Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
PC Based Computer music servers, crossovers, and equalization |
Thread Tools |
#4081 |
I return to say that I have solved the problem.
It was my mistake, I was trying to connect to the Daphile via WI-FI, after connecting it with a network cable the page worked and I installed the beta version. now it works fine, thanks a lot. |
#4082 |
Hi All.
Daphile can connect to Jriver via Upnp/Dnla Bridge, but not stable. How to solve? Thank you. |
#4083 | ||
Devices..? Pwr supply..? Version..?? Error messages ..?? Are you using a Daphile Beta version with ssh and command line output ?? Code:
top |
#4084 |
@DRONE7:
No debugging info. Daphile (rt latest version) on Laptop and Jriver27 (shared key) on fanless Nuc. At first, Daphile's output to Jriver well, then (15-20 minutes) no sound, while Daphile still displays Jriver as Player, I can change song from Daphile then song's name in Jriver changed respectively, but no sound (and seems no playing on Jriver). Daphile keeps working normally. Without UPnP Daphile, Jriver does well too. Thank you so much. p/s: ... command line output ?? No |
#4085 | |
You may need to run the Beta for that...
https://www.daphile.com/download/FAQ.txt Quote:
#4086 |
Thanks a lot @DRONE7. I'll try.
#4087 |
Hi DRONE7, I've tried 20.11 Version (b101707) and installed with the same way as other previous versions, but no any sound! However, Jriver imports and plays music in Hard disk attached to Daphile laptop (flac and dsd only, others types converted to *.l16 and could not be played)
I did not use root password (and don't know how). Many thanks. |
#4088 |
My system is a NUC, Pentium, 8Gb RAM, Pink Faun HEA I2S bridge to a Metrum DAC, using RJ45 ethernet cable for I2S. Ethernet cable tested and working.
Daphile running latest beta version, it runs, detects the correct audio device yet no data flow to the DAC and therefore no sound. My DAC works, I just disconnected the other I2S feed but seem unable to get this one working. The I2S bridge is connected via the M.2 slot, and is detected by Daphile, tracks are playing. Anyone who knows more about this setup, is there a mute button/toggle somewhere? Mixer settings: all ticked on, using just front, all switched off, makes no difference. Anyone here with a hint? Last edited by Marcel65; 2nd December 2020 at 11:00 PM. |
#4089 |
The audio device is shown in the settings page. As are ,probably, other devices ?
On the player page, bottom right, is the device you want to use selected in the drop down ? |
#4090 |
FYI. Many thanks
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
My Music Server | ppastudio | PC Based | 7 | 3rd March 2012 10:42 PM |
Music Server | croccodillo | PC Based | 10 | 5th April 2011 12:56 PM |
Music Server and PC based XO & EQ | otto88 | Multi-Way | 10 | 19th May 2010 01:41 PM |
Music Server | JC951t | Digital Source | 6 | 6th August 2008 06:47 AM |
SoCal Audiophile & Music Expo Nov 19-20th | Apex Jr | Everything Else | 3 | 21st November 2005 01:12 AM |
New To Site? | Need Help? |
