F4 power amplifier
F4 power amplifier
Old 21st February 2020, 01:56 PM   #4551
cal3713 is offline cal3713
Originally Posted by nfsgame View Post
You've built a great RF-reveiver with those foil-resistors >1cm away from PCB with a "loop"-antenna... It's better to form the leads with two fine pliers so that the leads are as short as possible.
I am planning on building a "maxed out" F4 with the z-foil resistors too. Nice to see an example and get some feedback on how best to install.
Old 25th March 2020, 06:07 PM   #4552
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
F4 power amplifier
Default Preamp for F4
Another preamp that works well with the F4 is the S5 Electronics K-PL kit.
This was my first tube build and it was pretty easy. Needs a 200v power supply and 6.3v for filaments. Antek has a dual 140v and dual 6.3v secondaries.
I used a 175v version, but had to drop the voltage by ~40v. The 140v will get you closer with less fuss.
K-PL uses a 5670 triode tube, however member (audiowise) recommended the 6922 with a cathode cap. Said 6922 will halve the output impedance. I will be trying th 6922 as well with a 60uF MKP. As-is it sounds pretty good.
I upgraded the main board parts for $25.
Price is right. Basic Bud chassis and other parts came to under $200.
It is my opinion that it sound way better than the price suggests.
S5 K-PL
I build, therefore I am.
Do not create problems where there are none.
F4 power amplifierHide this!Advertise here!
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 39 2nd August 2019 01:58 AM
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
