PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Thread Tools
Old 18th January 2021, 07:50 PM   #4171
Marcel65 is offline Marcel65  Netherlands
and again booting fails, it may have to do with Qobuz plugin as it is reporting incorrect username and login twice after booting the latest version and then the previous version boots. Have deactivated qobuz plugin and will try again a couple of times.
Old 19th January 2021, 10:09 AM   #4172
Lionel is offline Lionel  France
Where can i find the option to shut down a player without shutdown daphile totaly
See attached image (not sure this is what you are looking for).
Old 19th January 2021, 12:24 PM   #4173
chfaure is offline chfaure  France
Lightbulb device list
Originally Posted by soef View Post
Where can i find the option to shut down a player without shutdown daphile totaly.
You should go to the device list bottom right of the AudioPlayer page
You can attach devices to Daphile server and you should have an over "button" to turn off player. This is only valid to attached devices !
See following picture:
Click the image to open in full size.Click the image to open in full size.
Old 21st January 2021, 08:03 PM   #4174
mr-mac is offline mr-mac  Scotland
I an using OMV and have tried everything and can’t get smb or nfs to connect from daphile to openmediavault server.
Anyone got any ideas what I can try?
Old 21st January 2021, 09:53 PM   #4175
DRONE7 is offline DRONE7  New Zealand
@mrMac... you've not told us much about your setup so here goes with plenty of guesses and assumptions....
1)assuming you're using samba.
2) in the Daphile storage tab first select any previous attempts you have made trying to setup OMV acces, delete (remove entry) them, then reboot and return to the storage tab.
3) Select 'Add New' and choose cifs
then enter your username for the OMV samba account,the OMV server name, and the folder that you have selected to serve.
would look something like this..
cifs://Mac@MyOMV.local/Music
replace Mac MyOMV and Music with your own.
Reboot and see that you get the green tick.. :-)
Big assumption is that you know your way around OMV and have it set up and tested connecting to other clients ?
Old 21st January 2021, 10:07 PM   #4176
Tried smb and nfs.
Admittedly never had .local in the name and even the daphile setup didnít say to have that populated.
Will try that tomorrow
Old 21st January 2021, 10:10 PM   #4177
if OMV.local does not work then use the ip address of the OMV server instead...
something like..
cifs://Mac@192.168.1.xxx/Music
Old 21st January 2021, 10:11 PM   #4178
Windows can see the shared drives and I can also see the drive I set up for my name but didn’t manage to get logged in as the music account (one I plan to use for daphile) but assume it was just way I configured it as could see mine and my other half’s fine and got the r/W access for each of us in drives I was supposed to.
Music was set up identically to my share account and other half’s so can’t think it’s wrong, made a folder, made a user shared folder and gave the users r/W and checked it in the permissions tab.
Like I say will try with the .local in place tomorrow and maybe then on smb logging on omv see if says anything useful in log if doesnt connect.
Old 21st January 2021, 10:14 PM   #4179
So assume CIFS://Music@HOMESS.local/Music
I did already try Music@192.168.0.15/Music and it just stayed with a red x on daphile screen.
Have deleted all nfs and smb setups so will try again with private switched so guest will work r/W turned on and see if works without user info.
Then can see where I go from there.
Old 22nd January 2021, 05:39 AM   #4180
@mr-mac...
I would have this sorted and working before trying to configure Daphile....
Daphile - Audiophile Music Server & Player OSHide this!Advertise here!
Thread Tools
My Music Server ppastudio PC Based 7 3rd March 2012 10:42 PM
Music Server croccodillo PC Based 10 5th April 2011 12:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 01:41 PM
Music Server JC951t Digital Source 6 6th August 2008 06:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 01:12 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
