While they last...
While they last...
Thread Tools
Old 30th November 2021, 03:09 PM   #1051
triode_al is offline triode_al  Netherlands
triode_al's Avatar
I have a secret plan to use tight curve-traced quad SITs in a modified F6 amplifier.
Because in the F6 drain load = source load, and because the signal is applied between source and gate, the current swing is equal.
I think you need two tight matched pairs; the two pairs being roughly equal.
A little dissemetry top/bottom is not bad, gives a bit more H2, by having a volt or two difference in Vds, that probably works wonders.
The special F6 feedback is a requirement to get a lower output, but not mandatory because out of the box it might be in the order of 7-10 ohms, much lower than with the IRF240/250's real mosfets. So feedback can be much less.
la recherche d'un son perdu
Old 30th November 2021, 03:24 PM   #1052
TungstenAudio is offline TungstenAudio  United States
Wow, that will be some project!
I do like my F6 with the FQH44N10 parts, slightly higher voltage rails (+/–26V). Have thought about trying dissimilar Mosfets on top, or bottom, such as IXFK120N20P in the larger TO-264 package. However, I'm still busy with other projects.
Something else to consider if using higher voltage rails: Replace the simple JFet buffer with a HV opamp such as the OPA551. I used a Diamond buffer in mine, but I have really been enjoying the Marauder cards in my lottery VFET amp.
Old 30th November 2021, 10:39 PM   #1053
grataku is offline grataku  United States
Interesting! What kind of sit are you thinking about?
  Reply to this post
While they last...Hide this!Advertise here!
Thread Tools
Last plea for a while: 1x8" or 2x6.5" SB woofers for a two-way? Apfelsauce Multi-Way 3 29th April 2011 06:20 PM
new dipole baffle...last one for a while ultrachrome Multi-Way 1 7th September 2005 09:13 AM
Maplin "While Stock Last" AP130M0 4.98 Beggar Multi-Way 0 7th July 2004 10:59 AM
2SJ56-2SK176 on ebay in quantities! get'im while they last! KBK Parts 4 15th February 2004 08:16 AM
Last post for a while, featuring non-audio gratuitous image Jocko Homo Everything Else 11 5th November 2002 05:04 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
