BA3 pre oscillating question.
BA3 pre oscillating question. Please consider donating to help us continue to serve you.
Old 4th December 2019, 02:03 PM   #1
ColinA123 is offline ColinA123  United Kingdom
Default BA3 pre, oscillating question.
I am having a strange (to me) problem.
BA3 Pre feeding F6. both bog standard.
Genuine jfets from Spencer, BA3 using 2SJ313 & 2SK2013 (Genuine.)
There were no faults when feeding the F6 from a 10K passive.
With the BA3, there is occasionally a low level whistle in both channels.
(Not hum or mains frequency, higher pitched.)
This does not alter if the volume is altered.
Moving wires, and earth points makes no difference, but the noise does just fade in, and out on it's own.
My guess is that the BA3 is oscillating, or picking up noise from somewhere but I can not find anything with a scope when it is happening.
Any clues?
This BA3
Old 4th December 2019, 02:44 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
put 10K resistor from D point to GND
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 4th December 2019, 04:23 PM   #3
Thanks, will try that.
Old 4th December 2019, 07:52 PM   #4
OK,
System has been playing for several hours now,
Noise very much quieter, now only audible with ear right next to the speaker.
Seems stable.
Thanks Zen Mod.
Old 4th December 2019, 07:55 PM   #5
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Pass designs generally don't have input filtering so when their bandwidth is quite wide they will amplify non audio signals they might pick up. You can add an RC filter at each input just in case. When a volume potentiometer is there it is best to put the input filter before that potentiometer otherwise a variable filter has been created.
Just connect a 1 kOhm resistor to "+in" and also a 1000 pF silver mica or film cap from "+in" to GND. This, of course, at both channels.
It's only audio. Member of the non modular PCB design committee
Old 5th December 2019, 03:58 PM   #6
McQuaide is offline McQuaide  United States
Are you referring to a Zobel with the cap and resistor in series?
Mark
Old 5th December 2019, 04:59 PM   #7
Zen Mod's Avatar
resistor in line with signal , then cap as shunt to GND
BA3 pre oscillating question.Hide this!Advertise here!
Oscillating Op-Amp Loren42 Analog Line Level 16 3rd May 2013 06:15 PM
Why is my amp oscillating ? CaptainMorgan Solid State 8 25th March 2013 02:43 PM
Difference between self oscillating and non-self oscillating D-amp. sildex Class D 36 4th August 2010 04:30 PM
Self Oscillating (Oscillating Calculations) Help! Reactance Class D 7 12th March 2010 08:37 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
