PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Old 31st August 2018, 05:44 PM   #3081
Mooly's Avatar
Originally Posted by Nobrainer View Post
I have answered to both of you guys, but my replies don't show up?
This is because as a new member, your posts need to be read and approved by a moderator.
Old 31st August 2018, 05:46 PM   #3082
Nobrainer is offline Nobrainer
Yeah, I've figured it out now Thanks!
Old 1st September 2018, 02:03 AM   #3083
Tromperie is offline Tromperie  Australia
Well, there are quite a few members on this same network and (please correct me if I'm wrong) as far as I understand, anyone can see the "Daphile" under network, click on it, browse around the Settings, see passwords etc?
I wonder, if someone else on the network, browse into a playlist and clicks on a song... that would change it on my end as well, correct? So anyone on the network can mess around like that?!
For starters, they would have to know the IP address of Daphile and know enough to type that address into the address bar of a web browser.
Source: LMS 7.9.2 on FreeNAS, PiCorePlayer * Storage: FreeNAS 11 * DIY PGA2310 * Amps: 8 x LM3886TF
Xover: 24dB @ 300 and 3kHz * Speakers: CNC cut 54 laminations * SB 10", SB 5", VIFA 1" * Remote: Squeeze Control
Old 1st September 2018, 06:05 AM   #3084
phofman is offline phofman  Czech Republic
All they need is to run some network scan. A simple phone app like Fing would do.
Old 1st September 2018, 09:06 AM   #3085
If they are on a Mac, all they need to do is open Finder, then the Daphile folder shows up right there, in the left-hand menu, under "Shared".
Then they just need to click on the "DAPHILE" which is mounted, and they are in, all folders are presented and they are connected as a "Guest".
Next, let's say they click on the "Music" folder, there is a html URL that, once clicked, opens a Daphile URL in their default browser, and they are in Daphile interface.
So they do NOT need to know the address.
This however, does not work on Windows though, I assume it's because both, Linux and OS X, are both based on the Unix structure, Windows is not. I am just guessing this, so maybe someone else can correct me on this.
Personally, I do not like this and looking for a more private solution, as I am not the only one on this network and I can't just share it all like that.
EDIT: I DO like Daphile very much though, and I appreciate Kimmo's work, it's just this privacy thing that bothers me a little, that's all.
Old 1st September 2018, 01:02 PM   #3086
FredG31 is offline FredG31
Do you think Daphile (last x64 rt version) accepts a Weiss INT203 device?
I'm trying to use mine but Daphile thinks HW limit is 48KHz, and this unit can work from 24/16 to 24/192.
Am I missing something in the settings?
Thanks for your reply!
Fred from Toulouse (France)
Old 27th September 2018, 04:50 AM   #3087
@FredG31,
INT202/INT203 | Weiss Engineering Ltd.
This website says this about the INT203;
This is where our interfaces come in. The INT202 / INT203 allow any DAC to be connected to a FireWire or Thunderbolt ported computer. This is done, optimally, by slaving to the computer's internally generated clock with absolute bit transparency.
From my understanding, both of these are Apple and possibly not supported by Linux which normally runs on ex-Windows machines.
Old 27th September 2018, 05:15 AM   #3088
Weiss apparently does not care about linux GitHub - weiss-engineering/snd-firewire: ALSA DICE driver module
Old 28th September 2018, 08:58 AM   #3089
snoopy112 is online now snoopy112
Hello, may be someone could help me. I have PC on Intel dn2800mt with Daphile (latest beta version due to ssh), Matrix x-hi pci-e soundcard (usb 3.0, xmos, xhci driver uses) and connected Singxer SU-1 converter. It always works flawlessly when I power off/on or suspend system: it starts play automatically. But when I restart system, converter can’t be found (no audio device) while I turn Singxer power off and on or disconnect and connect again usb-cable. Have any suggestions how to fix this problem?
Old 14th October 2018, 03:04 PM   #3090
serdar is offline serdar
Hello friends.
Unlike the Ip number that I have been using for a long time, it opens as follows; 192.168.128.1 wi-fi hotspot only. It doesn't open when I enter the same rope. How can I solve the problem? Thank you for your contribution
Daphile - Audiophile Music Server & Player OSHide this!Advertise here!
My Music Server ppastudio PC Based 7 3rd March 2012 10:42 PM
Music Server croccodillo PC Based 10 5th April 2011 12:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 01:41 PM
Music Server JC951t Digital Source 6 6th August 2008 06:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 01:12 AM
Copyright ©1999-2019 diyAudio
