The Singing Bush
The Singing Bush
Old 4th April 2020, 06:22 PM   #411
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
The Singing Bush
Originally Posted by lhquam View Post
Here are some startup waveforms corresponding to the circuit in post #406. The horizontal scale is .2s/div.
  • violet is Vds(M1) at 20V/div
  • yellow is V+ at 20V/div
  • blue is V- at 5V/div
  • cyan is Vs(M1) (M1 source pin) at 20V/div
  • Vd(J1) is slightly less than Vs(M1).
The simulation in post #406 agree fairly well with these measurements.
tnx lhquam
and tnx for special Singing Bush picture you sent me in e-mail
regarding Singing Bush - as I already described - SIT biasing circuit is faster than Mu, so during startup procedure SIT is already biased in moment when Mu is starting conduction ........ so Mu is seeing (almost ) full rail voltage while current being 0 ...... then as current is rising, Mu Puck Vds is decreasing........
so , highest Vds is (almost) rail voltage , while highest current is pre-set Iq, luckily ( 'twas a Cunning Plan) never happening in same time
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 4th April 2020, 07:28 PM   #412
lhquam is offline lhquam  United States
Yes, that is a big advantage with having a separate power supply for the SIT bias circuit. I strongly considered that when designing my PCBs, and would do it for future designs.
I just looked at my PCB artwork and at trivial mod, cutting one trace and adding a wire to an unused Molex connector pin would allow using a separate supply for V-. The only other change would be to reduce one cap in the bias circuit from 1mF to around 22uF.
Old 9th April 2020, 03:12 AM   #413
ZM and other builders of the Singing Bush:
Does anyone have definitive listening opinions. What combinations of the mu follower resistors are preferred? (I refer the the resistors as Rmu (gain) and Rhi (the resistor above Rmu), where Rmu+Rhi defines the overall bias current.)
I have done some A/B listening comparisons against my XA25 build. The SIT amp is currently at 2.0A, Rmu=0R15, Rhi=0R5. Both amplifiers have an excellent sound stage. The main difference I hear is probably due to low damping factor, where I hear some low frequency "boom", probably due to speaker resonances. It is amazing that a 1%+ THD amplifier competes well against one with 100X lower THD.
Old 18th April 2020, 10:19 PM   #414
elwood625 is online now elwood625  United States
elwood625's Avatar
And now for something completely different, a man building a Singing Bush.
Power supply mock up, and matched SIT's.
Upgraded my Klipsch Heresy 2 speakers with new crossovers from Crities along with titanium dome tweeters from series 3 & 4. Once inside, fiberglass insulation was added, the cabinet was empty(?). Very nice sounding with my ACA mono-blocks.
Next, test SIT's using Zen Mod method, need to drill and tap a couple of holes to mount the SIT on a heat sink.
I hope to be very ready when the world wakes from it's nap.
ACA v1.6 monoblocks, Balanced Zen Line Stage, M2x, Aleph J, H2, B1 Korg triode, 12AX7a Phono amplifier, Balanced B1 Korg triode, 6FG6 "Magic Eye" tube VU meter, FS NJFET RIAA
Old 18th April 2020, 10:40 PM   #415
Zen Mod's Avatar
The Singing Bush
have small xformer?
Old 19th April 2020, 12:06 AM   #416
Ben Mah is offline Ben Mah  Canada
The Singing Bush
Thank you for all your work.
My build was based on the 50W Single-Ended BAF2015 2SK77B amp, with the THF-51S in place of the 2SK77B.
So it started out with Rhi=0R2 and Rmu=0R2, at 3.3A. It sounded quite good at lower volume but became harsh at higher volume. Since I usually listened at lower volume, I enjoyed it for some time. Another thing I noticed was that the sound projected out more than usual. This was also more pronounced at higher volume. Reversing the speaker connection polarity changed that to the sound being more behind the speakers.
After I did some distortion measurements, I found that the distortion was quite high. I then realized that was why the sound was harsh at higher listening levels.
After reading Zen Mod's Singing Bush posts, I changed Rhi to 0R3 (ZM had 0R4), and left Rmu at 0R2, and I=2,54A. The result was a drastic reduction in distortion. At this point, the amplifier was now also very enjoyable at higher volume. I still preferred the reversed polarity of the speaker connection for negative phase H2. Another characteristic of the amplifier, both before and after the Rhi change, was that the image projected was tighter and more focused than that of my other amplifiers.
I am quite happy with the sound right now so I haven't tried other combinations of Rhi and Rmu. Perhaps I will experiment when the weather gets warmer and I take the amps out of service and run one of my cooler (relatively speaking) amps.
As for comparisons, I have a SissySIT, 2SJ28 Hammond choke loaded L'Amp, and diyAudio Sony VFET amp. I like this BAF2015 amp best as it seems to me to give the more realistic portrayal of music. The other amps are still great amps - it's just that I prefer this amp more.
Some distortion measurements:
The Singing Bush
The first measurement was of Rhi=Rmu=0R2. The rest were for Rhi=0R3 Rmu=0R2
Old 19th April 2020, 12:59 AM   #417
elwood625's Avatar
ZM - Transformer has 2X 48v, 18v, 12v secondaries. 18v for bias circuit?
Old 19th April 2020, 01:33 AM   #418
Zen Mod's Avatar
The Singing Bush
18Vac perfect
if you have separate winding on Big Donut, that's practically the same as having separate small Donut
Old 20th April 2020, 05:49 AM   #419
wengtech is offline wengtech
Has anyone noticed this warning from Tokin?
it said voltage at the gate must be added first before the drain otherwise current will spikes.
quite similar to tube heater warming up?
Old 20th April 2020, 12:29 PM   #420
Zen Mod's Avatar
The Singing Bush
that's pretty much Conditio Sine Qua Non
fully served in Singing Bush
The Singing BushHide this!Advertise here!
singing x-over ton def Multi-Way 9 12th February 2015 12:27 PM
AD1865 DAC singing vandenberg Digital Line Level 14 7th January 2014 12:11 PM
EZDAC is singing now!!! ezkcdude Digital Source 217 11th December 2011 06:45 PM
Singing for change jackinnj Music 0 1st December 2009 06:53 PM
Help! My amp stopped singing... ligascon Tubes / Valves 20 5th April 2008 02:47 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
