VFET amp Bourns trimmer exchange
Thread Tools
Old 5th June 2021, 04:05 PM   #1
MEPER is offline MEPER  Denmark
MEPER's Avatar
Default VFET amp Bourns trimmer exchange
I have started the small academic exercise to verify if the 25k Bourns trimmer is the root cause of a very small amount of on/off noise in R-channel. It is academic because it is only audible with ear very close to tweeter. But L-channel is almost 100% "dead" and could be nice to achieve this also for R-channel. While new 25k trimmers are on the way I did the removal of the old and also I measured a value for a R1 and R2 resistor if I should want to try this out and use fixed resistors insted.
The removal went very smooth. I used a smd hot air gun I got long time ago. A hobby version (Velleman brand). But it worked perfect. I adjusted the temperature to 390 C and set airflow to medium. After 10 sec. or so heat up I could pull out the trimmer.
I measured 3 resistor values (R1: 10k80, R2: 12k52 and R3: 23k30 (check value). I miss 20 ohm somewhere.....
I guess if I had a 12k5 and a 10k8 resistor I was good to go but I don't have these values. But it looks very close to some standard values.
I suspect the trimmer is the problem as it creates noise by just the slightest touch of the trimmer screw. But time will show......
23k3 is quite far away from 25k but within the 10% tolerance. So maybe you guys out there has a 23k in one channel and 27k in other channel? :-)
Old 5th June 2021, 04:12 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
well, you can proudly say that your OCD outgrown eve mine OCD
though, there are other things at my side,so you're reaching just 100 mZM with this
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 5th June 2021, 04:50 PM   #3
MEPER's Avatar
OCD = Obsessive-Compulsive Disorder?
I think this is "spot-on" :-)
But I don't feel alone with this in this forum :-)
My mono block ACA's are in service now and they can certainly still deliver nice sound!
I had them out to a friend last week driving Snell C speakers.....and that was a bit of a surprise what they could do (4 ohm speakers as far as I know).
Old 5th June 2021, 05:29 PM   #4
Soundhappy is online now Soundhappy  France
Soundhappy's Avatar
Originally Posted by MEPER View Post
I have started the small academic exercise to verify if the 25k Bourns trimmer is the root cause of a very small amount of on/off noise in R-channel....23k3 is quite far away from 25k but within the 10% tolerance.
So how much Ohm's difference in another channel ?
class A amplifiers with full range speakers
sings like angels in heaven
Old 5th June 2021, 05:41 PM   #5
MEPER's Avatar
Trimmer is in place in other channel. It seems to work perfect so I plan to just insert another trimmer in R-channel.
If C3 was not there......then I could probably measure trimmer "in-circuit"?
But maybe not knowing if there could be 2k difference in trimmer values......could cause bad sleep for many nights?
Old 5th June 2021, 05:47 PM   #6
Zen Mod's Avatar
no
Old 5th June 2021, 05:58 PM   #7
MEPER's Avatar
Ok, but while VFET is out of service for a while until new trimmers arrive the ACAs has just played:
Brad Mehldau: Mon Chien Stupide
Brad Mehldau was a band I discovered by accident but I like their music and recordings very good.....and ACA did it very well.
Old 5th June 2021, 06:09 PM   #8
TungstenAudio is offline TungstenAudio  United States
A worthy sidebar discussion for those of us with OCD for these things.
Old 5th June 2021, 06:43 PM   #9
chromenuts is online now chromenuts  United States
Maybe we need a thread about OCD...I know that it prevents me from accomplishing a lot more of what I’d like to.
Good luck with your trimmer issues!
Old 5th June 2021, 06:55 PM   #10
tombo56 is offline tombo56  Croatia
Don’t we call our OCD “attention to detail” or “strive for perfection”?
VFET amp Bourns trimmer exchangeHide this!Advertise here!
Thread Tools
VFET-X (or my 1/3 40th Anniversary Sony VFET Clone) WalterW Pass Labs 192 4th August 2021 05:37 PM
Looking for 1 genuine Sony 2SJ18 vfet for my Sony TA 5650 vfet amp VFET747 Pass Labs 7 17th April 2021 06:21 PM
WTB 1 channel of VFET from Diyaudio's Sony Vfet kit fishball79 Swap Meet 3 10th July 2020 03:11 AM
IC: 2x sony vfet essentia kits, PSU PCB's, vfet part 2 PCBs and other acessories MASantos Swap Meet 7 15th April 2018 04:34 PM
WTB dual "modular" pots from Clarostat, Bourns ETC mihow Parts 0 15th September 2005 06:40 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
