PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Old 17th May 2019, 11:30 AM   #3491
phofman is offline phofman  Czech Republic
"with firmware 2.21.126 or lower"
vs. WDMyCloud < 2.30.165 - Multiple Vulnerabilities
IMO this whole device is worth extracting the drive inside and building a simple NAS with FreeNAS or linux.
Old 17th May 2019, 11:35 AM   #3492
Triplefun is offline Triplefun  New Zealand
Agreed. I believe the internal drive of the 8tb device is actually a wed red helium drive. You need to be wary of the sata power connector to get it to work. Best to use a molex to sata power adapter.
I listen, therefore I am !
Old 17th May 2019, 05:40 PM   #3493
Mr Trev is offline Mr Trev
I've been using a 1st. Gen model for a few years now and it's been mostly decent. It's running the 4.xx firmware so those vulnerabilites are a non-issue. My biggest complaint is it doesn't have NFS OOTB. Apparently NFS can be added through some SSH work, but that's outside my skillset. Setting up for SMB was easy enough in Daphile, but the transfer speeds seem to be lacking compared to Windows. I haven't tried FTP or SSH connections to see if its any quicker.
Old 19th May 2019, 03:11 PM   #3494
SRMcGee is offline SRMcGee  United States
SRMcGee's Avatar
Daphile - Audiophile Music Server &amp; Player OS
Folks:
I am poised to add a second SSD to my server. Are there any rules regarding naming conventions for a second local drive? In other words, should it have the same “Identification” name as the first drive, or is there anything else that I need to do to enable both SSDs to work properly together?
Scott
Good decisions come from experience. Experience comes from making bad decisions. (Mark Twain)
also, Everyone has a plan, till they get punched in the mouth. (Mike Tyson)
Old 19th May 2019, 05:05 PM   #3495
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Need to give second storage device a distinct name. 1st and 2nd drive will not be seen as one drive unless they are spanned at OS level.
However I think daphile will see it as one library.
I build, therefore I am.
Do not create problems where there are none.
Old 19th May 2019, 05:21 PM   #3496
SRMcGee's Avatar
Vince:
Thanks, as always. Having made as many mistakes as I have in the past, I'm trying to now operate with an over-abundance of caution.
It's upgrade time!
Scott
Old 20th May 2019, 12:12 AM   #3497
Tromperie is offline Tromperie  Australia
I couldn't find anything, but I would partition the whole drive as EXT4 as file ID as sdb2, install it in the box and see how it goes.
Source: LMS 7.9.2 on FreeNAS, PiCorePlayer * Storage: FreeNAS 11 * DIY PGA2310 * Amps: 8 x LM3886TF
Xover: 24dB @ 300 and 3kHz * Speakers: CNC cut 54 laminations * SB 10", SB 5", VIFA 1" * Remote: Squeeze Control
Old 20th May 2019, 07:09 AM   #3498
ttan98 is online now ttan98  Australia
H,
I am registered to Spotify, 1st time I registered on the Spotify from Daphile it worked quite well, I was able to do music track search and displaced the tracks or albums, no problems there.
After logging off and sign on again I could NOT do any searching. Nothing displayed from the searching function, or what's new. However, I can still play(intermittently stops sometimes) from my playlist that has tracks from Spotify, what's wrong?
Even a restart does not help. Cannot do any searching or displace anything from Spotify.
Old 20th May 2019, 07:47 AM   #3499
Originally Posted by ttan98 View Post
H,
It works now..no respond is reqd.
Old 20th May 2019, 01:34 PM   #3500
MSHAVS is offline MSHAVS  Netherlands
Default Spotty 2.8.x (Spotify Connect for LMS)
For future use: please follow this thread: [Announce] Spotty 2.8.x - Spotify Connect for your Squeezebox
Michel Herger is the developer of Spotty
Daphile - Audiophile Music Server &amp; Player OSHide this!Advertise here!
My Music Server ppastudio PC Based 7 3rd March 2012 11:42 PM
Music Server croccodillo PC Based 10 5th April 2011 01:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 02:41 PM
Music Server JC951t Digital Source 6 6th August 2008 07:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 02:12 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
