DIY Sony VFET Builders thread
Thread Tools
Old Today, 01:49 PM   #1101
Mark Johnson is offline Mark Johnson  United States
diyAudio Donor
Mark Johnson's Avatar
I'm messing around with electrically-compatible, physically compatible, amp channel boards -- boards
which use semiconductor devices you can buy today from Mouser (i.e. NOT VFETs).
Because the boards are electrically-compatible, they use the same single ended power supply:
+36V,GND. So they have an output coupling capacitor, just like the lottery VFET cards. Here's
one such amp channel board, the capacitor is ten millifarads, 50 volts, snap-in terminals @ 10mm
lead spacing.
The white thing at lower left is a Relentless front end card. Click on the image to see it full
size and undistorted.
DIY Sony VFET Builders thread-cappy-jpg
What??!? (you may be thinking) Are those connectors I see on the board? Do you mean
the I/O wires aren't soldered???
_
Old Today, 02:07 PM   #1102
juanitox is offline juanitox  France
juanitox's Avatar
Originally Posted by MEPER View Post
The 10.000 uF output cap will be very close to its ESR value already at relative low frequencies so a small bypass cap is "nonsense". If the output cap is audio grade quality it will stay at its ESR at 20 kHz and higher frequencies and then from a point raise in impedance caused by the inductance. I guess the ESR for such a cap is maybe 10-15 mohm? .....try to calculate the impedance of the small bypass cap at 20 KHz and compare to 10-15 mOhm.
as the perfect audiofool i have put a russian 30uf PIO here and it seems it doesn't harm at all
French is not a crime.
Old Today, 02:11 PM   #1103
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
_
well, I'm not even grumpy when I say that I despise that .........
but, I'm not letting my Despise ruining someone's Happiness
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old Today, 03:00 PM   #1104
diyAudio Donor
Naturally it is easy and simple to NOT stuff the FastOn 6.35mm (1/4 inch) blade connectors. When you omit those, there are big-fat-wire thru-holes to assist a hardwired and soldered connection. See arrows on image below.
It is also easy and simple to NOT stuff the Euro style screw cage terminal block. Just solder your input twisted pair or input coax cable, to the IN and GND pads where the termblok would go.
_
  Reply to this post
DIY Sony VFET Builders threadHide this!Advertise here!
Thread Tools
Looking for 1 genuine Sony 2SJ18 vfet for my Sony TA 5650 vfet amp VFET747 Pass Labs 7 17th April 2021 06:21 PM
VFET-X (or my 1/3 40th Anniversary Sony VFET Clone) WalterW Pass Labs 191 2nd April 2021 08:02 PM
WTB 1 channel of VFET from Diyaudio's Sony Vfet kit fishball79 Swap Meet 3 10th July 2020 03:11 AM
IC: 2x sony vfet essentia kits, PSU PCB's, vfet part 2 PCBs and other acessories MASantos Swap Meet 7 15th April 2018 04:34 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
