PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Old 15th March 2019, 09:49 AM   #3361
Triplefun is offline Triplefun  New Zealand
I have the original smsl m8a based on two ES9028Q2M as opposed to the ES9038Q2M. Difficult to tell the difference but I suppose subjectively I prefer the topping.
And the u208 is a big jump on the u8, primarily with the ability to effortlessly support dsd512. I use daphile to oversample all music to dsd512 in real time.
I listen, therefore I am !
Old 20th March 2019, 02:50 PM   #3362
tthorsten is offline tthorsten  Germany
How i can connect with Daphile if the Smartphone saw an Daphile Wifi who is locked.
is the default DAPHILE ?
if the notebook Monitor turns of - how i can see the IP Adress from Daphile.
why isnt it possible to use Daphile like or also as a "normal" Desktop version on the Notebook or computer it self.
how i update the Dahile Distro and progamms - is there a Update Button or have i always to install everthing new.
Old 20th March 2019, 02:55 PM   #3363
could Peppy and the PulseaudioCrossoverprojekt join together and make the best ever sounding and useable audiodistro on the Planet also with ARM support for the Raspi and Banna community.
Old 20th March 2019, 09:30 PM   #3364
Originally Posted by tthorsten View Post
How i can connect with Daphile if the Smartphone saw an Daphile Wifi who is locked? Is the default DAPHILE ?
If daphile can't connect to a network then it generates a WiFi hotspot, ssid Daphile and password secret1234
Use Android phone app wifi overview to confirm your wifi networks. Then use Android app fing to identify the daphile ip.
Daphile is a self contained Linux install and not just an app.
Once operational use a browser to access the daphile settings tab and click on firmware update to access the latest release. Look at the daphile faq for details on how to access the more frequent and useful beta releases.
Old 20th March 2019, 09:43 PM   #3365
itsmaxdd is offline itsmaxdd
I'm in desperate need of a way to also install a desktop environment on the daphile pc. I would like to use it with a salvaged laptop panel to have a full fledged music player. Is there a way to do so?
Old 20th March 2019, 11:58 PM   #3366
phofman is online now phofman  Czech Republic
IMO you can run daphile in KVM virtual machine and PCI-passthrough the host system soundcard to the KVM-running daphile distribution. Never done before, but IMO feasible. Does require deeper linux skills though.
Passing USB devices to virtualbox running daphile should be a bit easier, e.g. VirtualBox 2: How To Pass Through USB Devices To Guests On An Ubuntu 8.10 Host . I guess that could be the easiest path.
Old 21st March 2019, 12:01 AM   #3367
Tromperie is offline Tromperie  Australia
Source: Daphile on old PC from the tip * Storage NAS: FreeNAS 11 * Pre-amp: DIY PGA2310 * Amps: 8 x LM3886TF
Xover: 24dB @ 300 and 3,000Hz * Speakers: DIY design CNC cut 54 laminations * Drivers SB 10", SB 5", VIFA 1" VTG
Old 21st March 2019, 01:14 AM   #3368
DRONE7 is offline DRONE7  New Zealand
I'm guessing here that you want a gui to run Daphile totally from the laptop and not have to access it from another device.....
If so then yes that option is built in.
Install daphile then access it from another device , go to settings page and select the option for a local interface/gui.
Reboot and the gui will appear.
It is quite basic in operation and options (so you may need to access daphile occasionally from another device to make setting adjustments) but for normal playback it is fine.
This from Kimmo the developer of Daphile...
"Player control application on local UI (optional)" means that you can have jivelite enabled (disabled by default) on the local console. This enables the real stand-alone operations (excluding the settings management).
Old 21st March 2019, 07:10 AM   #3369
I would rather avoid a solution like that, ofc it is probably the most flexible and with a USB DAC it should be really easy to setup but i'm not a fan of it. Anyway if i had to i would probably go for W10 + VBox if it is possible.
This is interesting. I'm expecting to have locally almost a fully web-page-like interface right? Since i will probably buy a chinese NUC i7 8250u it would be a waste to use it only with Daphile, so is it possible to install other packets like torrent client, maybe plex or dlna if not present ecc?
Old 21st March 2019, 07:25 AM   #3370
Again: Daphile is an embedded gentoo-based installation with read-only filesystem (squashfs). You cannot add packages.
If you want to run it along a regular distribution at the same time, run it in a virtual machine (KVM, VB, ...) and make sure it can see the raw audio device you want to use (hence the passthrough I talked about).
Or just add some audio playback software to your existing desktop setup.
Daphile - Audiophile Music Server & Player OSHide this!Advertise here!
My Music Server ppastudio PC Based 7 3rd March 2012 10:42 PM
Music Server croccodillo PC Based 10 5th April 2011 12:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 01:41 PM
Music Server JC951t Digital Source 6 6th August 2008 06:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 01:12 AM
Copyright ©1999-2019 diyAudio
