B1 Korg loud continuous beep...
Old 7th January 2020, 02:22 AM   #11
Manolo47 is offline Manolo47  Puerto Rico
Default Photo here
I rewired the ground cabling and changed inputs. Input selector is the switch provided in the kit. Board vr1. It is still beeping. but it goes in and out on its own now and more ethereal.
All the music is there as it should be. Including a photo, maybe something is obviously wrong.
Old 7th January 2020, 02:43 AM   #12
noise does not go away when input is changed and volume control down...
Old 7th January 2020, 09:36 AM   #13
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
try cushioning entire pcb
also try magnet trick , to see are filaments the culprit
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 8th January 2020, 02:36 AM   #14
Eric is offline Eric  United States
Eric's Avatar
If you have a scope, this might reveal something useful. My NuTube rings a bit at 5300Hz when I change the stepped attenuator. It dies down within a few seconds and adding some damping materials helped reduce it to the point where it is no longer a problem. You might be having a similar issue - what is the proximity of the NuTube to your speakers? Some time ago, someone reported some interference issues with a fluorescent light bulb.
DIY Theater, Aleph-X Amps, LDR based BA-3 pre, B1 Korg, Pearl II, modified SL-1200 TT, F4, M2, Aleph-J, MoFo, a40, ACAs, FHXL & TB 1772 speakers
Old 9th January 2020, 12:29 AM   #15
Keeps doing it after some time playing. Maybe did not described the noise well, it is like a continuous shriek. If looks that if I press the 2 input interconnects with my hand it goes away or if I touch the case it also goes away
Old 9th January 2020, 12:32 AM   #16
Zen Mod's Avatar
keep just one thread alive , and try things ppl are telling you to try
Old 9th January 2020, 12:38 AM   #17
2 picoDumbs is online now 2 picoDumbs  Australia
2 picoDumbs's Avatar
Check all solder joints
"If you leave this point unattached to some circuitry, an ideal constant current source will emit a small lightning bolt which will travel until it connects to something." Nelson Pass
Old 9th January 2020, 12:40 AM   #18
Maybe rca connectors are not properly isolated from case or (Vice versa) maybe they are isolated when they shouldn’t be, depending on the intended earthing methodology.
Old 9th January 2020, 01:01 AM   #19
avtech23 is offline avtech23  Australia
Certifiably addicted to DIY.
avtech23's Avatar
Why another thread? Did you try any of the other suggestions?
The ever growing project list.. :NAP140 Clone, NAD 3020i & 3225PE, JLH1969, TDA2050, Fender 5F2A Princeton, NE5532 Pre, SHPA, B1 Korg, T2. : VSQC Phunk Style, Retro 50W, Filmosound 601, LM4780. : Apex AX-14, TGM-10, TDA7265 (Last in line)...maybe
Old 9th January 2020, 04:19 AM   #20
anatech is online now anatech  Canada
anatech's Avatar
These two threads have been merged.
Please do not create more than one thread on the same topic.
-Chris
"Just because you can, doesn't mean you should" my Wife
B1 Korg loud continuous beep...Hide this!Advertise here!
Small and LOUD! iPhone size and LOUD noobAV Multi-Way 35 20th September 2016 07:40 AM
2 X PIONEER CDJ-1000 MK3 PLAYER, Korg M3 88-Key Workstation / Sampler,Yamaha Korg holocoast Vendor's Bazaar 0 22nd August 2009 08:03 AM
Read this if you own a Sony Vaio laptop and want to turn off the annoying beep tone Rodeodave Digital Source 0 15th July 2008 05:08 PM
continuous outlogging Sylver300B Forum Problems 2 19th May 2005 10:11 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
