First Watt website update
Old 9th August 2020, 07:00 AM   #61
EUVL is offline EUVL  Europe
SJEP120R100
Ciss — 670pF
Coss — 103pF
Crss — 97pF
6x 2SK1058 parallel
Ciss — 3600pF
Coss — 2100pF
Crss — 60pF
But then if you have no Semisouth, maybe 6x matched 2SK1058 plus a Cascode is worth considering.
Good idea,
Patrick
xen-audio.com
Old 9th August 2020, 08:32 AM   #62
petoluk is offline petoluk  Czech Republic
Weeell, but the SJEP data sheet gives the capacitances at Vds = 100V / Vgs = 0V, while 2SK1058 is quoted at Vds = 10V / Vgs = -5V. If you correlate the data based on the charts (at least for Ciss, there's no Coss / Crss chart in the 2SK1058 data sheet), you get:
SJEP120R100
Ciss = ~850pF
2SK1058
Ciss = ~330pF x 6 = 1,980 pF
Still a lot, but not 5.5x as much, "only" 2.5x. So perhaps 4 in parallel selected for the highest yfs would just about cut the mustard... (2SK286, with 1.4 typ / 2.5 max yfs and Ciss of ~400pF, could still be a cheaper / easier to find option.)
Old 9th August 2020, 10:00 AM   #63
claudio52 is offline claudio52  Italy
claudio52's Avatar
Location: Mediterranean Sea, near the Circe enchantress
Can this silicon carbide power mosfet be a candidate?
https://www.mouser.it/datasheet/2/90...0d-1795432.pdf
Old 9th August 2020, 10:19 AM   #64
P.S. Found the capacitance charts for the 2SK1058 in TO-3, née 2SK135, so at comparable Vds / Vgs (10V / 0V), we'd get:
SJEP120R100
Ciss = ~850pF
Coss = ~300pF
Crss = ~300pF
2SK1058
Ciss = ~330pF
Coss = ~310pF
Crss = ~10pF
File Type: jpg Bias_Voltage_Dependencies_of_Capacitance_(2SK135_2SJ50).jpg (173.2 KB, 421 views)
Old 24th August 2020, 07:53 PM   #65
Antoinel is offline Antoinel  United States
F8 is innovative, an example of unmatched simplicity and efficiency-performance.
Let's broaden the view of this innovation by considering a classical power amp which has the familiar 3 stages. An input diff amp, followed by the last voltage amp and followed by complementary buffers. Let's do unto this classical amp what Mr. Pass did to J2.
Disable one semi from the the input diff amp, and return loop feedback to the source or emitter of the remaining semi in diff amp. Maybe easier written than done; but its an experiment!
Best
Anton
Old 24th August 2020, 08:18 PM   #66
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
heavyhearted, I must admit - F8 is equal to (my beloved) M2 in sheer wit and elegance, and that even without Iron in signal path
go figure ........... nothing to Babelfish there
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 24th August 2020, 08:27 PM   #67
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Don't feel bad. Initial front end to Last Sony Vfet Amp is M2 front end w/ Edcor.
Just for you....
Old 24th August 2020, 09:03 PM   #68
Zen Mod's Avatar
Just for you....
Old 25th August 2020, 06:44 AM   #69
2 picoDumbs is online now 2 picoDumbs  Australia
2 picoDumbs's Avatar
Just for you....
Nice one.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
  Reply to this post
First Watt website updateHide this!Advertise here!
What make and model are the original drivers in Wilson Watt&Puppy 7 (WATT) aguiarrj Multi-Way 17 24th June 2017 10:39 PM
Driving high watt speakers w/lower watt amp? bwolf Chip Amps 15 9th February 2016 11:28 AM
2.3 watt x 4 or 5 watt x2 SET amplifier using DECWARE Zkit1 and Zkit4 schematics Redwolf92 Tubes / Valves 12 29th October 2014 10:19 PM
creating 1 watt rms power from 5 watt chip amp? realflow100 Chip Amps 51 16th January 2013 11:35 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
