PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Thread Tools
Old 20th February 2021, 07:53 AM   #4291
Rallyfinnen is offline Rallyfinnen  Sweden
Just my general experiences form the last couple of days:
I tried with a couple of sound cards/dac's, and they were all supported:
Focusrite Scalett solo G3
SMSL Sanskrit
Asus Xonar X7(?)
Cambridge Audio (small USB interface)
Some Chinese usb DAC, can't remember the name.
I tried it on several laptops, and one was 32bit, so I had to download the other iso file. The other thing I had a problem with was the wifi adapter on one, but after running it via cable, it seemed to download a driver(?), and it started working after that.
Also an issue can be that some wifi adapters don't work as hot-spots, so I needed a cable to connect the first time. For some reason I never for any of them to connect to my wifi when starting from the USB setup drive. I always had to search for the wifi in Settings first, and then connect to it.
Old 22nd February 2021, 06:02 PM   #4292
patagonia is offline patagonia
Just to inform a discovery (at least for me hehe) with spoty plugin you use Daphile with Spotify Connect, I have a small lag but only on first connecting then normal. Find useful as operating the Spotify interfase is better than Daphile one.
Old 23rd February 2021, 08:07 AM   #4293
brauner is offline brauner
Default Daphile act as DHCP Server
Hello,
After power down, my Daphile device wake up before the router, and it looks like that Daphile became DHCP server and start giving IP addresses (192.168.128.x) to other devices in the net.
Is there a way to disable Daphile to act as DHCP server?
-Roei
Old 23rd February 2021, 11:22 AM   #4294
Originally Posted by brauner View Post
Hello,
-Roei
You could disable the hotspot in the network tap
Old 26th February 2021, 09:30 PM   #4295
JC552 is offline JC552
Default DSD Settings
What are the correct Daphile settings for playing DSD files? I just did fresh installs of version 21.01 for both 64 Bit and RT. Prior to the update when I played DSD (DSF or DFF) files on either version of Daphile the display on my DAC would indicate "DSD" and I believe it showed a sample rate of "1". After the new install it shows PCM and 44. The DAC is an EVO DAC 2 and it handles native DSD.
Old 27th February 2021, 10:47 AM   #4296
chfaure is offline chfaure  France
If your dac support native DSD go the device section of your connected DAC.
On DSD support use the dropdown list and
select Native DSD bitstream.
If it is not working you can also try
DSD over PCM (DOP).
This should work !
Old 27th February 2021, 12:45 PM   #4297
Thanks chfaure. I'll try DoP, but I'm sure I didn't use it in the past. I think I'll also see if I can go back to an older ISO.
If anyone else thinks they know why I'm not getting DSD to the DAC, please let me know.
Old 28th February 2021, 02:51 PM   #4298
rrodrigo is offline rrodrigo
Originally Posted by Nickolay V View Post
Hi !
Can anybody tell me how to install Roon Bridge on DAPHILE ?
Could someone please help? I would be very interested in that too
Old 3rd March 2021, 06:40 AM   #4299
markm9999 is offline markm9999  United States
Originally Posted by DosenZorn View Post
Since I didn't get any reactions I would like to ask again. Did anyone tried something similar, like writing a like program to support arduino/TFT screen interaction? I don't have any trouble to write arduino programs and set the circuit up to simulate a PC Keyboard with it.
So on Daphile I'm also able to use these simulated keyboard commands on the shortcuts settings to play/pause etc.
What I'd like to do additionally is to show the currently playing Songtitle on the screen. Therefore I'd like to write a python programme which I'm able to convert into an .exe type.
I'm also able to send information via serial connection to my arduino. What I'm not able yet is to read currently playing song metadata in python and auto run .exe files on daphile OS.
Does anyone have some tips on how to do this?
Thanks in advance again
- DosenZorn
Rather than focusing on Daphile, you may want to look into Logitech Media Server (LMS) itself.
Daphile is just repackaging LMS this along with an OS and it's own awesome tweaks.
You can see that here https://daphile.com/firmware/stable/CHANGES
I believe LMS has REST API's or you might be able to use CLI/Telnet commands.
I highly suggest you visit the LMS forums, look around & ask questions.
Squeezebox : Community : Forums
Old 3rd March 2021, 07:16 AM   #4300
phofman is offline phofman  Czech Republic
The DSD format is not officially handled by the USB-audio specs and audio devices cannot report its capability in a standard way. As a result USB IDs of devices known to support DSD are hard-coded in the linux USB-audio driver, in method linux/quirks.c at master * torvalds/linux * GitHub . If your device USB IDs are not handled by the method yet, it must be reported to the alsa-devel mailing list so that they are added to the kernel driver.
It will take a while (several months minimum) for the change to propagate into the new kernel release and for daphile to pick the new kernel.
Daphile - Audiophile Music Server & Player OSHide this!Advertise here!
Thread Tools
My Music Server ppastudio PC Based 7 3rd March 2012 10:42 PM
Music Server croccodillo PC Based 10 5th April 2011 12:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 01:41 PM
Music Server JC951t Digital Source 6 6th August 2008 06:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 01:12 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
