DIY F2 clone
DIY F2 clone
Old 6th October 2019, 04:34 AM   #601
csample is offline csample  United States
DIY F2 clone
I tried to take both measurements tonight. I am using the built in sound card on my computer and the generator in REW to create the signal. I am running an 8 ohm dummy load and measuring at the input to the amp.
To get an idea of the frequency response I varied the input frequency to the amp and measured the voltage of the output - I did not see any variation in the output voltage of the amp from 20 Hz to 20,000 Hz, but it did drop off a little at 10Hz. A pretty crude test, but the results seem ok.
I am having some trouble obtaining the FFT measurement, probably due to my inexperience. The questionable measurements I have now show that I need to have a 5 Vrms output on the amplifier to get a second harmonic peak make it above what I think is a -50dBV noise floor. I'll try again tomorrow.
Old 7th October 2019, 03:15 AM   #602
DIY F2 clone
The images below show what i am measuring for frequency response and the best I can do for the FFT.
The frequency response starts to drop off below 20 Hz, but is flat from there up to 20,000 the highest frequency measured.
The FFT shows a ~47dB difference between the fundamental and the second harmonic. These measurements were taken at 1000Hz and 5.2 Vrms or about 3.4W output. If I am getting the math right, this is about .45% distortion. The First Watt distortion chart for the F2J shows about .6% THD at this power level. So allowing for an increase due to higher order distortion, I think my amp measuring .45% seems like it is in the ball park.
Any recommendations of what to try next? I was considering trying a different C3, maybe making a 12,000 uF bank of Nichicon KZ or Silmic II? Anyone know what type of capacitor was used in the real F2J?
Is it possible that this amp/speaker combo just is not a good pairing?
File Type: png Screen Shot 2019-10-06 at 9.56.29 PM.png (21.1 KB, 129 views)
Old 7th October 2019, 04:51 AM   #603
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
DIY F2 clone
that is looking good, so nothing to conclude as possible culprit
any other amp as comparison , trying other source ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 8th October 2019, 12:51 PM   #604
DIY F2 clone
I just biased up my BA-3 last week and it sounds great! Not as much bass with the Vulcans as the F2J, but much clearer. It also sounds great with some 4 ohm Vifa/Scanspeak 3 way towers I built years ago, the bass is so clear and precise that it makes me think I never had an amp that could handle the low impedance 10" woofers before.
Eventually I will build the DCG3 preamp that I have parts for, maybe that will help with the 10K input impedance of the F2J. Although I though the B1 would have helped with this too...
Do you think there would be any value in changing the output electrolytics, or is this just a waste of time and money?
Thanks for the input Zen Mod, as always you are very helpful.
Old 8th October 2019, 01:05 PM   #605
Zen Mod's Avatar
DIY F2 clone
changing caps can only bring it closer to your taste, but can't cure-it-all
find a reason why you're not satisfied - it's either source side or speaker side
for starters - try feeding it with anything which has headphones output with volume
I remember having some amps in Yore, and I was happiest (then) feeding them ditto from crappy Technics CD headphones out
that will tell some ......
Old 8th October 2019, 05:30 PM   #606
DIY F2 clone
I will try to feed it with my Zen-Like headphone amp and see what happens. Thanks
DIY F2 cloneHide this!Advertise here!
F1 Clone DIY PCB suds Group Buys 2 8th January 2009 09:50 AM
My F3 Clone 04dgmsilv Pass Labs 11 31st August 2008 11:59 AM
clone AN/K ccopp Multi-Way 0 9th July 2006 08:24 AM
Question regarding ProAc 2.5 Clone and Tempo 2 Clone zoooh Multi-Way 5 11th March 2003 08:19 PM
Copyright ©1999-2019 diyAudio
