PC Based Computer music servers, crossovers, and equalization
Moode Audio Player for Raspberry Pi
Old 14th October 2017, 11:58 AM   #10031
sinski is offline sinski
In the library and browse view there is a lot of place in the upper part. Is it possible to add volume control there ? I am browsing through my musik, choosing one album, starting to play it, than i have to change playback window to adjust volume. Sometimes i am missing the possibilyty to have all controls on one screen, like in LMS.
Old 14th October 2017, 12:00 PM   #10032
TimCurtis is offline TimCurtis  United States
TimCurtis's Avatar
Originally Posted by estshorter View Post
Hi, Tim
A horizontal scrollbar appears in the library view.
It doesn't in the browse and playback view.
Is it intentional?
I think it is useless as there is no sufficient room for the bar to move and it consumes
vertical space.
I checked it on chrome, firefox, IE and Edge browsers on Windows 10 in Japanese environment.
I only test with Safari and it has auto-hiding scrollbars. I never see a horizontal scrollbar.
On Chrome try: chrome://flags and enable overlay scrollbars. Also I think there is a way to save the Browser window as an App similar to "Add to Home Screen" on IOS. This gets rid of the Browser decorations.
-Tim
Enjoy the Music!
http://moodeaudio.org, http://twitter.com/MoodeAudio
Old 14th October 2017, 12:07 PM   #10033
TimCurtis's Avatar
Originally Posted by unn4m3d View Post
Hi Tim and community,
First of all thanks a ton for all the effort and work everyone puts into this project.
I propose adding another mount option via webinterface: SSHFS
Right now, I set it up myself via SSH. On long-term it would be great to integrate SSHFS mounts into the Web GUI.
My personal usecase is that I access my music collection stored on a dedicated server via Internet in more than one physical location (two appartements and office).
Therefore, for me SSHFS is a much better choice than SMB/CIFS or NFS.
I guess I might be not the only one who would appreciate this.
If I get more requests for it I'll add to the TODO list.
-Tim
Enjoy the Music!
Old 14th October 2017, 12:11 PM   #10034
TimCurtis's Avatar
Originally Posted by FSpretzel View Post
Hallo Tim and community
Is it possible to use the new Terry-Berry DAC 2 under MoOde 3.8.4 via the IS2 interface? If so, which audio device description must be taken?
Thank you.
Best regards
What I2S driver does the manufacturer specify for their DAC?
-Tim
Enjoy the Music!
Old 14th October 2017, 12:15 PM   #10035
TimCurtis's Avatar
Attachment 640156
I can have a look at maybe adding back the popup volume control that used to be included.
-Tim
Enjoy the Music!
Old 14th October 2017, 12:49 PM   #10036
-Tim
THX
Old 14th October 2017, 01:40 PM   #10037
unn4m3d is offline unn4m3d
-Tim
Great, thanks for the quick answer.
I am curious if I am the only one who is missing this feature.
Old 14th October 2017, 02:25 PM   #10038
Zootalaws is offline Zootalaws  New Zealand
-Tim
All docs are in Japanese, but volumio blokes reckon mamboberry works.
Old 14th October 2017, 05:47 PM   #10039
rpiaudiox is offline rpiaudiox
Hi Tim,
First of all, thanks for your great work!
I am thinking upgrading my old HifiBerry DAC and getting a AUDIOPHONICS I-Sabre DAC ES9028Q2M, but I can┤t find the AUDIOPHONICS ES9028Q2M DAC in I2S audio device list in Moode.
┐Will it work?, ┐or a special driver will be needed?
Thanks.
Old 14th October 2017, 07:38 PM   #10040
kaspersone is offline kaspersone  Denmark
Using moOde password protected on workplace WLAN's seems like a pretty narrow usage scenario so unless I get more requests for it, adding pwd protect would be up to user.
Below is a simple recipe if u want to pwd protect the web root. As far as pwd protect Airplay just edit /usr/local/etc/shairport-sync.conf and uncomment the password param.
sudo sh -c "echo -n 'timcurtis:' >> /etc/nginx/.htpasswd"
sudo sh -c "openssl passwd -apr1 >> /etc/nginx/.htpasswd"
cat /etc/nginx/.htpasswd
sudo nano /etc/nginx/nginx.conf
Add the following two lines in the location block for the web root /
auth_basic "Restricted Content";
auth_basic_user_file /etc/nginx/.htpasswd;
location / {
root /var/www;
index index.html index.php;
try_files $uri $uri/ /coverart.php;
sudo systemctl restart nginx
-Tim
Seems doable even for a noob like me. Thank you for the guide.
But yes workplace wlan is quite narrow. Thou I think the password option is not just for workplaces but also for other environments.
Looking forward for the new iteration of Moode
Moode Audio Player for Raspberry PiHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 30th April 2017 12:10 AM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 08:29 AM
Raspberry Pi + CirrusLogic Audio Card = FAIL solderhead PC Based 31 26th January 2016 07:48 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 06:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 04:38 AM
Copyright ©1999-2019 diyAudio
