PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Thread Tools
Old 19th February 2021, 07:54 AM   #4281
DRONE7 is offline DRONE7  New Zealand
Yes Pavel !, those of us who have conquered it would agree "a few minutes" but to a newcomer let us manage expectations and say perhaps 'an hour or two' :-)
Old 19th February 2021, 08:45 AM   #4282
jayce996 is offline jayce996
I've an EMOTIVA XMC2 connected via USB to a Daphile NUC i3, it works well except when i try to play DSD or want to apply any resampling option such as BruteFIR.
I did not find any complain on EMOTIVA Forum regarding DSD
Can anyone tell me if this is related to the NUC or the PRE/PRO?
Old 19th February 2021, 11:00 AM   #4283
phofman is offline phofman  Czech Republic
Learning how to copy OS image onto a flash drive, how to configure bios to boot from usb etc. does not seem a bad investment of time.
Old 19th February 2021, 11:20 AM   #4284
duplex is offline duplex  Germany
My Daphile is on a Celeron based Mini-PC, connected via USB to a Rotel RC-1570 Preamp (pure stereo).
BruteFIR works smoothlessly, while DSD playback is the only feature I could not get to work properly. The Rotel itself can't process DSD, so Daphile should convert to PCM, but no setting I tried did work.
My current workaround is converting DSD files to 88.2 PCM FLAC, which works fine and hardly costs more than a minute per album. So there's not much pressure to find a solution on this issue.
Rotel RC-1570, Quad 303 (mod), Tannoy Definition D500 (mod), dedicated Daphile server, homemade no-nonsense cable work, BruteFIR room correction. Measuring: Behringer ECM8000, Steinberg UR12, Room EQ Wizard.
Old 19th February 2021, 12:09 PM   #4285
thyristor44 is offline thyristor44
On a different subject @phofman.
You once gave me a link to a TPA3116 amp that could be modified for balanced input for noise. Have you seen any of the current ones that could be modded, I can't find one, or your mod, although I do remember how to do the mod.
thyristor44
Old 19th February 2021, 12:45 PM   #4286
DosenZorn is offline DosenZorn
Originally Posted by DosenZorn View Post
Hello,
I hope someone is able to Help me. Is there and possibility to run an .exe or .py program on auto start from Daphile? I wanted to connect an Arduino with TFT Screen as HID. Also is there any way to read the metadata of the currently playing song with python or similar. Has someone else already tried this?
Thanks in advance and with best regards
DosenZorn
Since I didn't get any reactions I would like to ask again. Did anyone tried something similar, like writing a like program to support arduino/TFT screen interaction? I don't have any trouble to write arduino programs and set the circuit up to simulate a PC Keyboard with it.
So on Daphile I'm also able to use these simulated keyboard commands on the shortcuts settings to play/pause etc.
What I'd like to do additionally is to show the currently playing Songtitle on the screen. Therefore I'd like to write a python programme which I'm able to convert into an .exe type.
I'm also able to send information via serial connection to my arduino. What I'm not able yet is to read currently playing song metadata in python and auto run .exe files on daphile OS.
Does anyone have some tips on how to do this?
Thanks in advance again
- DosenZorn
Old 19th February 2021, 02:35 PM   #4287
You would have to modify the daphile filesystem quite a lot is not easy to do (based on squashfs) and actively supported by daphile author.
Old 19th February 2021, 02:39 PM   #4288
Adding an Amp into Thin-Client PC
These amps are discussed in detail in this huge thread TPA3116D2 Amp . I try to keep an eye on it, IMO the most recommended board currently is TPA3116D2 Amp . Since it has all four input caps in THT make, it should be trivial to convert the board to balanced input.
Old 19th February 2021, 07:57 PM   #4289
Thanks a lot phofman that gives me plenty of information for another system. The original one I modified on your advise is in use all the time.
Thanks again.
Old 20th February 2021, 06:06 AM   #4290
I am glad that simple hack works you.
Daphile - Audiophile Music Server & Player OSHide this!Advertise here!
Thread Tools
My Music Server ppastudio PC Based 7 3rd March 2012 10:42 PM
Music Server croccodillo PC Based 10 5th April 2011 12:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 01:41 PM
Music Server JC951t Digital Source 6 6th August 2008 06:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 01:12 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
