SuSyLu Where Are You?
Thread Tools
Old 26th October 2021, 07:13 PM   #251
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
I think we discussed this - depends on how much magnetic energy storage you want for headroom. The custom dual balanced 600VA class EI core choke I have is 11lbs 5oz. The size and weight comes mostly from requirement of 14ga wire and 60mH with 0.5ohm DCR.
Impedance sweep (two separate ones line up) and fairly linear behavior from 20Hz to 20kHz.
I am told that the 60mH and DCR spec of 0.5ohms is at 10kHz.
XRKaudio Store // Manufacturer’s Forum
Old 26th October 2021, 07:24 PM   #252
mbrennwa is online now mbrennwa  Switzerland
mbrennwa's Avatar
Originally Posted by daanve View Post
mbrennwa, with both winding in series being 95 mH, each winding is 24 mH, not 47 mH.
Oups, yes, you're right. I forgot that series or parallel windings act different when they're on the same core. I guess the Lundahl is out.
Old 26th October 2021, 11:45 PM   #253
nicoch58 is offline nicoch58  Europe
  Reply to this post
SuSyLu Where Are You?Hide this!Advertise here!
Thread Tools
Do You Agree With The "1001 Albums You Must Hear Before You Die" list? Cask05 Music 6 5th May 2016 11:12 PM
Thank-you thank-you thank-you thank-you and thank-you nonik Introductions 2 27th January 2004 11:21 AM
What do you get when you cross... nobody special Pass Labs 13 12th October 2002 05:47 PM
what you you gents do with old projects? gsattler Multi-Way 18 21st May 2002 10:34 PM
What do you think you are doing!? Jason Everything Else 4 30th January 2001 02:19 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
