Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Pass Labs This forum is dedicated to Pass Labs discussion. |
Thread Tools |
#171 |
Woofertester, thank you for so long and detailed answer. Many things are clearer now.
I have to: classify jfets, check wattage/dissipation, put bigger resistors, change pinouts, make some boards and mount two amps. I think it worths trying, even it's at my limit. We're confinated now in Spain, boredom is my friend. ![]() Again thank you
B1 preamp + M2 clone amp |
#172 | |
#173 | |
For now, just live with the J175 operating its power limit. |
#174 |
I wonder if anyone considered putting their beasts in a tank and filling it up with fluorinert and an aquarium pump to circulate, one of those neat waterfalls for cooling just like Cray did.
#175 |
Official Court Jester
HAM Geezers did that with their melting 807s and 6L6 ..... bucket of oil ......
why one should the same with eeny tiny weeny JFets? if you push them in enormous current region , byebye any linearity
my Papa is smarter than your Nelson ! clean ![]() ![]() ![]() |
#176 |
#177 |
enormous current region means - above Idss ....... gate going positive ref. to source
I can't see that your pcbs are made to accommodate that (and they shouldn't be)
#178 |
Below is the basic schematic for a CCS beast cell. R3 is just a gate resistor. Any value from 200 to 1k ohms will fine. Nelson's micro-beast uses 470 ohms for R3.
For good linearity from the J113 jfet, Nelson's bias resistor, R2, is 47 ohms for 10 to 15 milliwatts dissipation per J113. Even at that dissipation, I can't keep my fingers on the jfets for more that 10 seconds. So heat dissipation needs to be taken into account. Lastly, R1 is 47 ohms. One drawback of the J113 jfet is Idss values range from 7 to 30. So matching J113s is important. |
#179 |
The CCS micro-beast schematic:
#180 |
Thank you!for the schematic and the information.
Best regards, Frank |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
tube x-over noise redux | jlg4104 | Tubes / Valves | 4 | 12th December 2020 01:31 AM |
Article: Beast With a Thousand Jfets | Nelson Pass | Pass Labs | 126 | 18th September 2019 09:35 PM |
The Beast with a Dozen Jfets | wrenchone | Pass Labs | 30 | 24th June 2013 04:31 AM |
Beast with a Thousand JFETs | Nelson Pass | Pass Labs | 297 | 18th May 2013 12:38 PM |
Guidelines for switching N-channel JFETs to P-channel JFETs (and vica versa)? | Test Electrix | Construction Tips | 9 | 24th January 2011 07:22 PM |
New To Site? | Need Help? |
