Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Pass Labs This forum is dedicated to Pass Labs discussion. |
New Electrolytics installed in
-Remote Power Supply -(4) in Power Regulator circuits -(2) in Phono Stage Adjusted V+ & V- to recommended settings (within 0.01 by my Fluke DVM) Those adjustment Pots are touchy little buggers... In the future, it might be nice to replace ‘em with something a bit less “twitchy”. Getting a subtle background hiss that seems to occur in conjunction with certain voices and sounds in the music like brushed cymbals. Other than THAT, the thing sounds MARVELOUS (and I don’t use that term loosely). This unit is new to me - so I do not have any comparison or before and after sounds to go by. (I re-capped it as a preventative measure and did not attempt to hook it up before doing so.) The Hiss doesn’t appear to be there all of the time - background is dead quiet when it’s supposed to be so. Have not tested the phono stage yet, so I doubt if it’s anything there. Any ideas on what to check? Last edited by Geeqner; 2nd December 2019 at 11:49 AM. |
#2 |
Official Court Jester
care to post some pics?
all voltages checked?
my Papa is smarter than your Nelson ! clean ![]() ![]() ![]() |
#3 |
Posted A BUNCH at the end of my previous “FET-9 Restoration” thread.
Gotta’ double-check listening tonight to verify if it’s isolated to one channel or not. Will report back around 8 PM site (Zulu?) time |
#4 |
sorry , I'm easy to be confused and distracted ... it goes with age and spirit
![]() so , link to pics ? yeah - if both channels , and PSU is shared , it must be common culprit for both channels if just one , look for bad solder points ( not always possible to solve with visual inspection only) , also wiggle-wiggle of suspicious part can change amount of his sometimes old parts are having pin -corosion inside of case , so wiggle can save you ![]()
#5 |
Yeah - I suppose that I can pop the covers again and re-flow any questionable solder joints.
Any particular type of solder work best on these fancy-ar$e, Ag-Plated Circuit Boards. (As I do not do this often and not worried about exposure, I'm thinking old-school stuff with Pb probably flows nicer in a fine-size rosin-core. But other than that???) Also need to double-check the Gain Jumpers setting - with my Power Amp (Emotiva XPA-2 Gen 3), it goes pretty loud before dial hits 12:00 position Last edited by Geeqner; 2nd December 2019 at 02:24 PM. |
#6 |
You can get Euthetic solder (with Pb that is) and some 2% silver if you want to go fancy.
Definitely stay away from PB-Free solder for a repair job on that type of stuff... Kester 44 is often cited by your fellow americans, should be fine for the job. Now that's getting me wondering what you used for the recapping ob... Last edited by coolnose; 2nd December 2019 at 02:38 PM. |
#7 |
I don't care for that modern fancy solders ...... except in case where there is some silver on pcbs , in which case is nice and clever using solder with some silver .....
not that I'm doing that often ...... ![]()
#8 |
Yeah - at Work, in order to minimize problems with waste disposal, etc,
EVERYTHING has gone to ROHS-compliant stuff, including the stuff that they pre-tin the leads and solder pads on Circuit Boards with. Naturally, this means that although it is more "environmentally friendly" - it flows like a warm turd ![]() (Sort-of like water-based Varnish...) Bring back the stuff marked with the Skull and Cross-Bones ![]() When you saw it - you KNOW that you need to be careful with the stuff, but you also KNOW that the darned stuff actually WORKS! |
#9 |
I made a french brand (MBO) Sn62Pb36Ag2 my "standard" solder, but a 500gr. spool of 0.7mm lasts a year or so... so the cost of the solder is negligable (more/less)
#10 |
I've heard good things about the Cardas products - they have solder too, for use with their wire / Litz Wire and Connectors.
Cardas Solder From what I've heard - most of their stuff seems based upon SOUND Engineering Principles with minimal "snake oil" effect... |
Thread | Thread Starter | Forum | Replies | Last Post |
Intermittent Static on ARC REF 3 Preamp | maxzimum | Tubes / Valves | 48 | 12th November 2019 10:23 PM |
BA3 preamp hiss | fwt1712 | Pass Labs | 42 | 3rd June 2016 02:47 PM |
arc xdi 1200.6 slight speaker hiss | bnae38 | Car Audio | 35 | 28th March 2016 12:12 AM |
Tube preamp SS PS slight thump like dead wax on an LP | Too much stuff | Tubes / Valves | 14 | 24th December 2014 07:45 AM |
Preamp hiss and my fancy new GC :) | markiemrboo | Chip Amps | 10 | 12th December 2006 10:07 AM |
New To Site? | Need Help? |
