PC Based Computer music servers, crossovers, and equalization
USB cable quality
USB cable quality
Old 7th September 2013, 04:08 PM   #281
phofman is offline phofman  Czech Republic
If the playback soundcard is just plugged-in and all settings left at default, then the setup will be identical. Replacing the cable means the USB soundcard will be removed from the system and again configured to default when attached with the other cable. Any previous setup changes would be lost. Do we know the card setup was left at default?
Old 7th September 2013, 04:11 PM   #282
On Hiatus
SY's Avatar
USB cable quality
We don't know anything. Marlene can post the files and the test setup details to allow people to try to replicate this remarkable result.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 7th September 2013, 04:12 PM   #283
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
USB cable quality
It would be true if the USB port have been changed, using the same port settings are retained and no setup happens.
I can hardly trust that he changed the port.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - Sign for here for the 13th My_Ref FE GB.
Old 7th September 2013, 05:09 PM   #284
Really, are you sure? That is how usb soundcards behave in windows? I do not know, it certainly is not the case in linux. If a soundcard is detached, it is removed from the system. Just like in windows. And unless you stored its configuration specifically, which is not automatic, upon next attach it is configured to its default settings. The actual port plays no role at all. In linux cards are identified by its name, not port.
Old 7th September 2013, 05:24 PM   #285
Siberia is offline Siberia  Lithuania
Siberia's Avatar
Originally Posted by DF96 View Post
No.
It is easy to show that certain measurements are different for boys and girls, especially after puberty! This doesn't tell you much about career choice, but it does dismiss any claim that they are essentially the same. If minor differences in body chemistry can create significant differences in body shape then it is quite possible that these also create differences in preferences. Anyone who has known any boys and girls (or men and women) will know that this is the case. It is merely silly for people to assume the opposite and require sensible people to do the same.
Might be OT, might be not, but I must reply. Mostly out of respect to what I've read on hundreds and thousands of your posts in which you were so truthful to science.
Please, show any scientific evidence that proves biological states of being male or female as determinants of choice, preferences, thinking, acting. The claim that seeing body differences we should assume difference in preference is grounded in beliefs. This form of thinking was refuted by numerous gender studies. Yes, it's humanities but it's still science. Gender is a social construct and trying to prove otherwise always ends in sexism and claims like "women are worse in mechanical or engineering in general".
Sorry, if this is too OT. I've seen so many sexist "innocent" remarks here and kept myself silent not to disrupt the topic. Not this time.
Old 7th September 2013, 05:36 PM   #286
DF96 is offline DF96  England
Complete bunkum. Gender is defined by every cell in the body. Small children usually exhibit gender preferences from a very early age. The exceptions are noticeable precisely because they are exceptions (e.g. a girl who wants a train set will often end up as an engineer or physicist). I have worked with female engineers and they were every bit as good as the men, but they remained women and thought and acted like women - even the one who was a convinced feminist!
What is wrong with sexism? i.e. regarding men and women as being different? It may be considered taboo by modern trendy liberals but ordinary people regard it as normal common sense.
Gender studies is not science. They decide the answer then look for supporting evidence. The bile heaped on those who disagree shows that they are not seeking truth but pushing a political/philosophical agenda.
To say any more would take me seriously OT so I will stop there.
Old 7th September 2013, 05:47 PM   #287
marce is offline marce  United Kingdom
Anyone read that article?
Marlene's Musings: Vodoo continued: my final Statement on USB cables
It's the last one from a series with final conclusion.
He eared differences, he tried to measure, he found differences in measurements but later discovered that his measurements where faulty.
After fixing his mesurements he found no differences at measurements but still recognize differences with ABX via Foobar (!)
Interesting... it seem we need better measurements, after all.
No.
Old 7th September 2013, 05:53 PM   #288
Reality first!
USB cable quality
Absolutely, not only soundcards, in fact you can see under Device Manager all branched USB devices if you select 'Show hidden Devices' in the View menu.
Originally Posted by marce View Post
No.
Hi Marce,
Can you elaborate a bit?
BTW
Just in case you didn't read the credits for my My_Ref variation, thanks again for your invaluable help with the PCB design.
Dario
Old 7th September 2013, 06:13 PM   #289
Siberia's Avatar
Any evidence?
Choosing a car over a doll in early stages of development is linked to hormones. Although, it has no career or other social consequences if children are not tought at later stages to conform to gender stereotypes. Which only proves a gender being a social contruct.
There is no scientific evidence that boys prefer blue and girls prefer pink etc
Sexism wrongly imposes superiority.
Calling other people trendy and your camp normal is not an argument.
Finding an answer and being able to prove it still makes it science regardless the intentions. If your belief "gender is defined by every cell in the body" would be scientificaly proven, should it be call less of the fact and rather a political agenda?
I'm stopping this OT here too.
Old 7th September 2013, 06:26 PM   #290
rsowen is offline rsowen  United Kingdom
What Setup? I have never experienced this. Certainly not the case on the Windows driver's we use, or Mac.
USB cable qualityHide this!Advertise here!
How to isolate USB instrument from interference conducted by the USB cable sunkai Parts 3 25th April 2014 03:19 PM
USB Cable sergedc Digital Source 3 23rd April 2012 12:44 PM
Will wireless USB hub lower the quality of my USB sound card output? rg12 Digital Source 6 6th January 2011 09:47 PM
USB DAC (in the cable!?) rjm Digital Source 5 13th May 2004 09:19 AM
Copyright ©1999-2019 diyAudio
