PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Old 23rd February 2019, 12:18 AM   #3281
Tromperie is offline Tromperie  Australia
Is there something I'm missing? Is there some way to edit and add artist and track info on that initial ripper screen? Any help would be much appreciated.
In a word, no.
PS - I just checked, and I can select "Unknown Artist" from the list of Album Artists and play the recording that way. Even though I'm more or less sure that I had deleted that folder using the file manager.
Every time there is an unknown artist, Daphile creates that folder. If you have a Windows computer, try MP3 Tag to edit the metadata.
Source: Daphile on old PC from the tip * Storage NAS: FreeNAS 11 * Pre-amp: DIY PGA2310 * Amps: 8 x LM3886TF
Xover: 24dB @ 300 and 3,000Hz * Speakers: DIY design CNC cut 54 laminations * Drivers SB 10", SB 5", VIFA 1" VTG
Old 23rd February 2019, 05:29 AM   #3282
Julf is offline Julf  Europe
There are of course lots of good taggers/music managers for linux too.
Old 23rd February 2019, 03:27 PM   #3283
tthorsten is offline tthorsten  Germany
how i rip cds with dahile in WAV instead of Flac - i couldnt found that option
Old 23rd February 2019, 04:08 PM   #3284
and is it possible to have example brutefire files to test the sound - lets say we choose the curve from the carhifi guys.
Frequenzgänge - Klangtuning 2 - RX-7 FD*Audio - Tobias Albert the redcurve in the diagramm is from a carhifi magazine here in germany
Old 23rd February 2019, 05:03 PM   #3285
el156se is offline el156se  Romania
Hi Tubeguy,
the ripping capability included into Daphile was programmed for original CD's, and those have already ID tag from factory. Advice: before to burn a new CD, your daughter must use an software to add tag info for all selected tracks (number of track, title, artist, year..etc). One suggestion is DB Power Amp (that is not for free), or other free tagging software at choice. Tagging is mandatory for building a healthy data-base in daphile. You cannot operate inside a database without tags, as it will be like trying to find an unknown chapter from an unknown book which sits on an unknown shelf
Q
Old 23rd February 2019, 07:10 PM   #3286
SRMcGee is online now SRMcGee  United States
SRMcGee's Avatar
Folks:
This may be off-topic, but I wasn't sure where else to ask the question. I have two servers, each with their own SSD, and an NAS device to which I copy everything. When I rip music, it is copied directly to my basement server (running Daphile). I then use Finder on an Apple MacBook Pro to copy the new albums to the second server and the NAS device. That way I have duplicate music libraries on both servers and a back-up on the NAS device.
I recently bought six CDs by Gary Clark Jr. (highly recommended, by the way). Those CDs were ripped to my basement server and they show up in Daphile under a directory titled "Gary Clark Jr", just as you would expect. I can listen to his music all day long on my basement server, should I so choose. Here's the weird thing: when I opened Finder on the MacBook Pro to copy those CDs to the second server and the NAS device, Finder did not find the "Gary Clark Jr" directory (and of course none of the CDs in that directory or subdirectories). Finder reports most if not all of the rest of my music library on that server; there may be other artists that Finder also does not report, but Gary Clark Jr. is the first that I have found (or not found).
Has anyone else experienced this? How do I cause Finder to "see" the missing directories on my basement server? I've had trouble with Daphile seeing files in the past, but this issue with the MacBook Pro is a first for me.
Scott
Good decisions come from experience. Experience comes from making bad decisions. (Mark Twain)
also, Everyone has a plan, till they get punched in the mouth. (Mike Tyson)
Old 24th February 2019, 06:26 AM   #3287
Why would you do that? FLAC contains exactly the same data, but stored in a more efficient way, and unlike WAV, has proper standardized tagging/metadata support and content integrity checksums.
Old 24th February 2019, 06:45 PM   #3288
Triplefun is offline Triplefun  New Zealand
Originally Posted by SRMcGee View Post
Folks:
Scott
Sounds liike an issue with sharing. Try going to Daphile storage settings and turn sharng off, restart daphile, turn sharing back on, and restart again.
I listen, therefore I am !
Old 24th February 2019, 07:21 PM   #3289
SRMcGee's Avatar
Triplefun:
Thanks for the suggestion. I tried it but that didn't solve the problem. Daphile still shows the Gary Clark Jr folder (and the CDs) but Finder doesn't see the Gary Clark Jr folder. Given that we have two Macs in the house and neither shows that folder, I suspect you're on to something. Might I need to refresh something on both Macs or is this more likely to be a Daphile-based issue?
Scott
Old 24th February 2019, 08:34 PM   #3290
Triplefun:
Scott
Probably a Daphile / Linux/ AccurateRip issue. Is the gary c folder at the root level? Try using Daphile file manager to reposition the directory. Maybe even create a new directory and copy the ripped files to there?
Daphile - Audiophile Music Server & Player OSHide this!Advertise here!
My Music Server ppastudio PC Based 7 3rd March 2012 10:42 PM
Music Server croccodillo PC Based 10 5th April 2011 12:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 01:41 PM
Music Server JC951t Digital Source 6 6th August 2008 06:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 01:12 AM
Copyright ©1999-2019 diyAudio
