PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 19th October 2017, 05:14 PM   #10101
NuGuy Audio is offline NuGuy Audio
Originally Posted by TimCurtis View Post
Do you mean "select internet radio" in LMS?
I assume u are running the Squeezelite renderer in moOde.
-Tim
Yes I am trying to open internet Radio stations in LMS. I also thought that moOde had it's own internet stations. How do I go about accessing these stations.
Yes I am running the Squeezelite renderer in moOde.
Old 19th October 2017, 06:13 PM   #10102
philrandal is offline philrandal  United Kingdom
JB Radio 2 has changed its 320kbps stream url to
http://184.75.223.178/proxy/sdsyygqt?mp=/mp3-320
Phil
Pi Zero W + Pimoroni pHAT DAC / Pro-ject Elemental / Marantz CD6004 / Marantz PM6004 / Monitor Audio Bronze 2
Old 19th October 2017, 06:25 PM   #10103
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
Dunno about the LMS issue but moOde's radio station feature is only accessible via moOde WebUI.
-Tim
Enjoy the Music!
http://moodeaudio.org, http://twitter.com/MoodeAudio
Old 19th October 2017, 06:26 PM   #10104
TimCurtis's Avatar
Phil
Hi Phil,
I'll add to the TODO list.
-Tim
Enjoy the Music!
Old 19th October 2017, 10:02 PM   #10105
Morias is offline Morias
Originally Posted by bifi View Post
I would like to modify the UI of my Moode 3.8.4 as shown in the attachment.
I use the official Raspberry Display and need a little bit more space.
So I would like to move the Play / Stop menu to the titlebar as on the browse and library page and hide the whole volume stuff because i dont't use the volume control.
But I have no clue in web programming.
Any hints ?
Michael
I change the zoom on my official rpi display and the standard interface fits fine. About 75% zoom works.
Old 20th October 2017, 07:34 AM   #10106
kaspersone is offline kaspersone  Denmark
Using moOde password protected on workplace WLAN's seems like a pretty narrow usage scenario so unless I get more requests for it, adding pwd protect would be up to user.
..snip....
see Tims guide in post #10023
Originally Posted by Zootalaws View Post
I think this resolves your problem: Shairport-sync Name * Issue #510 * mikebrady/shairport-sync * GitHub
But... I would like to have a password option, both for Moode config and for airport.
You can remove the link to the config pages by editing the link out of the main HTML page, but it would be nice if it was available as an option in the configure>general sub-page.
Maybe an option for ver.4.01?
Originally Posted by kaspersone View Post
... Thank you for the guide.
But yes workplace wlan is quite narrow. Thou I think the password option is not just for workplaces but also for other environments.
Thank you Tim & Zootalaws.
This was easier than I thought, and works like a charm.
For those of you running with raspotify as well, remember to disable discovery mode - if you fail to do this you'll eventually end up confused
Old 20th October 2017, 07:57 AM   #10107
bifi is offline bifi  Germany
I tried this first, but my eyes are old and my fingers fat
Old 20th October 2017, 03:06 PM   #10108
metalrob is offline metalrob
Hi Guys!
Have sadly recognized, that the wonderful JB Radio 2 isn't working anymore.
On Archphile I was able to implement 2 more streaming options for JB Radio 2, one of them a 16bit 192khz flac stream, that sounds excellent;-).
But with MoOde I'm not able to create the station playable.
The flac stream for JB Radio 2:
http://209.126.66.166:10999/flac.m3u
There is a still active mp3 320K channel existing-
but same as with the URL above- not playable after creating the station.
With Archphile both flac and mp3 versions are playing.
Maybe someone has an idea how to store both URL's successfully under 'Radio'
Thanx and greetingz
Robert
Old 20th October 2017, 03:23 PM   #10109
Originally Posted by metalrob View Post
Hi Guys!
Thanx and greetingz
Robert
See a few posts above for a working 320Kbps mp3 stream.
Try pasting the url in the flac.m3u into the Moode config for the station.
Phil
Old 20th October 2017, 03:26 PM   #10110
-Tim
Is the moOde web UI only accessible through a pc or can I use my andriod phone (Samsung) to access moOde via wifi. I have tried using my phone with both IP address and also name.local of the device but it has been a no go.
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 30th April 2017 12:10 AM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 08:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 07:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 06:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 04:38 AM
Copyright ©1999-2019 diyAudio
