PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 5th November 2017, 08:52 AM   #10521
aBrianH is offline aBrianH  United Kingdom
Sorry for the stupidity BUT.
I have and used a MacBook Pro to make SD cards for Moode until now. Keen to examine the beta however.
I have copied the img to a USB disc.
Now looking at STEP 2 I assume there is no way to persuade OSX to do the same stages? i.e. there is no /mnt but there is a /Volumes.
no /dev/sda1 and so forth.
The only Linux I have is that care of Moode. Do I have to wait until someone offers a build like Tim has done until now? Or is there an alternative way?
Thanks folks
Old 5th November 2017, 09:16 AM   #10522
Man in a van is offline Man in a van  United Kingdom
Try "moodeaudio" as passwd
Old 5th November 2017, 09:19 AM   #10523
Default Don't Panic! give it a go!
Yesterday I installed Raspbian Stretch Full on a rpi3b with attatched monitor,mouse and keyboard.
I followed the instructions for steps 1 and 2 from the receipt with regard to the usb stick and when I got to here
Code:
Use "sudo fdisk -l -o Device,Start,Type | grep 0p" to print the partition data. Offset = Start * 512.
there was no data posted on the screen.
I knew that a previous OP had informed Tim of the same problem, I found the post and read Tim's reply.
The info that this step is based on the OS that I was using on the rpi encouraged me to just continue with the process without trying Tim's workaround.
The install completed and I then did the image burn and completed the beta7 install.
I did leave out Step 11 and did not install any additional components.
Today I used Gparted on a live usb stick of Mint to check the partitions on the sd card, here are the results;
The card is a Scandisk 16gb
reading from left to right I got
"unallocated"..............4.00 Mib
"/dev/sdc1"...............Size 41.81 Mib............Used 21.48 Mib
"/dev/sdc2"...............Size 2.93 Gib..............Used 1.62 Gib
"unallocated".............11.86 Gib
So, if one has no linux skills, but possess a pi (that's a given) have accesss to a kepboard and monitor and an extra sd card, then it is quite possible, with a little care and diligence to complete the receipt.
Hope this helps.
Last edited by Man in a van; 5th November 2017 at 09:38 AM. Reason: forgot the rodent (duh!)
Old 5th November 2017, 09:27 AM   #10524
Being a "bear of little brain" I just realised that I could have got the info the easy way
Code:
sudo fdisk -l
gives
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 8192 93813 85622 41.8M c W95 FAT32 (LBA)
/dev/mmcblk0p2 94208 6238207 6144000 3G 83 Linux
From Tim's receipt
I don't know if this is important or even matters, perhaps some one can explain.
Every thing seems to work, regardless
Ronnie
Old 5th November 2017, 09:35 AM   #10525
tonno is online now tonno  Austria
Thanks folks
Hi aBrianH,
i have no OSX, but i think you can write the unmodified stretch image to a sd-card like all the moode images you did before. Then pull out the sdcard and plug it in again. There shouls be the FAT boot-partition. Then create an empty file with the name "ssh" on the "FAT" partition. Thats it.
Eject your sdcard from your mac and follow STEP3.2
Disadvantage of this method: After the first boot the root-filesystem will expand to its maimum size, so a backup of your sdcard will eat a lot of time and a lot of memory. And belive me - you want to have a backup after hours of compiling and installing
-tonno
Old 5th November 2017, 09:47 AM   #10526
Does this help?apply?
Scroll to the bottom of the page
boot - Disable auto file system expansion in new Jessie image 2016-05-10 - Raspberry Pi Stack Exchange
Old 5th November 2017, 09:53 AM   #10527
jonners is offline jonners  United Kingdom
jonners's Avatar
I did it basically using tonno's method in the previous post. No keyboard, monitor or mouse attached to the RPi. Used Apple Pi Baker on MacBook to create the Stretch image on SD card, and terminal for the rest. Adding the empty file enables you to initially ssh in to the RPi.
Old 5th November 2017, 11:25 AM   #10528
Originally Posted by Man in a van View Post
Before you plug it into your Raspberry Pi.
Edit the file: /boot/cmdline.txt
Remove the following text: init=/usr/lib/raspi-config/init_resize.sh
Code:
pi@raspberrypi:~ $ df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root       1.7G  1.1G  520M  67% /
devtmpfs        460M     0  460M   0% /dev
tmpfs           464M     0  464M   0% /dev/shm
tmpfs           464M   18M  446M   4% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           464M     0  464M   0% /sys/fs/cgroup
/dev/mmcblk0p1   42M   21M   21M  51% /boot
tmpfs            93M     0   93M   0% /run/user/1000
Just tried it - and it seems to work properly.
We do not need a linux-pc needed for the build process
-tonno
Old 5th November 2017, 11:43 AM   #10529
Originally Posted by tonno View Post
Hi aBrianH,
-tonno
Thanks for that suggestion tonno, it made the best sense from my position.
However, I tried it twice and after the powerdown on restart of the box - powered on again - the pi was no longer on the network.
It is connected by ethernet BTW. So I reburned the SD card and went through the same process to fail at Step 4.1 just isn't on the network.
Looks like the Step 3 things have not worked as intended.
Checked the SD card in the Mac and the only thing that had changed was config.txt. That now reads
disable_splash=1
hdmi_drive=2
dtparam=i2c_arm=on
dtparam=i2s=on
dtparam=audio=on
#dtoverlay=pi3-disable-wifi
#dtoverlay=pi3-disable-bt
Stumped - it is beyond me sad to say.
Old 5th November 2017, 11:48 AM   #10530
@tonno
Snap!, I have just done it on Raspberry stretch-lite on an rpi3b using a 7gb card
Here is the output of "sudo fdisk -l"
Disk /dev/mmcblk0: 7.5 GiB, 8010072064 bytes, 15644672 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x11eccc69
/dev/mmcblk0p2 94208 3622247 3528040 1.7G 83 Linux
I'm going to expand the card using sudo raspi-congfig ( I know that there is a simple cmd line for this, but can't find it at the moment).
When the card is expanded and updated I'll start the usb stick trick and see how it goes.
I'll be using Putty on a Windows 10 laptop.
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 30th April 2017 12:10 AM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 08:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 07:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 06:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 04:38 AM
Copyright ©1999-2019 diyAudio
