On A Hippie Trail, Head Full Of Zombie
Old 14th January 2020, 12:06 AM   #71
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
I don't think you will hear a difference.
I just prefer silver cause it will help me sleep better at night knowing I won't need to be replacing the cables for a bloody long time, if ever.
I have some speaker cables that are green. It's easy replacing external speaker cable, not so easy replacing wire in the amp chassis. I prefer low maintenance.
If I didn't use silver plated, I would use tin plated.
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 14th January 2020, 10:37 AM   #72
Measuring properties of ECW20N20 and ECW20P20.
I had already done this years ago but the results are on my laptop that is dead, so doing it again.
Old 14th January 2020, 12:15 PM   #73
Results of Vgs Threshold (Id = 2.5mA) testing.
ECW20P20
0.53V x 2 out of 20 devices
0.55V x 18 out of 20 devices
ECW20N20
0.14V x 20 out 20 devices
You won’t get this level of matching out of any mosfets I am familiar with.
The whole curves match just as well from my memory of my previous testing results.
I will do complete curves of Id vs Vgs later (maybe tomorrow)
Old 23rd January 2020, 06:51 AM   #74
Just an update.
Almost ready to test powersupply.
Old 23rd January 2020, 10:01 AM   #75
JeffYoung is offline JeffYoung  Ireland
JeffYoung's Avatar
What's the part # on those big bridges? I was looking for something similar, but couldn't find anything soft/fast recovery.
Nice shielding on the mains entry.
Old 23rd January 2020, 10:05 AM   #76
http://ixapps.ixys.com/DataSheet/VBO52-08NO7.pdf
I don’t know what kind of recovery it has but we will see it in FFT and can compare with the FFT of the soft recovery rectifiers in my previous build.
Old 23rd January 2020, 04:19 PM   #77
JeffYoung's Avatar
A friend sent me a link to one that's a FRED:
VBE60-06A IXYS | Mouser Ireland
but dang, those suckers are expensive.
That looks like a nice chunky Ametherm behind it. You using the AS32-20010?
Old 23rd January 2020, 09:54 PM   #78
Yeah. I am aware of that one, but I chose vbo52 cause I prefer the package and terminal style of it. I also like the low forward voltage drop. I can always add an RC snubber if necessary, maybe 10 Ohms, 100 nF.
Yeah the thermistors are Ametherm. I can give you the part number if you’re interested, they’re a little different than AS32
Old 23rd January 2020, 11:37 PM   #79
JeffYoung's Avatar
Yeah, when you get a chance. I had a hard time figuring out exactly which one would be appropriate for JamJar.
I'm currently of the opinion that the AS32-20010 will be sufficient (over the AS35-20010), but I'm on a bit of a wing and a prayer.
(I'm feeding a 1.5KVA transformer which then goes to 47mF, 0R4, and 47mF on each secondary. Single thermistor in series with the primary.)
Old 24th January 2020, 12:05 AM   #80
MS22 20005 Ametherm | Circuit Protection | DigiKey
I am going with this one. The energy rating is better than CL60 with higher cold resistance at 20 Ohms, but similar hot working resistance to CL60.
I don’t understand their capacitance ratings since I have used over 400,000uF (200,000uF per rail) with CL60 with a 400VA transformer without issues and these are better than CL60.
I am using 500VA transformers per mono block.
I will be testing soon.
On A Hippie Trail, Head Full Of ZombieHide this!Advertise here!
Head-head sonic battle among the top sounding DIY SS amplifiers :) tommydoan84 Solid State 12 2nd November 2019 05:49 PM
Molex 11-39-0303 Crimp Die Head for Hand Tool IDC IDT Crimper Die Head Only NIB HonorPC Vendor's Bazaar 0 21st December 2018 01:23 AM
Pinnacle PN5+ speaker fell on my head, no longer works (neither does my head) bartbrn Multi-Way 4 20th August 2013 08:04 PM
Colne Valley trail DF96 The Lounge 4 30th July 2013 02:45 PM
Head to head comparison of Manger and Lowther in Acousta and Front horns David Pinnegar Full Range 3 12th January 2011 01:59 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
