Germanium investigations
Thread Tools
Old 27th February 2021, 03:40 PM   #281
VeightTripleDivision is offline VeightTripleDivision  Latvia
2SB206 too exotic for me.
Circlotron thread here is quite interesting, yes. I have LTSpiced a balanced input vacuum/Ge hybrid. I am just not sure if I want classic inductor loaded SE more or powerful circlotron instead. Still struggling to chose.
Old 27th February 2021, 04:07 PM   #282
Svjatoslav is offline Svjatoslav  Ukraine
Originally Posted by VeightTripleDivision View Post
Is 1T910AD quite the best choice for SE?
It is possible. This transistor seems to be the latest development of high-power germanium high-frequency in the world.
But it is limited in the collector-emitter voltage.
There is also GT905 (1T905), metal body, or plastic.
60 V, 3 A, 6 W, frequency up to 60 MHz.
Attachments - measuring table, and diagram of the measuring stand.
??905, 1?905, gt905 ?????????? ????????????, ????????? ????????????, ?????????????? ????????????
Old 27th February 2021, 07:36 PM   #283
Zoran is offline Zoran  Serbia
Originally Posted by Tubelab_com View Post
Many know that my exploits with vacuum tubes date back to a pre-teen kid in the 60's that got tubes, transformers and other parts from the trash to make guitar and HiFi amps. I also got discarded car radios from a local auto junkyard. If it didn't work, they tossed it. The radios from the late 50's usually had 4 or 5 tubes that ran directly from the 12 volt car battery and one big fat (TO-36) germanium transistor on the back driving an output transformer in a class A SE design. There were several different kinds. The number 2N174 comes to mind, but there was a silver colored Delco branded part that was the hardest to blow up.
The common transistor used in the germanium totem pole circuit was the 2N2147. It was in everything from Heathkit stereos to Acoustic guitar amps. The circuit design comes from the RCA transistor manual.
I wound my own driver transformers and used the circuit for everything from 10 watt guitar amps with car radio transistors to a monster amp that put out over 1 KW from 24 X 2N3773's.
I found one of my old amps with 6 X "2n3055's" when I was moving out of Florida. I built it in high school (1969) which explains my crude construction skills. It made 200 to 300 watts into a 4 ohm load on a B+ of about 100 volts. The measurements were made with a Simpson 260 and a scope, hence the large uncertainty factor.
Hi I have the similar repared mono block amps from Westrex
Westrex 2404-C Germanium Amp Restored
I spot thwat the same heatsinks was used in mine...
That topology sounds pretty good (to me).
cheers
Old 27th February 2021, 09:04 PM   #284
Somebody have done any Germanium buffer stage?
Old 28th February 2021, 10:13 AM   #285
jpatay is offline jpatay  Ukraine
Complementary pairs ГT402, ГT404 fit well in the buffer to the output stage. But they need to be equipped with radiators. Circlotrons can use ГT321, ГT403, П605А, 1Т906.
Old 28th February 2021, 01:43 PM   #286
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
I have several pieces of П210АВП, they look interesting on paper for output stage
made in IV '68
go figure
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 28th February 2021, 01:51 PM   #287
Suitable for an amplifier in a subwoofer. They are very strong, almost indestructible.
Old 28th February 2021, 02:37 PM   #288
Zen Mod's Avatar
btw. I mentioned this one several times
made by good friend of mine
Germanium Amp
he bought dozens of these Biguns, but also killed them plenty in amp developing, but ending finally with good and trusty amplifier
I would like to know where to buy them these days, but my deficiency in Russian language is just over my head now
Old 28th February 2021, 02:54 PM   #289
1T813 or П210АВП?
Old 28th February 2021, 03:08 PM   #290
Zen Mod's Avatar
1T813, preferable
they're more sturdy, if I'm not wrong
Germanium investigationsHide this!Advertise here!
Thread Tools
Honey Badger bias investigations Zymorg Solid State 17 17th March 2017 09:25 AM
Germanium Amp bata bane Solid State 15 23rd June 2016 04:03 AM
OCD Germanium off topic jfetter The Lounge 4 22nd June 2016 10:35 PM
About ADZ12 germanium brskovacevic Solid State 5 8th June 2015 04:21 PM
Sonic Tripath Investigations Pano Class D 39 16th February 2005 08:36 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
