1632 + transistor output
I am just wondering
Will it be a good idea to use opa 1632 for say a preamplifier, Which have susy. And output them to a discrete transistor for better drive? 1632 have internal servo..
Or just build something like a balanced bba3 or aleph p will be better?
What are the advantages quality wise.musicality .thd, harmonics etc.. Please shed some lights.
Official Court Jester
Joined 2003
as far I remember , that chip likes lower values for Rin ?
worth checking datasheet
besides that , good sounding one , I did use it as final stage , after xformer I\V DA conversion , where Rin(s) were also acting as adequate load on xformer secondary , resulting in proper linearity
Joined 2003
I mean - that chip is capable of being preamp itself , only care is range of preferred Rin values , so it'll need buffer in front , as Juma made it in his application for Circlotron
read datasheets and related papers, think about possible parts you have for input buffers (JFets?) , do not underestimate need for decent power supply ...... and when you done with preliminary thinking about approach and concept , write back here
How bout putting this in front?
It's on!
It's very good. Running it single ended.
Should make a version of whammy with it.. My friend will draw something later maybe jfet input. 1632 then 2sk213
Susy is not plain.... She is hawt like papa
And thank you theslowdiyer. Com for the Gerber file
