Reading Np's explenation about merit and drawback of diamond differential, I draw this : http://www.diyaudio.com/forums/showthread.php?postid=688316#post688316
What do you think?
What do you think?
Onvinyl said:Is this Idea a valid option worth trying?
Improved linearity through complementary differential further tamed with sort of double-x?
Or would the circuit blow and explode due to the different charges meeting at the gates?
Just a silly morning-idea before coffee & work?
yours,
Rüdiger
This circuit may be very fine as differential amplifier itself- fast, linear etc., but won't work correctly as front-end of a power feedback amplifier. It is because of drain-gate local feedback, which may cause to ill feedbacks' interaction like 'correction of the correction', which obviously will degrade performance of global feedback. Not to mention low PSRR.
Without drain-gate feedback resistors will be just fine.
regards
It is just drawn upside down (think Tharma and some others in early '70 drew -Vcc up and +Vcc down) and lacks biasing circuit- it shows idea of diamond differential. I think diamond combines some pros of so-called 'current feedbak' (one low impedance input) with low distortion of voltage feedback.
regards
regards
