PC Based Computer music servers, crossovers, and equalization
Daphile - Audiophile Music Server & Player OS
Old 20th August 2018, 07:27 AM   #3041
phofman is online now phofman  Czech Republic
Originally Posted by pietjers View Post
I use the copy command of Windows Explorer on a Windows PC that is in the network.
Does that mean copying from one network share to another network share through your windows PC?
Old 20th August 2018, 07:51 AM   #3042
pietjers is offline pietjers  Netherlands
pietjers's Avatar
I am using a Windows PC in the same network to initiate the copying process. But the USB disk drive is directly connected to the Dahpile PC.
Old 20th August 2018, 07:59 AM   #3043
Triplefun is offline Triplefun  New Zealand
USB 2.0 or USB 3.0. Big difference !
I listen, therefore I am !
Old 20th August 2018, 08:19 AM   #3044
IIUC your data flow daphile HDD -> wrapping in daphile samba -> network -> windows -> unwrapping in windows SMB/CIFS client -> wrapping in SMB/CIFS client for the USB network share -> network -> unwrapping in daphile samba -> copying to USB.
What is your ethernet speed? Or even wifi?
Old 20th August 2018, 08:35 AM   #3045
pietjers's Avatar
Ethernet and Wi-Fi speeds are fast enough, but the whole chain you describe make it pretty slow.
(Windows PC uses Wi-Fi and Daphile PC is connected over Ethernet using the same router).
Also writing music from a Windows PC to Daphile PC is slow (2Mb/sec.).
Old 20th August 2018, 08:55 AM   #3046
Are they? 2MB/s = 16 Mbps + SMB huge overhead (protocol, encryption) + long unpredictable latency of wifi. People regularly report < 1MB/s samba speed over wifi. Perhaps samba params in daphile could be tweaked to improve the throughput - google offers lots of help. But again - no ssh access, read-only filesystem on daphile...
dtto
Old 20th August 2018, 09:25 AM   #3047
pietjers's Avatar
I tried to copy the music collection using a HD docking. So I took the HD out of the Daphile PC and connected it, using a HD docking, to a Windows PC, but then Windows asks to format the HD because the Ext 4 filesystem is not recognized.
Old 20th August 2018, 09:46 AM   #3048
Well, complain to the company you paid your money to - Microsoft. Ext4 is pretty old.
3 Ways to Access Your Linux Partitions From Windows
Or reformat your external HDD with NTFS which linux supports. Look at https://www.daphile.com/download/FAQ.txt Q12 .
Old 20th August 2018, 09:51 AM   #3049
DRONE7 is offline DRONE7  New Zealand
Download and write to bootable media (USB stick or DVD ) an Ubuntu live o/s...(18.04) (Etcher ... Etcher )
Boot your windows pc from that and copy files to docked Daphile drive.
Old 24th August 2018, 06:25 PM   #3050
thyristor44 is offline thyristor44
BBC HLS stream problems.
Hello can anyone help with a bbc HLS stream problem. I have tried Daphiles from 14 to the latest 18.07 but cant get the hls stream. If I do it sounds like very loud white noise with bbc almost inaudible.
I have enabled plugins bbc iplayer and play hls, but still no luck. I am using a variety of old pcs and laptops but doesn't help. My dual core system does work but that has the same 18.07 on. I have a choice of streams to listen to.
Has anyone any ideas.
thyristor44
Daphile - Audiophile Music Server &amp; Player OSHide this!Advertise here!
My Music Server ppastudio PC Based 7 3rd March 2012 11:42 PM
Music Server croccodillo PC Based 10 5th April 2011 01:56 PM
Music Server and PC based XO & EQ otto88 Multi-Way 10 19th May 2010 02:41 PM
Music Server JC951t Digital Source 6 6th August 2008 07:47 AM
SoCal Audiophile & Music Expo Nov 19-20th Apex Jr Everything Else 3 21st November 2005 02:12 AM
Copyright ©1999-2019 diyAudio
