Daphile - Audiophile Music Server & Player OS
Joined 2004
Hey Scott
Have you tried resetting everything by unplugging from power for a couple minutes.
Unplug router/modem, power ethernet adapters, and servers for couple minutes.
Two servers is not a high sampling, but since both are experiencing the same issue, it's possible it's their network connection.
Vince
Vince:
Yes, you may be right. I just connected one of the servers directly to the router and, naturally, it booted up fine. It hung when reinserted in its usual location.
I'll start by resetting the power ethernet adapters (again) but will let them power down for a while longer.
jnorris:
I'm sad to say I'm somehow gratified that it's not just me.
Scott
Hi, has someone used shairport plugin to stream from an appletv2?
If so could you help me with the settings, I get daphile to show the stream on the player but no sound and it just go to "stop", if I hit play it just "stop" immediately, played a little with settings but really don't know what I´m doing...
Streaming from my Macbook works fine.
Thanks!
Cambridge Audio CXA80
Hello,
I own Cambridge Audio CXA80 with USB XMOS port connected to Daphile (Lenovo ThinkCentre M58) with an internal hard drive. Everything works fine.
Daphile Settings-Audio Devices show CA CXA80 1.0. and there is HW limit: 96000Hz. Obviously I need some driver or something else to reach higher speeds. There is, on Cambridge Support pages, the possibility to download Windows driver for 2.0, but it is unusable in my case.
Does someone of you had or have similar issue?
Any solution?
All the best
Thank you for your answer and links. I've already read that.
From the Manual, I've understood that receiver is already in Class 2 operating mode. Windows and Linux, by default, have support for Class 1 and we need some software driver to handle Class 2 on the player (computer) side.
To be sincere, I'm very satisfied with Class 1 (24/96). I can't hear any improvement at a higher speed. But, you know,...
Allo Revolution Dac on Daphile : high cpu interrupt rate
Hello,
I have a Allo Revolution Dac connected to a mini-PC with linux Daphile on it.
When I use the internal sound card of the mini-pc (with the Revolution dac unplugged), the cpu usage is very low (few %).
As soon as I plug in the Revolution Dac, the cpu usage rise at ~12% constantly, even when not playinc music.
Code:
top - 17:09:14 up  1:43,  1 user,  load average: 0.12, 0.13, 0.09
Tasks: 163 total,   1 running, 162 sleeping,   0 stopped,   0 zombie
%Cpu(s):  1.4 us,  5.5 sy,  0.0 ni, 93.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :   7808.4 total,   7308.5 free,    211.2 used,    288.7 buff/cache
MiB Swap:      0.0 total,      0.0 free,      0.0 used.   7486.5 avail Mem
 PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
 124 root     -81   0       0      0      0 S  11.8   0.0   5:50.08 irq/123-xhci_hc
I know 12% is not a big deal. I'm just surprised that's the cpu usage even when there is no music played.
Anyway, I'm more concerned about the interrupt rate : there is ~7 000 interrupts per second on the cpu 0.
Below for an interval of ~10 seconds.
Code:
daphile ~ # cat /proc/interrupts | grep 123
 123:   23748036          0          0          0   PCI-MSI 344064-edge      xhci_hcd
 123:   23816116          0          0          0   PCI-MSI 344064-edge      xhci_hcd
I don't know what to think about it, but it seems rather high.
it's seems to me that it's a Daphile problem (if it's a problem). With volumio I stay with ~1% cpu usage and low interrupt rate.
Thanks for helping :)
IMO your cause is the same as in RPi4 and Khadas Toneboard - interrupt flooding !?!? . Check your DAC with the lsusb command, my 2 cents your bInterval will be 1 too.
Linux snd-usb-audio module used to have a parameter nrpacks which specified how many USB frames were sent by the USB controller before it threw an IRQ. That parameter has been removed in exchange for some automatic determination of correct nrpacks value. Maybe trying larger period size could raise it from 1 (i.e. IRQ every highspeed frame 0.125ms = 8kHz) to something higher.
But 12% is no major load.
Thanks for the reply, and, indeed, bInterval is 1.
Code:
Bus 001 Device 003: ID 152a:8809 Thesycon Systemsoftware & Consulting GmbH Revolution
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          239 Miscellaneous Device
  bDeviceSubClass         2
  bDeviceProtocol         1 Interface Association
  bMaxPacketSize0        64
  idVendor           0x152a Thesycon Systemsoftware & Consulting GmbH
  idProduct          0x8809
  bcdDevice            1.02
  iManufacturer           1 Allo.com
  iProduct                3 Revolution
  iSerial                 0
  bNumConfigurations      2
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0135
    bNumInterfaces          4
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower                0mA
    Interface Association:
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         2
      bFunctionClass          1 Audio
      bFunctionSubClass       0
      bFunctionProtocol      32
      iFunction               0
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass         1 Audio
      bInterfaceSubClass      1 Control Device
      bInterfaceProtocol     32
      iInterface              3 Revolution
      AudioControl Interface Descriptor:
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      1 (HEADER)
        bcdADC               2.00
        bCategory               8
        wTotalLength       0x0048
        bmControls           0x00
        bLength                 8
        bDescriptorType        36
        bDescriptorSubtype     10 (CLOCK_SOURCE)
        bClockID               41
        bmAttributes            3 Internal programmable clock
        bmControls           0x07
          Clock Frequency Control (read/write)
          Clock Validity Control (read-only)
        bAssocTerminal          0
        iClockSource            9 Allo.com Internal Clock
        bLength                 8
        bDescriptorType        36
        bDescriptorSubtype     11 (CLOCK_SELECTOR)
        bClockID               40
        bNrInPins               1
        baCSourceID(0)         41
        bmControls           0x03
          Clock Selector Control (read/write)
        iClockSelector          8 Allo.com Clock Selector
        bLength                17
        bDescriptorType        36
        bDescriptorSubtype      2 (INPUT_TERMINAL)
        bTerminalID             2
        wTerminalType      0x0101 USB Streaming
        bAssocTerminal          0
        bCSourceID             40
        bNrChannels             2
        bmChannelConfig    0x00000000
        iChannelNames          11 Analogue 1
        bmControls         0x0000
        iTerminal               6 Revolution
        bLength                18
        bDescriptorType        36
        bDescriptorSubtype      6 (FEATURE_UNIT)
        bUnitID                10
        bSourceID               2
        bmaControls(0)     0x0000000f
          Mute Control (read/write)
          Volume Control (read/write)
        bmaControls(1)     0x0000000f
        bmaControls(2)     0x0000000f
        iFeature                0
        bLength                12
        bDescriptorType        36
        bDescriptorSubtype      3 (OUTPUT_TERMINAL)
        bTerminalID            20
        wTerminalType      0x0301 Speaker
        bAssocTerminal          0
        bSourceID              10
        bCSourceID             40
        bmControls         0x0000
        iTerminal               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceSubClass      2 Streaming
      iInterface              4 Revolution
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           2
      AudioStreaming Interface Descriptor:
        bLength                16
        bDescriptorType        36
        bDescriptorSubtype      1 (AS_GENERAL)
        bTerminalLink           2
        bmControls           0x00
        bFormatType             1
        bmFormats          0x00000001
          PCM
        bNrChannels             2
        bLength                 6
        bDescriptorType        36
        bDescriptorSubtype      2 (FORMAT_TYPE)
        bFormatType             1 (FORMAT_TYPE_I)
        bSubslotSize            4
        bBitResolution         32
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            5
          Transfer Type            Isochronous
          Synch Type               Asynchronous
          Usage Type               Data
        wMaxPacketSize     0x02d0  1x 720 bytes
        bInterval               1
        AudioStreaming Endpoint Descriptor:
          bLength                 8
          bDescriptorType        37
          bDescriptorSubtype      1 (EP_GENERAL)
          bmAttributes         0x00
          bmControls           0x00
          bLockDelayUnits         2 Decoded PCM samples
          wLockDelay         0x0008
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       2
      bNumEndpoints           2
        bLength                16
        bDescriptorType        36
        bTerminalLink           2
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             2
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0008
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       3
      bNumEndpoints           2
        bLength                16
        bDescriptorType        36
        bTerminalLink           2
        bmControls           0x00
        bFormatType             1
        bmFormats          0x80000000
        bNrChannels             2
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         32
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0008
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass       254 Application Specific Interface
      bInterfaceSubClass      1 Device Firmware Update
      bInterfaceProtocol      1
      iInterface             10 Allo.com DFU
      Device Firmware Upgrade Interface Descriptor:
        bLength                             9
        bDescriptorType                    33
        bmAttributes                        7
          Will Not Detach
          Manifestation Tolerant
          Upload Supported
          Download Supported
        wDetachTimeout                    250 milliseconds
        wTransferSize                      64 bytes
        bcdDFUVersion                   1.10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         3 Human Interface Device
      bInterfaceSubClass      0
      bInterfaceProtocol      0
      iInterface              0
        HID Device Descriptor:
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bCountryCode            0 Not supported
          bNumDescriptors         1
          bDescriptorType        34 Report
          wDescriptorLength      33
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               8
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0135
    bNumInterfaces          4
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower                0mA
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         2
      bFunctionSubClass       0
      iFunction               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           0
        bLength                 9
        bDescriptorType        36
        bcdADC               2.00
        bCategory               8
        wTotalLength       0x0048
        bmControls           0x00
        bLength                 8
        bDescriptorType        36
        bClockID               41
        bmControls           0x07
        bAssocTerminal          0
        bLength                 8
        bDescriptorType        36
        bClockID               40
        bNrInPins               1
        baCSourceID(0)         41
        bmControls           0x03
        bLength                17
        bDescriptorType        36
        bTerminalID             2
        bAssocTerminal          0
        bCSourceID             40
        bNrChannels             2
        bmControls         0x0000
        bLength                18
        bDescriptorType        36
        bUnitID                10
        bSourceID               2
        iFeature                0
        bLength                12
        bDescriptorType        36
        bTerminalID            20
        bAssocTerminal          0
        bSourceID              10
        bCSourceID             40
        bmControls         0x0000
        iTerminal               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           2
        bLength                16
        bDescriptorType        36
        bTerminalLink           2
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             2
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         32
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0008
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       2
      bNumEndpoints           2
        bLength                16
        bDescriptorType        36
        bTerminalLink           2
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             2
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0008
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       3
      bNumEndpoints           2
        bLength                16
        bDescriptorType        36
        bTerminalLink           2
        bmControls           0x00
        bFormatType             1
        bNrChannels             2
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         32
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0008
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           0
        bLength                             9
        bDescriptorType                    33
        bmAttributes                        7
          Will Not Detach
          Upload Supported
          Download Supported
        bcdDFUVersion                   1.10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               8
Device Qualifier (for other device speed):
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         2
  bMaxPacketSize0        64
Device Status:     0x0001
  Self Powered
In Daphile, do you suggest to change Kernel/Alsa buffering Buffer time (100ms) or Period count (3) ?
First I would confirm that the values set in the GUI are actually being used - by looking at /proc/asound/YOURDACCARD/pcm0p/sub0/hw_params. Having confirmed that the daphile values are actually used (approximately, the driver picks the nearest supported value), you can try to raise the period size value (buffer size / period count). It is possible the change will have no effect on the IRQs rate - in such case there is nothing to do about it and the kernel will continue handling one outgoing microframe per one IRQ.
I don't have pcm0p/sub0/hw_params, but I guess there is some usefull information in /proc/asound/card1/stream0.
Code:
Allo.com Revolution at usb-0000:00:15.0-4, high speed : USB Audio
Playback:
  Status: Running
    Interface = 1
    Altset = 1
    Packet Size = 72
    Momentary freq = 44100 Hz (0x5.8330)
    Feedback Format = 16.16
  Interface 1
    Altset 1
    Format: S32_LE
    Channels: 2
    Endpoint: 1 OUT (ASYNC)
    Rates: 44100, 48000, 88200, 96000, 176400, 192000, 352800, 384000, 705600
    Data packet interval: 125 us
    Bits: 32
  Interface 1
    Altset 2
    Format: S32_LE
    Channels: 2
    Bits: 24
  Interface 1
    Altset 3
    Format: SPECIAL DSD_U32_BE
    Channels: 2
    Bits: 32
If there is nothing to do, I hope a newer kernel will improve the situation.
The stream0 file lists USB parameters, generated by snd-usb-audio kernel module. Individual altsettings can be determined from the lsusb readout, but the additional useful info provided by the driver is momentary samplerate (for async mode) and which altsetting is currently being used.
The file listing hw params including buffer and period information is generated by the sound layer common to all sound (alsa) drivers, including the usb-audio one. It is located at pcmXX/subX/hw_params of your /proc/asound/card1 directory. Look at Alsa Opensrc Org - Independent ALSA and linux audio support site
Yes, it doesn't matter if music is playing or not.
Code:
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Dummy [Dummy], device 0: Dummy PCM [Dummy PCM]
  Subdevices: 8/8
  Subdevice #0: subdevice #0
  Subdevice #1: subdevice #1
  Subdevice #2: subdevice #2
  Subdevice #3: subdevice #3
  Subdevice #4: subdevice #4
  Subdevice #5: subdevice #5
  Subdevice #6: subdevice #6
  Subdevice #7: subdevice #7
card 1: Revolution [Revolution], device 0: USB Audio [USB Audio]
  Subdevices: 0/1
By the way, thanks a lot for your involvement !
Code:
daphile ~ # uname -a
Linux daphile 5.4.54-daphile #4 SMP PREEMPT Tue Aug 4 08:11:18 UTC 2020 x86_64 Intel(R) Celeron(R) N4100 CPU @ 1.10GHz GenuineIntel GNU/Linux
daphile ~ # ls /boot/
boot  disk.uuid  EFI  fw2008040757  fw2008040759  grub  latest  lost+found
As you can see there is no config-* file in /boot/ I looked in EFI and fw.... too :(
