PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Old 9th May 2019, 04:17 PM   #3481
anadigi is offline anadigi  Canada
Originally Posted by hellrider77 View Post
Well. I can install it in LMS but cannot be used as LMS server settings page is also heavily modified so I cannot select the material skin.
I have use the material skin on Daphile since the first release! It should work!
Old 9th May 2019, 04:46 PM   #3482
hellrider77 is offline hellrider77  Romania
It actually works. I just had to access the default LMS skin at daphileip:9000 and get to LMS server settings from there. Select material skin. I have to access daphile via 9000 port. Added the web app to homescreen. That's it. Much sleeker than daphile webui.
Old 14th May 2019, 02:17 AM   #3483
Nickolay V is offline Nickolay V  Russian Federation
Hi !
Can anybody tell me how to install Roon Bridge on DAPHILE ?
Old 14th May 2019, 11:29 AM   #3484
Tromperie is offline Tromperie  Australia
Maybe so, but doesn't have the same functionality.
Source: LMS 7.9.2 on FreeNAS, PiCorePlayer * Storage: FreeNAS 11 * DIY PGA2310 * Amps: 8 x LM3886TF
Xover: 24dB @ 300 and 3kHz * Speakers: CNC cut 54 laminations * SB 10", SB 5", VIFA 1" * Remote: Squeeze Control
Old 15th May 2019, 01:17 AM   #3485
DRONE7 is offline DRONE7  New Zealand
Agreed... and that's possibly because it is aimed at mobile device use cases rather than administering LMS from a conventional PC desktop.
Horses for courses.
Old 15th May 2019, 09:15 AM   #3486
dmigo is offline dmigo  Taiwan
Hi, I am a newbie to music streaming and networking scene.
After some hard works to setup a Daphile system, I used a cell phone as the remote to play music from a local usb drive last night. I was so excited and satisfied with the sound quality.
However, I run into a problem to catch my music files which are stored on WD My Cloud Home. WD My Cloud Home is a kind of personal cloud, not a NAS. I tried so hard to let Daphile to read form it, but it couldn’t.
I just wonder if it is possible to mount it as a network drive? And how to set the parameters?
Also I am thinking of another solution. Use LMS as the server on cell phone and the Daphile as a player. But, there seems no android version of LMS? Anyone can help me with? Thanks in advance.
Old 15th May 2019, 09:42 AM   #3487
phofman is online now phofman  Czech Republic
Well, WD My Cloud Home is a proprietary solution which does not use/offer data through standard network filesystem protocols. If offers the Public section via smb How to mount My cloud hone on Linux - NAS & Devices - Plex Forum , but that is not where most user data are. Unless WD writes some linux way to access the data (which it will not), a linux device cannot access it.
My recommendation is stop using this closed solution for your data and get a standard NAS instead if you like your data and want to use systems which WD has not bothered to let access to its proprietary "solution".
LMS on android would mean rewriting the whole multiplatform (perl) LMS code to the android dalvik (Java). IMO the way would be running LMS on windows which I would expect offers the WD MCH files somehow in form of virtual filesystem (directories, files) for other apps to use.
Again, do not get your data voluntarily (they even charged you ) locked-up into these short-lived proprietary closed technologies.
Old 15th May 2019, 10:07 AM   #3488
Horses for courses.
Correct. Material Skin is perfect used as a remote. Much better than squeezer or daphile webui when used on a small cellphone screen. For daphile settings or advanced server settings, daphile webui is perfect and still use it. Several skins can be used in parallel so no wories. I do not control daphile via desktop so I don't know which solution is better. Used solely as remote, I would still bet on material skin.
Old 15th May 2019, 11:33 AM   #3489
sangram is offline sangram  India
This device requires internet access and cannot be mapped like a traditional network drive.
This means that read/write speeds are limited to that of the internet connection, not the LAN on which the device is connected.
Daphile cannot access this device on the network, nor can any of the other traditional LAN access methods.
Old 17th May 2019, 11:15 AM   #3490
Triplefun is offline Triplefun  New Zealand
I haven't tried it but you can install a squeeze cwntre client on mycloud which should be accessible by daphile ?
How to install the SqueezeCenter App on a My Cloud with firmware 2.21.126 or lower
I listen, therefore I am !
Daphile - Audiophile Music Server & Player OSHide this!Advertise here!
My Music Server ppastudio PC Based 7 3rd March 2012 11:42 PM
Music Server croccodillo PC Based 10 5th April 2011 01:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 02:41 PM
Music Server JC951t Digital Source 6 6th August 2008 07:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 02:12 AM
Copyright ©1999-2019 diyAudio
