F5 build questions
F5 build questions
Thread Tools
Old 12th January 2021, 06:22 PM   #1
tyerkey is offline tyerkey
Default F5 build questions
Hi All,
I have finally begun building an F5 amplifier that I bought the boards for about 10 years ago. Life happened and the build just had to be shelved. I have a couple of questions that I need help with. I am slightly above novice range when it comes to electronics, so please be patient with me. My Previous build experience includes a pair of ACAs and a Bottlehead Quickie.
1) I am also a woodworker. I realize that there are parts of this amp that will get hot. If I have appropriate heat sinking, and the base plat of the chassis is steel, would it be safe to build the rest of the enclosure out of hardwood?
2) I know it may be in the build guide, but how do I compute the amount of heat sinking necessary to keep this amp cool enough?
3) I forget what else I was going to ask.
Old 12th January 2021, 06:42 PM   #2
rayma is offline rayma  United States
The base plate would need lots of holes for natural convection, or a fan.
These should get you started.
Heat Sink Size Calculator
Heat Sink Size Calculator | Celsia
Old 12th January 2021, 06:56 PM   #3
Dennis Hui is online now Dennis Hui  Canada
Hoopy Frood
F5 build questions
Another thing is to reference the build guide corresponding to your F5 PCBs,
since it's possible you may have an older version.
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 12th January 2021, 10:12 PM   #4
McQuaide is offline McQuaide  United States
Wood is not a great idea given it doesn't isolate from all kinds of nearby interference. Maybe line it with aluminum sheet?
Mark Micro Seiki DDX-1000>Pearl 2>BA-3 FE>F5>Mirage OM-7 Towers
Old 13th January 2021, 03:11 PM   #5
Thank you all. I think I will bite the bullet and buy a chassis.
Old 14th January 2021, 11:02 AM   #6
mkane77g is offline mkane77g  United States
Grandfather
F5 build questions
Aleph J quiet as a graveyard. Run @ 53C.
Old 14th January 2021, 02:45 PM   #7
Centurion53 is offline Centurion53  United States
Very interesting build! Would love to see more photos, is the power supply on board or external?
  Reply to this post
F5 build questionsHide this!Advertise here!
Thread Tools
Pre Build questions: 6 channel Avondale Voyager build fred sonnen Solid State 0 20th December 2014 12:16 PM
Driver stage to finals newbie questions - (I hope not dumb questions) rongon Tubes / Valves 15 13th June 2011 09:29 PM
Some Quad els57 questions! - Novice Questions! Fanuc Planars & Exotics 13 5th December 2007 10:26 AM
Questions, questions, from newb DIYer Phatman91624 Multi-Way 41 3rd August 2002 03:52 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
