Pearl 2 Crackling on Left Channel
Old 13th June 2020, 02:43 AM   #11
hirscwi is offline hirscwi  United States
I replaced the ZVP3310 along with the CCS (Q10 and Q11 - ZTX450). It seems to be working just fine now.
I do have a question about zeroing the DC at the test point (using P1). The closest I can get to 0 is about 25mV and it sometimes climbs to 200 mV after a few minutes. Is this normal? I am measuring with the cartridge connected to the circuit.
Thanks for the assistance.
Old 13th June 2020, 02:57 AM   #12
codyt is online now codyt  United States
codyt's Avatar
I recall that being normal when I built mine. I did end up putting a bit of capacitance in series with R14, which keeps offset rock solid.
Old 13th June 2020, 11:16 AM   #13
Thanks.
Old 15th June 2020, 12:50 AM   #14
For what it's worth, I had to replace both ZVP3310s because I was getting quite a bit more gain from the right channel after replacing the ZVP3310 on the left channel. Must have been different gain codes?
Old 15th June 2020, 05:22 AM   #15
mymindinside is offline mymindinside  United States
Hirscwi, what precautions did you take to keep the ZVP3310 ESD safe while installing it?
I'm starting on my Pearl2 and dont want to fry mine while stuffing the boards..
One method i've seen recommended is to short the gate pin to source (with foil or a clip). I do have a wrist strap but am not sure where to connect it on my workbench, don't have an accessible ground point.
Just in case, i do have some spares...
Old 15th June 2020, 11:50 AM   #16
I used wrist straps connected to ground of house wiring.
Old 16th June 2020, 02:02 AM   #17
Ah ok, ��
Old 30th June 2020, 04:57 AM   #18
Super_BQ is offline Super_BQ  New Zealand
Super_BQ's Avatar
Send a message via ICQ to Super_BQ Send a message via Yahoo to Super_BQ
After uncovering my Penultimate Zen (aka Zen v4) monoblocs. I've discovered 1 channel is also louder than the other. It's quite noticeable with Klipschorns. The affected amp also seems to show little mid-range sound.
Will double check if the cables could be the source of the problem because i'm not keen on unsoldering all the TO-247 IRF transistors (3 per board x 2 as i'm running 2 boards per channel in balanced mode).
I do know the Zen v4 uses the same ZVP3110 and ZTX450 transistors. I have plenty of spares for which they were purchased around the same time I built these monoblocs (circa 2002).
Old 1st July 2020, 02:10 AM   #19
Super_BQ's Avatar
OK - all is fixed.
https://i.imgur.com/Ogn6HsD.jpg
https://i.imgur.com/srXuGwE.jpg
As I suspected, bad ZVP3310A input mosfet. I had 40V showing on the input +
Being in monobloc config, I tested each side individually, clearing the 1 was like half the output and slightly distorted.
Pearl 2 Crackling on Left ChannelHide this!Advertise here!
Audiolab 8000a Amp Left Channel Crackling griff505 Solid State 2 4th December 2015 11:36 AM
Crackling noise from left channel of my Arcam CD23 andy2 Digital Source 8 7th March 2013 04:14 PM
Crackling sound from left channel of X150.5 pingpong Pass Labs 1 7th February 2011 02:14 AM
Crackling noise in left channel. fritz39 Solid State 1 20th January 2009 11:57 PM
Tube Amp - Crackling Sound on Left Channel Noak Tubes / Valves 8 28th December 2005 01:46 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
