PC Based Computer music servers, crossovers, and equalization
Archphile - An Archlinux Based Audiophile Distribution for Raspberry Pi and Udoo Quad
Old 7th September 2018, 07:02 PM   #271
DomieMic65 is offline DomieMic65  Greece
Originally Posted by Dave Bullet View Post
Please help this newbie. I boot my Pi with archphile and it looks to load ok. I am running an HDMI to my TV so can see the boot sequence. When complete, the hdmi drops so I presume archphile had dropped the tty and gone headless? If so I cannot see a DHCP allocation. To my Pi from either wireless router. Therefore I cannot ssh and configure. Any ideas please?
In p23 of the manual is the way to enable or disable hdmi.
Check if it is enabled.
You should be wired though ... wireless is disabled by default!
Old 8th September 2018, 09:19 AM   #272
Dave Bullet is offline Dave Bullet  New Zealand
Thanks man. I was being very lazy.
Hard wired = console
Left onboard wifi disabled (default)
Enabled wlan0 for USB dongle wifi (better antenna / gain for wifi access)
Set static IP on wifi
Using MPDDroid from android.
Alll working well!
"Usual diyaudio train wreck of dubious drivers and just the crossover to sort out. Well, how are you on crossovers and modelling? Pretty green, I reckon" - system7 (Steve)
Old 17th September 2018, 04:28 AM   #273
Alll working well!
You are welcome!
Glad it works for you now!
Old 18th September 2018, 12:33 PM   #274
freeplay is offline freeplay
Anyone using MPDeluxe or Soundirok for iOS? I'm unable to see any webradio playlist. But MPDroid on Android works fine.
Old 18th September 2018, 01:44 PM   #275
I'm using both and have the same problem.
I guess it has to do with iOS.
Don't know for sure though!
Old 19th September 2018, 04:32 AM   #276
I figured out a way... convert the .pls file to .m3u and upload to the playlist directory. Only problem if you have that many radio stations, then you have tons of playlists including your own local ones
Old 19th September 2018, 03:34 PM   #277
I can do with only the Android clients for the radio.. hehehe! The stations are many and I am not listening to radio that much.
Thank you any way...
Old 29th September 2018, 04:26 AM   #278
While thinkering with upnp for tidal, I came across the linn kazoo iOS app.
It exposes archphile mediaserver AND the radio stations!
Old 13th October 2018, 04:07 AM   #279
Does anyone know if alsa-equal (Equalizer) works (not necessarily supported) on v0.99.73? Has it been removed from the playground repo?
Old 13th October 2018, 07:47 AM   #280
Thank you!
I just saw your reply ..
Kazoo installed and I will test it as soon as I get back home!
Archphile - An Archlinux Based Audiophile Distribution for Raspberry Pi and Udoo QuadHide this!Advertise here!
My DAC for the Raspberry Pi usul27 Digital Line Level 156 29th April 2017 11:10 PM
DSP for the Raspberry Pi usul27 Digital Line Level 39 30th August 2016 07:29 AM
To Raspberry Pi/BeagleBone Black/CuBox/UDOO owners: RuneAudio is looking for testers ACX PC Based 173 10th November 2015 06:44 PM
RaspyFi/Volumio - Turn raspberry Pi into Audiophile audio Player mikelangeloz PC Based 295 14th June 2014 05:32 PM
miniAMP and raspberry pi kp93300 miniDSP 0 3rd March 2014 03:38 AM
