PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Thread Tools
Old 23rd January 2021, 05:20 PM   #4191
Crunch1234 is offline Crunch1234
Originally Posted by phofman View Post
In some cases I had to disable IPv6 support in linux ntb wifi settings to connect to networks which offered both IPv4 and IPv6. Perhaps this could be the same reason - the new router is likely supporting both IP versions.
I have no idea how to get into a terminal to begin even, it just hangs up on that connecting stage. Also, I do have an ethernet cable (plugged into a usb adapter) that ubuntu picks up, no need to even go to Wifi. (Though that doesn't work either, same screen)
Old 23rd January 2021, 05:59 PM   #4192
Marcel65 is offline Marcel65  Netherlands
for me this last version is a winner now it works, somehow CPU temps seem lower and my system does not freeze every couple of hours anymore
Old 24th January 2021, 02:47 PM   #4193
Bonzo74 is offline Bonzo74
Originally Posted by hifimandan View Post
Have you checked your streaming settings in tidal settings actually in Daphile?
You can set your account type in there I think, or set the max bit rate you want to use, my Meridian explorer2 dac works with Tidal MQA via Daphile
Hi, sorry but I don't understand where and what I have to check.
Do you mean that inside the Tidal app, inside Daphile I can chose the account type and the max streaming bitrate?
Thank you
Old 24th January 2021, 03:02 PM   #4194
Hi all,
I'm using Daphile and I'm satisfied, but yesterday I have found a strange behavior.
On my NAS I had an MP3 version of an album that I replace with the same album on FLAC format.
When I started the Daphile PC, Daphile show me correctly the FLAC version that I can play, but show me also the MP3 album version.
When I go inside a song of the MP3 version I can't see, obviously, the sampling rate and I can't play the song.
When Daphile starts check the song/album database for new added files, but I have the doubt that in order to eliminate the MP3 album version I need to tell Daphile to rescan all the library and not only changes.
Obviously this is boring if the library is big.
Someone has encountered the same problem?
Many thanks
Old 24th January 2021, 03:15 PM   #4195
Sangram is offline Sangram  India
Sangram's Avatar
Typically you would rescan everything if you removed files, and scan for changes if you only added files. This is part of the core LMS logic.
Old 24th January 2021, 03:21 PM   #4196
So my doubt was legitimate!
Now I try to rescan.
Thank you
Old 25th January 2021, 08:16 PM   #4197
chfaure is offline chfaure  France
Are you connected using cable or with wifi ?
If it is using WiFi, try with cable...
It it was with cable, does your subnet changed ? (i.e 192.168.1.xxx to 10.10.z.z) and used fix address instead of dhcp this can explain why you cannot have any internet connection.
Normally when you boot in linux you should have console using function key.. and then try to change values to get dhcp working.(you should be able to connect with same user/password as ssh connection)
Old 26th January 2021, 01:18 AM   #4198
joshua43214 is offline joshua43214
Daphile was working great until today when the new modem / router combo came from my ISP (Shaw "bluecurve" 1gbit).. Now I get the "waiting for internet connection" message at the start that sits there forever... Tried re-installing both the stable and nightly build, same message. I boot daphile of the USB, and UBuntu off my hardisk, and ubuntu is working ok with the new equipment.
How do I even troubleshoot this, I can't connect to the old url I had for the player, it seems to not be connected as it says.
Look for a label on your router, it should have an IP address (something like 192.162.x.x) and a password.
Open a browser, and type in the IP address, enter the password (and please change it so your neighbors don't borrow your wifi to download kiddi porn!).
You should get an interface that allows you to monitor and edit your router/switch settings. Hopefully the home page will have a list of all devices that are registered to your router, and which ones are active, inactive, or blocked.
All I can suggest at this point is to experiment with settings until you get it working. It is possible the router is firewalling either Daphile or your cable adapter. Do you have to use a USB adapter?
As for how to open a command window in Windows, simply open any folder and type "cmd" into the address bar with out quotes and you get a command window. you can ssh into a remote computer from there if you want. Or you can do winkey + x and select a command prompt from there.
Old 26th January 2021, 04:32 AM   #4199
ttan98 is offline ttan98  Australia
I own and operate a Daphile system I am quite happy with it, I can access Spotify and Youtube as paid services. On Daphile I was able to access Spotify not a problem there, however, I find it very difficult to access Youtube from Daphile, twice without success. Can Daphile access Youtube Music as a streaming website? I suppose not.
For those out there the Sound reproduction from Youtube Music is so much better than Spofify.
Old 26th January 2021, 08:11 AM   #4200
using the Youtube plugin is explained in Daphile, in short; 'it's a nuisance'. I agree that YT sound quality is not that bad, Spotify sounds far too plasticky even at it's highest settings.
Daphile - Audiophile Music Server & Player OSHide this!Advertise here!
Thread Tools
My Music Server ppastudio PC Based 7 3rd March 2012 10:42 PM
Music Server croccodillo PC Based 10 5th April 2011 12:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 01:41 PM
Music Server JC951t Digital Source 6 6th August 2008 06:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 01:12 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
