Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Pass Labs This forum is dedicated to Pass Labs discussion. |
Thread Tools |
#4871 |
BTW I have my new built running nice with the Aikido preamp. I like what I hear a lot.
#4872 |
Airline Pilot-If it's not Boeing I'm not going. Aleph J, F4, DCB1, VHEX +, USSA-5, BA-3 Pre, DCG3, USSPA, Transcendent Sound Masterpiece (sold) TDA1541A D3, RH84, D3 Build guide |
#4873 |
Very nice schematic
"Diyers are the happiest audiophiles: they have the opportunity to be deeply involved in what they are doing and it provides a lot of satisfaction". Nelson Pass |
#4874 |
Uh-oh. I was moving my main stereo to another room when I fumbled my F4 and semi-dropped it, managing to recover so it didn't hit the floor, though it landed in a chair. When I listened later, one channel was about 1/3 the loudness of the other. Switching loudspeaker connections confirmed that one channel was weak (but I'm not 100% sure it's not the preamp yet; to be confirmed later). Aside from looking for anything broken and maybe checking the bias, is there any other troubleshooting tricks I can try?
#4875 |
Official Court Jester
preamp or not, confirm ....... then troubleshoot amp, only if needed
my Papa is smarter than your Nelson ! clean ![]() ![]() ![]() |
#4876 | |
#4877 |
Oops. Yes, it looks like one of the tubes in the preamp is in need of replacement. Never mind! But at least I know how to proceed in the future in the unlikely event I need to fix the amp. Thanks, everybody.
#4878 |
Hi folks. So I was reading about some $20k+ amps and read that each rail had it's own power supply transformer. This cued me to realize that I had a totally unused transformer in my power supply and could easily try this out for my f4 monoblocks (image below). Both transformers are identical, 400v anteks with dual 18v secondaries.
My question is, if I do this, what should I do with the extra secondaries. I read recommendations to just heat shrink each wire and then tie up the pair. Other people recommended connecting them in parallel to a single rectifier. Any opinions from this group? Thanks as always. |
#4879 |
Parallel the secondaries on each transformer. Then you have 2 transformers with only one secondary each. One transformer per rail. Voila!
Illustrated Build Guides - Pass F4 - Pass B1 - Pass F5 - Pearl 2 - O2 HPA - Hagerman Bugle 2 - Pass Aleph J - Me at BAF'13 -Pass F5Turbo - BA-3 Amp - BA-3 Preamp -F6- -AmpCampAmp -Me at BAF'18 -Me at BAF'19 |
#4880 |
Great, thanks.
I read that there could be some problems if the windings weren't matched even if nominally rated as identical. Was thinking that really wouldn't be a problem here, but thought I'd go ahead and check. In many cases, I think the concern came from using identically rated secondaries across different transformers, thereby increasing the chances of voltage differences. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 39 | 2nd August 2019 02:58 AM |
Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 11:49 PM |
McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 11:22 PM |
Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 09:44 AM |
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 05:06 PM |
New To Site? | Need Help? |
