PC Based Computer music servers, crossovers, and equalization
USB cable quality
USB cable quality
Old 16th September 2013, 11:24 PM   #321
ClaveFremen is online now ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
USB cable quality
Originally Posted by SY View Post
That's the beauty of digital. You transmit the bits or you don't.
This is nonsense...There's no such thing as 'pure' digital transmission, every transmission is analog.
To have bit perfect trasmission you need trasmission protocols with error correction, retransmission of data, etc.
Finally for streamed data you don't even need to trasmit and receive all the bits...all you need is to receive the great part of it in a timely manner.
Originally Posted by cbdb View Post
Why do you think this is the only way audio is transfered over USB.
There's no a single way to transmit audio via USB.
For instance you can transfer audio as a file but you'll need a buffer to seamlessly play it and it will not be realtime.
BTW Isochronous trasmission can be done both synchronous or asynchronous (the difference is in which clock the trasmission use)
Dario
ClaveFremen "Bailando Salsa en el Sietch" - Sign for here for the 13th My_Ref FE GB.
Old 16th September 2013, 11:28 PM   #322
On Hiatus
SY's Avatar
USB cable quality
If a system is digital, the bits are transmitted and received or not. There's no "in between." If the bits aren't transmitted and received, there's dropouts if and when the lack of transmission/reception exceeds data correction. You recite a nice slogan, but that's all it is.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 16th September 2013, 11:38 PM   #323
Reality first!
USB cable quality
Sorry, false.
If the analog transmission representing digital data can't be interpreted there's an error.
If the transmission protocol provides a method for retransmisson you can then request again the missing data.
You're supposing the protocol provides retrasmission, there are protocols that don't do it.
Nicer than: That's the beauty of digital. You transmit the bits or you don't. ?
BTW mine is not a slogan but a simple, plain fact that every electronic engineer (should) know.
Dario
Old 17th September 2013, 12:03 AM   #324
On Hiatus
SY's Avatar
USB cable quality
Yes, dropouts, if the error is great enough to cause correction to fail. You'd have to really work at it to cause this to happen, though no doubt some high end cable peddler or ignorant diy-er could have managed the feat. A cheap USB cable from any normal retail outfit will work perfectly in this system.
Old 17th September 2013, 01:38 AM   #325
Greg Erskine is offline Greg Erskine  Australia
Greg Erskine's Avatar
USB cable quality
Are we still in context?
Originally Posted by lowtherdream View Post
Post #1: Context: PC or other digital source connected via USB to an external DAC.
Am I right in assuming there is no error correction at all?
regards
Greg Erskine
Old 17th September 2013, 07:35 AM   #326
marce is offline marce  United Kingdom
This is wrong, I'm sorry but digital transmission is digital transmission.
Old 17th September 2013, 08:52 AM   #327
Reality first!
USB cable quality
Hi Marce,
can you elaborate?
While it's obviously true that "digital transmission is digital transmission" (truism), at the physical layer you transmit analog waveforms representing digital data, like pulses, squarewaves or a limited set of continuously varying wave forms (passband trasmission).
So, at the physical layer, digital transmission is still subject to physics and so to errors, which can be handled, if needed, at higher levels by transmission protocols (error checking, error correction, retransmission).
The whole digital domain is actually an abstraction.
Where am I wrong?
Dario
Old 17th September 2013, 09:01 AM   #328
alan1977 is offline alan1977
yes my understanding of USB audio transmission was slightly wrong
Isynchronous (sp) is waht hte majority of DACs handle from what ive seen, data is streamed in 0s and 1's, the DAC doesn't care if what it receives is what's sent, it just handles the signal and converts it to analog.
Asynchronous (sp) is more like hte method for which you would transfer data which cannot be received incorrectly, the data is checked, and resent if necessary before being processed, there are Asynchronous DACs available after research, which in theory shoudl completely remove the need for an overpriced cable? should it not?
So, to summarize... if you have an isynchronous DAC, the quality of the cable can potentially affect the recieved signal. Can you hear it? that's another matter completely
I hope i have this right please feel free to correct me
Old 17th September 2013, 09:08 AM   #329
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 USB cable quality
I smell entrenched positions, time for some posters to look at the bigger picture.
2nd order effects exist, fact!
Cables can't filter the data, fact!
Data either passes with a high enough accuracy to completely recovered or it does not, this in independent of resending, fact!
It would be nice if someone who claims 'better' cables can make an audible difference could point to blind listening tests that back up that position. Surely if 2nd order effects were audible there must be some way to 'queer' a test to prove it?
That no manufacturer yet has points to the truth.
Paradise Pre-reg PSU PCBs
Old 17th September 2013, 09:13 AM   #330
Reality first!
USB cable quality
Originally Posted by sq225917 View Post
Data either passes with a high enough accuracy to completely recovered or it does not, this in independent of resending, fact!.
Sorry, false. See again Isochronous transfer.
Dario
USB cable qualityHide this!Advertise here!
How to isolate USB instrument from interference conducted by the USB cable sunkai Parts 3 25th April 2014 03:19 PM
USB Cable sergedc Digital Source 3 23rd April 2012 12:44 PM
Will wireless USB hub lower the quality of my USB sound card output? rg12 Digital Source 6 6th January 2011 09:47 PM
USB DAC (in the cable!?) rjm Digital Source 5 13th May 2004 09:19 AM
Copyright ©1999-2019 diyAudio
