PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Thread Tools
Old 3rd December 2020, 08:40 AM   #4091
Marcel65 is offline Marcel65  Netherlands
HI there,
Thanks for your support!
The device is selected and showing in the lower right corner, in my experience so far if the device does not work or is not installed tracks do not play.
I just checked, everything is working perfectly with my previous setup; NUC connected via USB to singxer SU1 connected via HDMI to a LVDS to RJ45 convertor into the Metrum RJ45.
triplechecked the ethernet cables and those are fine too.
See attached screenshots of my settings
Old 3rd December 2020, 12:58 PM   #4092
connecting the SU1 bridge via USB and selecting that shows Daphile is working, I get sound immediately.
Old 3rd December 2020, 02:39 PM   #4093
East Sea is offline East Sea
Originally Posted by DRONE7 View Post
The audio device is shown in the settings page. As are ,probably, other devices ?
On the player page, bottom right, is the device you want to use selected in the drop down ?
Here is the bottom right:
Old 3rd December 2020, 02:42 PM   #4094
yes the HEA bridge is showing there too, it's showing as CMI8888
Old 4th December 2020, 10:14 AM   #4095
am going to try W7 to see if it is related to the OS or the CPU/MB
Old 4th December 2020, 08:11 PM   #4096
bridge is working under W10Pro, so it's definitely a Daphile/Linux problem
Old 4th December 2020, 11:47 PM   #4097
DRONE7 is offline DRONE7  New Zealand
What player are you using in Win ? LMS ?
May not be a Daphile/Linux problem but an LMS one.
Check in Daphile> Settings>Advanced Media Server Settings>Plugins>Third Party Plugins. and see if there is anything pertinent.
Old 5th December 2020, 05:11 AM   #4098
Thank you @DRONE7. After many changes of Daphile Settings (rt, non-beta) and also Jriver27, at the end they work! Here are the Dap. settings:
File Type: jpg Screenshot_20201205-115945_Gallery.jpg (361.3 KB, 139 views)
Old 5th December 2020, 11:43 AM   #4099
joshua43214 is offline joshua43214
Originally Posted by Triplefun View Post
For those who are interested I have finally got the new machine running thanks to the help of Kipeta - father of daphile. The sound is magnificent and a big improvement on my i5 9400. Sound is noticeably clearer across all frequencues. I find I can upsample dsd256 to dsd512 with 17 (?) threads and NO stuttering. Memory peaks at 5gb
Pcm is also improved although I still prefer DSD upsampling.
Also if anyone is looking to build a new computer I strongly suggest you look at the amd zen 3 range of CPUs. A noticeable improvement on intel. It will be interesting to see the hqplayer comments
Would you mind sharing the details of the build?
Thanks,
-Josh
Old 6th December 2020, 12:10 PM   #4100
AMD zen 3 has a wide choice of CPU's with a broad range of prices
Daphile - Audiophile Music Server & Player OSHide this!Advertise here!
Thread Tools
My Music Server ppastudio PC Based 7 3rd March 2012 11:42 PM
Music Server croccodillo PC Based 10 5th April 2011 01:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 02:41 PM
Music Server JC951t Digital Source 6 6th August 2008 07:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 02:12 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
