Dreaming of a DIY power amp
Thread Tools
Old 2nd March 2021, 01:43 PM   #51
peppennino is offline peppennino  Italy
Flux Capacitor Tester
peppennino's Avatar
Originally Posted by Giovanni1968 View Post
We are 'talians from the south, harder than the others to convince...
So which would you pick as easy to start with and eventually upgrade later of if confident with the assembly and result?
I'd go for J or F4, absolutely keepers, even if you would switch to other FW boards in the future
SL-1210 w/6L6's PSU | Mini Pearl | 834P TRLH w/α2δ PSU | Raspberry Pi3 w/Nanosound 2 | B1R2 | Aleph JZen | Pi 4 | FE103E BLH | Rack
Old 2nd March 2021, 01:56 PM   #52
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
solder'n'plug'n'play - M2
solder'n'set a little'n'plug'n'play - F4, especially considering SP9 preamp swing (which is probably sole good thing SP9 is having )
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 2nd March 2021, 04:00 PM   #53
Giovanni1968 is offline Giovanni1968  Italy
Okkey Peppí I will give a read at the F4 specs but since I am no tech would you mind as a fellow Borbonic to summarise for me pros and cons of j4 vs F4 vs F5?
Grazie cumpá
Giovanni
Old 2nd March 2021, 04:00 PM   #54
Ahah, and I thought the SP9 being the almost only piece worth keeping in my sound system
Old 2nd March 2021, 04:08 PM   #55
peppennino's Avatar
Grazie cumpá
Giovanni
With your preamp I' probably go for F4 too.
Have a look here:
Sound of various Pass amps
Saluti isolani
Old 2nd March 2021, 04:21 PM   #56
peppennino's Avatar
And here:
According to those who built F4, it is very neutral and follow the qualities of the preamplifier. In needs more swing than others because it has no voltage gain.
Old 2nd March 2021, 05:53 PM   #57
@peppennino almost got me sold on the F4, as many of you suggested it seems it would make it worth keeping the SP9 (even tho it doesn't have a black face which I am 100% sure sounding better than my silver face one).
Gonna read the pdf and try and make up my mind
Grazie
Old 2nd March 2021, 06:03 PM   #58
Zen Mod's Avatar
F4 would allow full potential of your SP9 to shine, simply because F4 is not having voltage gain ....... that means that for full blast , preamp must deliver that on input of F4
that also means that F4 is not having much character of its own, resulting that preamp is dominant in amplification chain, sound wise
read pdf
Old 2nd March 2021, 07:06 PM   #59
read pdf
Just did a couple hours ago and then called my friend in Napoli (pizza?) who confirmed being available to help and about FW being worth.
Peppe, would you help me arrange a shopping list so I can figure where would I end?
Grazie
Old 2nd March 2021, 07:19 PM   #60
william2001 is offline william2001  United States
william2001's Avatar
The TL431 is a critical part in the F4 for proper operation, not all are the same. I recommend this part: NCP431ACLPRAG
And most people end up lowering the value of R9 to get the bias current where you want it. I have a 5K there.
Dreaming of a DIY power ampHide this!Advertise here!
Thread Tools
Dreaming of EZ DIY concrete enclosures? Your prayers have been answered! mosconiac Multi-Way 4 10th March 2013 10:49 PM
Dreaming of a power JFET complimentary pair. JZatopa Pass Labs 7 12th January 2012 10:40 AM
Night dreaming? / Middle of the night bloom Gabevee Tubes / Valves 54 25th July 2004 04:36 AM
Dreaming of owning DIY-Loudspeaker store sianturi Multi-Way 11 16th July 2002 04:03 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
