PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Daphile - Audiophile Music Server & Player OS Please consider donating to help us continue to serve you.
Old 22nd October 2019, 02:56 AM   #3621
Rudy81 is offline Rudy81  United States
Rudy81's Avatar
Problem solved it seems after beating my head against the wall for several hours.
Here is how I managed to fix the problem.
Problem:
1TB SSD drive that housed my .flac files in my HTPC running Windows 10 worked fine with Daphile as a 'Read' only drive. However, I could NOT change the drive to 'RW' so I could add or modify files through Daphile or via the network. I tried both firmwares and did several installs. Nothing worked.
SSD drive had been formatted by Windows10 in ntfs.
Solution:
It occurred to me after a while that maybe, Daphile was trying to change the permissions, but the drive file system somehow was preventing the change. I removed the drive and connected it to Windows 10. Under "properties", I noticed that the Security tab showed that "Users" did NOT have full control of the drive. Just System and Administrator.
I set all the user names to full control and full access. Windows 10 then changed all the permissions of all the folders in the entire drive.
Re-installed in Daphile machine and it now works as it should. The drive has a 'lock' on the actual drive name, but the individual folders are all accessible!!!!
Old 22nd October 2019, 08:46 AM   #3622
Tromperie is offline Tromperie  Australia
Yes, NTFS introduces a set of problems. Well sorted.
Source: LMS 7.9.2 on FreeNAS, PiCorePlayer * Storage: FreeNAS 11 * DIY PGA2310 * Amps: 8 x LM3886TF
Xover: 24dB @ 300 and 3kHz * Speakers: CNC cut 54 laminations * SB 10", SB 5", VIFA 1" * Remote: Squeeze Control
Old 22nd October 2019, 02:48 PM   #3623
Rudy81's Avatar
Are you aware of any guides specifying the various settings in Daphile? I have looked a the FAQ and no real explanation on the settings.
My last issue right now is that I cannot get digital music sent via my HDMI to my pre/pro DAC. HDMI worked on windows and Daphile does identify HDMI as device HDMI 0 [hw:1,3]. Is this a driver issue?
Thank you for your help.
Old 22nd October 2019, 09:44 PM   #3624
Sorry, but I can't help you there.
Old 25th October 2019, 05:19 AM   #3625
rickywwk is offline rickywwk
Hi all, I'm using Onda oBook 11.6. The mother board is Intel Cherry X5 with Broadcom network card. However when using the USB drive to boot and first time init connect to WIFI, it always show "Waiting for network connection". When I use the HP notebook, it works. Any idea ? Thanks.
Old 26th October 2019, 01:01 AM   #3626
DRONE7 is offline DRONE7  New Zealand
Daphile does not have support for every network/wi-fi card...your Broadcom is apparently one that is not.
Try using a usb wifi adapter..
Search this thread as several have posted their working adapters.
Here are some I have tried...
Others report these...
Old 27th October 2019, 05:01 PM   #3627
tthorsten is offline tthorsten  Germany
how ist ist possible to have
spotify
soundcloud
youtube
lastfm
and so on on daphile ???
Old 27th October 2019, 08:08 PM   #3628
spotify
soundcloud
youtube
lastfm
Go to Advanced Settings, install the plugins, and, if needed, follow the instructions to configure.
Old 28th October 2019, 09:14 AM   #3629
thanks
Old 18th November 2019, 09:47 AM   #3630
jigarpatel is offline jigarpatel
I already have installed Daphile 19.01 64-bit x86.
Is it possible to upgrade it to real time kernel or I have to do fresh install ?
Daphile - Audiophile Music Server & Player OSHide this!Advertise here!
My Music Server ppastudio PC Based 7 3rd March 2012 11:42 PM
Music Server croccodillo PC Based 10 5th April 2011 01:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 02:41 PM
Music Server JC951t Digital Source 6 6th August 2008 07:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 02:12 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
