PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 21st October 2017, 06:34 AM   #10121
Zootalaws is offline Zootalaws  New Zealand
Originally Posted by eta314 View Post
Yes it on. Sometimes it shows up as an airplay device but most of the time it does not.
Cannot figure out what is causing this inconsistent behavior..
Most often itís a network issue.
Wifi or Ethernet? Confirmed you only have the Pi at that address?
DHCP or fixed address? Got router settings, dns setting correct?
Old 21st October 2017, 09:48 AM   #10122
metalrob is offline metalrob
Originally Posted by philrandal View Post
See a few posts above for a working 320Kbps mp3 stream.
Try pasting the url in the flac.m3u into the Moode config for the station.
Phil
Thanx Phil!
The new 320K URL works;-) JB Radio 2 is reborn:-)
Unfortunately the flac stream couldn't be implemented in MoOde for some reason. But maybe Tim wants to put that on his to do list. With Archphile it's working- so it should be possible.
Greetingz, Robert
Old 21st October 2017, 09:52 AM   #10123
philrandal is offline philrandal  United Kingdom
Originally Posted by metalrob View Post
Thanx Phil!
Greetingz, Robert
The FLAC stream is playing via Moode as I type this., using the url I posted earlier.
No track info displayed, alas.
Phil
Pi Zero W + Pimoroni pHAT DAC / Pro-ject Elemental / Marantz CD6004 / Marantz PM6004 / Monitor Audio Bronze 2
Old 21st October 2017, 12:16 PM   #10124
Man in a van is offline Man in a van  United Kingdom
So it does, many thanks
Input Processing
Source: http://209.126.66.166:10999/flac
Encoded at: VBR compression
Decoded to: 16 bit, 192 kHz, Stereo
Rate: 6.144 mbps
Old 21st October 2017, 02:23 PM   #10125
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
The symptom "Sometimes it shows up..." suggests a network issue. To troubleshoot try the following:
1) Verify shairport-sync is actually running
pgrep -l shairport-sync
2) Verify that only a single adapter and ip address are operational
ip addr show eth0
ip addr show wlan0
-Tim
Enjoy the Music!
http://moodeaudio.org, http://twitter.com/MoodeAudio
Old 21st October 2017, 03:55 PM   #10126
JohnW is offline JohnW  Czech Republic
JohnW's Avatar
Sorry if these are rather basic questions but I'm really computer illiterate:-
1. Can Moode support direct CD playback via USB Drive - any drive limitations?
2. How do I add a custom WiFi driver to the system (I'm using CM3 module so using an external USB WiFi solution).
3. Is the HDMI output enabled and does this have any significant impact on operational speed - with HDMI "mode" can a USB keyboard / mouse be used as the user interface?
4. Can files be played from the Local memory?
Time is my worst enemy!
Old 21st October 2017, 03:56 PM   #10127
Phil
Sorry, Phil!
Didn't pay enough attention. JB Radio 2 FLAC also works:-)
Track information, if really needed, could be drawn by switching to mp3-version;-). So I placed them both together;-)
Greetingz, Robert
Old 21st October 2017, 04:05 PM   #10128
TimCurtis's Avatar
1. moOde does not support playback from USB CD drive.
2. you need to have good Linux skills to add drivers, etc
3. HDMI port is enabled but moOde is a headless music server thats designed to be accessed from another computer via a web Browser. There is no built in support for displaying moOde UI on a locally attached display however it can be done. User @morias posted a recipe in this thread for the 7" Pi Touch Display.
-Tim
Enjoy the Music!
Old 21st October 2017, 04:07 PM   #10129
TimCurtis's Avatar
Sorry, Phil!
Greetingz, Robert
Hi Robert,
Are these the two new URL's ?
http://184.75.223.178/proxy/sdsyygqt?mp=/mp3-320
-TIm
Enjoy the Music!
Old 21st October 2017, 04:12 PM   #10130
JohnW's Avatar
-Tim
Hi Tim,
OK thank you for your swift reply - shame about the lack of CD playback via CDROM drive.
I added a question after I posted - can Moode support playback form local Memory?
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 30th April 2017 12:10 AM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 08:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 07:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 06:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 04:38 AM
Copyright ©1999-2019 diyAudio
