB-DAC like the upcoming Revolution DAC from Allo and I would like to let Audirvana do all DSD converting or upsampling.
So the signal path through Moode should be as pure as possible.
Does this change some settings you mentioned?
Thanks again.
Matt
If u are using moOde just as a UPnP renderer and i assume controlling volume with Audirvana or some downstream volume control device then you would want to set MPD volume to "Disabled (0dB)".
Old 19th October 2019, 06:56 PM   #14953
matthiasw is offline matthiasw  Germany
Yes, volume control with analog preamp downstream.
With a wired ethernet connection to the SIG the setting would be:
Wait for eth0 address: ON
Correct?
I have searched many forums and did not found many issues in working together of Audirvana and Moode as UPnP renderer.
What is your experience?
Matt
Old 19th October 2019, 07:26 PM   #14954
TimCurtis's Avatar
Yes. When it's ON moOde waits up to 9 seconds for an IP address to be assigned before continuing its start up sequence. Typically an IP address is already assigned before moOde startup begins and so no wait occurs.
Old 20th October 2019, 07:01 PM   #14955
Jempie is offline Jempie  Indonesia
i want to protect the settings page with an password, so that only i can only change the settings, but i cannot override the source.
does anyone knows why it's protected
Old 21st October 2019, 10:04 AM   #14956
Hi Tim,
cdsgames reported on the Shanti thread that USBridge Sig. does support up to DSD512.
I assume he tested it with MoOde.
I want to send high rate native DSD (not DoP) via UPnP to the SIG/MoOde and then to USB-DAC.
Do exist MoOde settings so that DSD stays native and does not get converted into DoP or PCM?
Matt
Old 21st October 2019, 12:39 PM   #14957
TimCurtis's Avatar
Below is from the MPD manual.
User’s Manual — Music Player Daemon 0.22 documentation
"Native DSD playback is used automatically if available. DoP is only used if enabled explicitly using the dop option, because there is no way for MPD to find out whether the DAC supports it. DSD to PCM conversion is the fallback if DSD cannot be used directly."
Old 11th November 2019, 01:57 AM   #14958
mhouston is offline mhouston  Australia
mhouston's Avatar
Default Moode6
Ive installed and upgraded to the latest Moode but wish to use it as an access point. All good but what IP should I enter now.
Old 11th November 2019, 02:24 AM   #14959
mhouston's Avatar
Found it.
Old 11th November 2019, 07:50 AM   #14960
BackinBlack is offline BackinBlack  England
BackinBlack's Avatar
Originally Posted by mhouston View Post
Found it.
You'll find a lot more info over at -Moode Forum
Glad to hear you got it working
Happy Listening
Ian
Just listen, if it sounds good to you, enjoy it.
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 30th April 2017 12:10 AM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 08:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 07:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 06:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 04:38 AM
Copyright ©1999-2019 diyAudio
