PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Old 5th May 2019, 04:08 PM   #3461
phofman is offline phofman  Czech Republic
Post here output of
Code:
amixer -c 1 contents
Please copy/paste text, no picture screenshot.
Old 5th May 2019, 05:54 PM   #3462
Mr Trev is offline Mr Trev
Originally Posted by phofman View Post
Post here output of
Code:
Just to show how clueless I am doing this sort of thing, it took a while to even figure out how to copy/paste in Putty - that's why I posted a screenshot last time.
Code:
numid=57,iface=CARD,name='HDMI/DP,pcm=3 Phantom Jack'
  ; type=BOOLEAN,access=r-------,values=1
  : values=on
numid=42,iface=CARD,name='Headphone Jack'
  : values=on
numid=38,iface=CARD,name='Internal Mic Phantom Jack'
  : values=on
numid=40,iface=CARD,name='Line Jack'
  : values=off
numid=41,iface=CARD,name='Line Out Jack'
  : values=off
numid=39,iface=CARD,name='Mic Jack'
  : values=off
numid=44,iface=CARD,name='SPDIF Phantom Jack'
  : values=on
numid=43,iface=CARD,name='Speaker Phantom Jack'
  : values=on
numid=37,iface=MIXER,name='Master Playback Switch'
  ; type=BOOLEAN,access=rw------,values=1
  : values=on
numid=36,iface=MIXER,name='Master Playback Volume'
  ; type=INTEGER,access=rw---R--,values=1,min=0,max=31,step=0
  : values=31
  | dBscale-min=-46.50dB,step=1.50dB,mute=0
numid=11,iface=MIXER,name='Headphone Playback Switch'
  ; type=BOOLEAN,access=rw------,values=2
  : values=on,on
numid=10,iface=MIXER,name='Headphone Playback Volume'
  ; type=INTEGER,access=rw---R--,values=2,min=0,max=31,step=0
  : values=31,31
numid=3,iface=MIXER,name='Front Playback Switch'
  : values=on,on
numid=2,iface=MIXER,name='Front Playback Volume'
  : values=31,31
numid=5,iface=MIXER,name='Surround Playback Switch'
  : values=off,off
numid=4,iface=MIXER,name='Surround Playback Volume'
  : values=0,0
numid=8,iface=MIXER,name='Center Playback Switch'
  : values=off
numid=6,iface=MIXER,name='Center Playback Volume'
  : values=0
numid=9,iface=MIXER,name='LFE Playback Switch'
  : values=off
numid=7,iface=MIXER,name='LFE Playback Volume'
  : values=0
numid=30,iface=MIXER,name='Line Boost Volume'
  ; type=INTEGER,access=rw---R--,values=2,min=0,max=3,step=0
  : values=0,0
  | dBscale-min=0.00dB,step=10.00dB,mute=0
numid=20,iface=MIXER,name='Line Playback Switch'
  : values=on,on
numid=19,iface=MIXER,name='Line Playback Volume'
  : values=31,31
  | dBscale-min=-34.50dB,step=1.50dB,mute=0
numid=29,iface=MIXER,name='Mic Boost Volume'
  : values=0,0
numid=18,iface=MIXER,name='Mic Playback Switch'
  : values=off,off
numid=17,iface=MIXER,name='Mic Playback Volume'
  : values=0,0
numid=25,iface=MIXER,name='Capture Switch'
  : values=off,off
numid=27,iface=MIXER,name='Capture Switch',index=1
  : values=off,off
numid=24,iface=MIXER,name='Capture Volume'
  : values=0,0
  | dBscale-min=-16.50dB,step=1.50dB,mute=0
numid=26,iface=MIXER,name='Capture Volume',index=1
  : values=0,0
numid=14,iface=MIXER,name='Loopback Mixing'
  ; type=ENUMERATED,access=rw------,values=1,items=2
  ; Item #0 'Disabled'
  ; Item #1 'Enabled'
  : values=0
numid=35,iface=MIXER,name='IEC958 Default PCM Playback Switch'
  : values=on
numid=53,iface=MIXER,name='IEC958 Playback Con Mask'
  ; type=IEC958,access=r-------,values=1
  : values=[AES0=0x0f AES1=0xff AES2=0x00 AES3=0x00]
numid=31,iface=MIXER,name='IEC958 Playback Con Mask',index=16
numid=54,iface=MIXER,name='IEC958 Playback Pro Mask'
  : values=[AES0=0x0f AES1=0x00 AES2=0x00 AES3=0x00]
numid=32,iface=MIXER,name='IEC958 Playback Pro Mask',index=16
numid=55,iface=MIXER,name='IEC958 Playback Default'
  ; type=IEC958,access=rw------,values=1
  : values=[AES0=0x04 AES1=0x00 AES2=0x00 AES3=0x00]
numid=33,iface=MIXER,name='IEC958 Playback Default',index=16
numid=56,iface=MIXER,name='IEC958 Playback Switch'
  : values=on
numid=34,iface=MIXER,name='IEC958 Playback Switch',index=16
  : values=on
numid=21,iface=MIXER,name='Auto-Mute Mode'
  ; type=ENUMERATED,access=rw------,values=1,items=3
  ; Item #1 'Speaker Only'
  ; Item #2 'Line Out+Speaker'
  : values=0
numid=50,iface=MIXER,name='Caller ID Switch'
  : values=off
numid=1,iface=MIXER,name='Channel Mode'
  ; Item #0 '2ch'
  ; Item #1 '4ch'
  ; Item #2 '6ch'
  : values=2
numid=22,iface=MIXER,name='Input Source'
  ; Item #0 'Internal Mic'
  ; Item #1 'Mic'
  ; Item #2 'Line'
  : values=0
numid=23,iface=MIXER,name='Input Source',index=1
  ; Item #1 'Mic'
  ; Item #2 'Line'
  : values=0
numid=28,iface=MIXER,name='Internal Mic Boost Volume'
  : values=0,0
numid=16,iface=MIXER,name='Internal Mic Playback Switch'
  : values=off,off
numid=15,iface=MIXER,name='Internal Mic Playback Volume'
  : values=0,0
numid=49,iface=MIXER,name='Off-hook Switch'
  : values=off
numid=13,iface=MIXER,name='Speaker Playback Switch'
  : values=off,off
numid=12,iface=MIXER,name='Speaker Playback Volume'
  : values=0,0
numid=46,iface=PCM,name='Capture Channel Map'
  ; type=INTEGER,access=r----R--,values=2,min=0,max=36,step=0
  : values=0,0
  | container
    | chmap-fixed=FL,FR
numid=45,iface=PCM,name='Playback Channel Map'
  : values=0,0
  | container
    | chmap-fixed=FL,FR
numid=47,iface=PCM,name='Playback Channel Map',device=1
  : values=3,4
  | container
    | chmap-fixed=FL,FR
numid=48,iface=PCM,name='Capture Channel Map',device=2
  : values=0,0
  | container
    | chmap-fixed=FL,FR
numid=58,iface=PCM,name='Playback Channel Map',device=3
  ; type=INTEGER,access=r----R--,values=8,min=0,max=36,step=0
  : values=0,0,0,0,0,0,0,0
  | container
    | chmap-fixed=FL,FR
    | chmap-fixed=FL,FR,FC,LFE,RL,RR,SL,SR
numid=52,iface=PCM,name='Capture Channel Map',device=6
  ; type=INTEGER,access=r----R--,values=1,min=0,max=36,step=0
  : values=0
  | container
numid=51,iface=PCM,name='Playback Channel Map',device=6
  : values=0
  | container
Old 6th May 2019, 08:02 AM   #3463
But you made it and learned something new. It all counts.
The listing looks OK. In alsamixer I would try switching the Channel Mode to 2ch. I do not know the codec but can imagine a 6ch mode would disable the stereo (2ch) SPDIF output. Unlikely, but worth trying. Apart of that, all SPDIF outputs related to the codec seem to be ON.
There are 3 HDA codecs hooked to your HDA controller bus - ALC1200, Nvidia HDMI codec, and the Si3054 modem.
IIUC commit kernel/git/tiwai/sound.git - Sound sub-system tree , the SPDIF (IEC958) controls with index=16 should be related to SPDIF output, while the other SPDIF controls (default index=0) should be those of the Nvidia HDMI codec.
Old 6th May 2019, 08:19 AM   #3464
jazzter is offline jazzter  Germany
Hello,
using Daphile in a WiFi Hotspot configuration with Intel-NUC based hardware controlled via iPeng on an old Tablet and it works fine. Only problem, how to safely shutdown Daphile when I'm not able to connect to Daphile with a browser.
Thank you for your suggestions or ideas
Erich
Old 6th May 2019, 04:53 PM   #3465
The channel mode was originally 2ch. I switched the 6ch just to see of it would make a difference, it didn't, and I thought I switched it back.
One thing I just noticed is the headphone jack is on:
Code:
  : values=on
Since the optical out is shared with the headphone jack would this possibly be overridng the digital out? How would I turn it off - just to check (I'm pretty sure the headphone was off in alsamixer - actually everything but master and the spdifs should be off IIRC)
Thanks for your help.
Old 6th May 2019, 11:15 PM   #3466
Tromperie is offline Tromperie  Australia
Press the On button.
Source: LMS 7.9.2 on FreeNAS, PiCorePlayer * Storage: FreeNAS 11 * DIY PGA2310 * Amps: 8 x LM3886TF
Xover: 24dB @ 300 and 3kHz * Speakers: CNC cut 54 laminations * SB 10", SB 5", VIFA 1" * Remote: Squeeze Control
Old 7th May 2019, 01:12 AM   #3467
jetsilver is offline jetsilver  United States
USB automount failing for DAP. I've tried a bunch of Daphile installation files and have no idea why mounting my DAP - it's a Cowon Plenue D - is a sometime thing in the beta (CLI) but never works in the release branch.
Using the 19.01 RT beta *with* the DAP attached I get:
daphile ~ # lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 183.5M 1 loop /mnt/root-ro
sda 8:0 1 111.8G 0 disk
├─sda1 8:1 1 1G 0 part /boot
└─sda2 8:2 1 110.8G 0 part /mnt/hdd
sdb 8:16 1 30.8G 0 disk /media/music/USB Drives/PLENUE D
sdc 8:32 1 119G 0 disk
└─sdc1 8:33 1 119G 0 part /media/music/USB Drives/1EE1-3B51
daphile ~ # lsusb
Bus 002 Device 003: ID 045e:0039 Microsoft Corp. IntelliMouse Optical
Bus 002 Device 002: ID 0438:7900 Advanced Micro Devices, Inc.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 2357:011e
Bus 001 Device 003: ID f617:0905
Bus 001 Device 002: ID 0438:7900 Advanced Micro Devices, Inc.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 009: ID 0e21:09f0 Cowon Systems, Inc.
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
daphile ~ # mount
none on /sys type sysfs (rw,relatime)
/dev/sda1 on /boot type ext4 (ro,noatime,discard)
/dev/sda2 on /mnt/hdd type ext4 (rw,noatime,discard)
/boot/fw1901200702/rootfs on /mnt/root-ro type squashfs (ro,noatime)
overlay on / type overlay (rw,relatime,lowerdir=/mnt/root-ro,upperdir=/mnt/hdd/system/root-rw-fw1901200702/upper,workdir=/mnt/hdd/system/root-rw-fw1901200702/work)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
tmpfs on /run type tmpfs (rw,nodev,relatime,size=784456k,mode=755)
fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
dev on /dev type devtmpfs (rw,nosuid,relatime,size=10240k,nr_inodes=979269,m ode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode =000)
shm on /dev/shm type tmpfs (rw,nosuid,nodev,noexec,relatime)
none on /tmp type tmpfs (rw,nosuid,relatime)
none on /media type tmpfs (rw,relatime,size=6664716k)
none on /media/all_shares/RAM Drive type tmpfs (rw,relatime,size=6664716k)
/dev/sda2 on /media/music/Internal Drives/Music type ext4 (rw,noatime,discard)
/dev/sda2 on /media/all_shares/Music type ext4 (rw,noatime,discard)
/dev/sda2 on /media/all_shares/Playlists type ext4 (rw,noatime,discard)
/dev/sdb on /media/music/USB Drives/PLENUE D type vfat (ro,relatime,uid=1000,gid=1000,fmask=0133,dmask=00 22,codepage=437,iocharset=iso8859-1,shortname=mixed,utf8,tz=UTC,errors=remount-ro)
/dev/sdc1 on /media/music/USB Drives/1EE1-3B51 type vfat (ro,relatime,uid=1000,gid=1000,fmask=0133,dmask=00 22,codepage=437,iocharset=iso8859-1,shortname=mixed,utf8,tz=UTC,errors=remount-ro)
daphile ~ #
when I install it with the Plenue connected.
It's the Plenue D (dev/sdb) and 1EE1-3B51 (dev/sdc1) devices I want to access. Once booted off the installation .iso, these drives are visible and they show up in the File Manager as USB drives, but that doesn't survive an installation onto the device drive.
Being able to mount the DAP and transfer files is important to me, I leave the .flac files on the device, and transfer to the DAP.
On installing the main (non-beta, no CLI) branch these USB drives simply don't show up, ever.
What does it take to get USB drives to show up in the "local drives" panel as hot-plugged devices?
Old 7th May 2019, 08:36 AM   #3468
What is a DAP?
Old 7th May 2019, 08:53 AM   #3469
Julf is offline Julf  Europe
What is a DAP?
Digital Audio Player?
Old 7th May 2019, 08:57 AM   #3470
And it is a standard USB mass storage?
Daphile - Audiophile Music Server & Player OSHide this!Advertise here!
My Music Server ppastudio PC Based 7 3rd March 2012 11:42 PM
Music Server croccodillo PC Based 10 5th April 2011 01:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 02:41 PM
Music Server JC951t Digital Source 6 6th August 2008 07:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 02:12 AM
Copyright ©1999-2019 diyAudio
